Lg 42 LCD tv Works fine for about 10mins the loses input display and tv info goes fuzzy. Sound is ok tho
  • 933 Answers
THERE COULD BE SEVERAL THINGS CAUSING THIS, YOU WILL NEED TO GET A DIAGNOSES BEFORE ATTEMPTING TO REPLACE ANYTHING.
Posted on Oct 29, 2012
  • 86 Answers
SOURCE: no signal display on rca 42" lcd
If you have tried other input jacks and cables with the same result, then yes, the input/output board is defective or buggy.  Sometimes a power drain can clear this up as well so it's worth a try:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If this doesn't resolve it, service would be necessary.
Posted on Mar 25, 2009
SOURCE: lg 42 inch hdtv lcd dont know pass code to unlock tv
Enter the password "7777".
Posted on May 28, 2009
  • 21 Answers
SOURCE: lg lcd tv screen goes
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
SOURCE: the tv sensor is not working on my 42" lg lcd hdtv
Believe it or not...THIS WORKS!!!!
 Look on the back of your set for an external remote jack. It should be the same size as a small headphone jack. If it has one, use a spare headphone plug or your headphones, and plug them in and out about 50 times. This will clean the tarnished contacts and make your remote sensor start working. Your remote sensor goes through a switch on this jack.
Posted on May 04, 2010
info33
  • 72 Answers
SOURCE: LG 26LC7D LCD TV that turns on, but no pix
Here is a link for the manual - it might help - http://tv.manualsonline.com/manuals/mfg/lg/26lc7d_26lc7dc_32lc4d_42lc4d.html
Posted on Jul 03, 2010
LG LCD TV is only displaying scanning bars of colour
Is the TV in some sort of case? Like an entertainment center. Sounds like it's overheating. If you do I would try to move it and see if it still does it.
Maybe set it on a stand outside of encasement.
Oct 06, 2017 | LG 42LC2D 42 in. LCD HDTV
My Sanyo DP42647 TV has sound but comes in very fuzzy not clear at all
have you checked it on video inputs on rear of set and also on tuner inputs to see if problem on all inputs?
Aug 26, 2012 | Sanyo 42 in. LCD TV
HI WHEN WE TURN OUR LG 42 INCH LCD TV ON IT WORKS OK FOR ABOUT 30 MINUTES THEN THE PICTURE GOES AS THE SCREEN GOES WHITE THE SOUND WORKS FINE AFTER ABOUT A HOUT THE PICTURE COME BACK AND IN OK ...
I suspect you have a poor contact on the video processor board or the upscaler itself on the screen.
Check all ribbon connectors and look for any components that have got very hot, there may be a dry solder joint beneath them.
Hope this helps.
Nov 27, 2010 | LG 42LG70 42 in. LCD HDTV
Lg 42pc1dv have just purchased a lg bluray player and hdmi cable selected corret socket get the picture ok but no sound, all works fine on daughters tv.
hi. i have the same problem with my sky HD box and the same lg tv as you,
did you solve the no sound through HDMI.
Nov 25, 2010 | LG 42LC2D 42 in. LCD HDTV
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Has fuzzy spots all the way across the screen and just scrolls up
Is the picture fuzzy whether you are waching tv or a dvd or a tape. If it's only fuzzy on tv or dvd or tape then it's the source. If all inputs are fuzzy suspect a bad tv.
Apr 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Jun 16, 2008 | LG 42LB1DRA 42 in. LCD Television
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
