Question about Whirlpool LER4634J Electric Dryer
Taking a long time to get hot - Whirlpool LER4634J Electric Dryer
  • Whirlpool Master
  • 7,482 Answers
Hi dennisconroy
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the heating element/thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me
Bud
Posted on Oct 29, 2012
Hot water not running to machine just the cold water
Try switching the hot and cold hoses. See if the hot water works. Sometimes the gate gets frozen, other times the hot is so slow it seems to not be working, similar to when it takes a long time to get hot water in the sink.
Apr 19, 2017 | Washing Machines
Hot water unit explodes at different times.Takes long time for hot water to arrive.how do we stop the explosions from happening?
Sounds like you need an expansion tank above your hot water tank. That would help alleviate any pressure that builds up.
Jan 30, 2016 | Water Water Heaters
No water is coming through when HOT water temp is selected. only on COLD. and COLD comes through when WARM is selected.
Sorry to read about your problem, I hope this helps you out.
sounds like your temp selector control is defective..
try this
on warm or hot, turn off the cold water valve at the wall.. you should get hot water, if you dont..you may have a defective hot-water inlet valve
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Washing Machines
I have a Kenmore Series 80 Super Capacity Plus Washer. It has 3 water temperature settings, Cold/Cold, Warm/Cold, and Hot/Cold. Warm is Cold and Hot is barely warm. I know I have very hot water as the...
the inlet valves just open and close, if you have high cold water pressure, it will override the hot water. I suggest you turn down the cold water valve, until warm is kinda warm. your cold water fills will take longer, but you will have warmer water
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Kenmore 24032\24036 Top Load Washer
Dryer is hot when opened, but takes 3 or 4 timed cycles to get clothes dry on very dry setting and timed setting
Check for a restriction in exhaust system,not just behind unit but all the way to outside vent,should feel warm decent airflow at outside vent.If not all you will end up with is warm moist clothes,You need good airflow to take away the moisture in the clothes not just heat.This issue can happen slowly over time and next thing you know its taking two or three times longer to dry even though when you open the door its hot inside.
Good luck
Aug 08, 2010 | Amana Dryers
My Rinnai 26 sometimes takes 10 minutes to start
This is not an uncommon problem. You may notice this problem particularly if you haven't used hot water for a period of time. The hot water heater is probably working, but there is quite a bit of water that has to clear out of the lines before the hot from the heater reaches your appliance. I suspect that the water heater is doing its job, and that is the assumption I am going off of for my next statement. A recirculation system will work well to eliminate your problem. Again, assuming that the hot water heater is in proper working order. I would do my research on recirculation systems before buying one. Often times you get get a relatively inexpensive unit that will do the job for you.
Nov 18, 2009 | Rinnai Water Heaters
Hot water is cutting out after 2 - 3 minutes whilst showering
check the screen on the cold water intake on the cold side,, you might have to flush the system out, and do you have the shower head water restricter in, if not you may be using to much hot water,,, how many other hot water fixtures are running at the same time? try running just the shower,,,if this is a tank water heater the dip tube could be bad that is on the cold side it takes the cold water to the bottom of the tank and forces the hot water out,, if you ar only getting a couple of min of hot water and the dip tube is bad it is not going to the bottom but just at the top and not getting all the hot water you will need a plumber
Mar 21, 2009 | Water Heaters
Dishwasher runs for a long time
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Nov 12, 2008 | Kenmore 24 in. 17362 / 17364 / 17369...
Whirlpool LER4634J Electric Dryer Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
