Question about Roper Washing Machines
Have a 2002 kitchen aid top loader washer kaws750jq4 does everything but the spin cycle, the motor runs but won't spin unless you help it. Is worth fixing? If so how?
Goes into spin cycle and motor kicks in drains the water but wont spin without help, then does not spin fast enough to do any good.
  • 641 Answers
SOURCE: Washer won't fast spin or drain
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port. Good luck
Posted on Sep 04, 2007
the dr
  • 447 Answers
SOURCE: I also need the answer...
Verify Lid switch ..... A solved rating is great motivation to continue giving priceless advise........
Posted on Oct 03, 2007
  • 351 Answers
SOURCE: roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Posted on Mar 20, 2008
  • 66 Answers
SOURCE: ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Posted on Nov 27, 2008
  • 98 Answers
SOURCE: spin cycle won,t spin. starts then stops
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Apr 01, 2009
How to fix the spin cycle on my Whirlpool washer?
Usually Debra you have to replace the motor when this happens motor is weak and heating up cutting out to soon ..Hope this helps
Mar 02, 2015 | Whirlpool WFC7500VW Washer
How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the transmission.watch this video
http://www.youtube.com/watch?v=9K1KHEogf3c
May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
Aug 29, 2011 | Whirlpool Washing Machines
Washer wont spin
Dear Cindy,
Fixya people are not on a switchboard, and we do not answer until someone of us reads and understands the problem, and knows how to advise you to fix it.
You could wait days or weeks, depending on who reads the problem, and what they know about it.
We are at home or at work somewhere, and are answering questions in our "spare time".
Two things to check are the drive belt (if it has one) or the coupling attached to the motor (if it has one)
God bless your efforts.
Oct 17, 2017 | KitchenAid KAWS850L Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
The washer runs through entire cycle but when it gets to the spin cycle the motor clicks on but does not spin
Hi there....you havent stated whether its a top loader or a front loader.....top loader 1st.....
usually caused by a defective drive clutch..this will require the drive mechanism to be removed and a relacement clutch fitted
front loader 2nd...this is usually caused by failed spin windings in the motor..worn carbon brushes in the motor.or a failed programmer....
regards Sir Galahad
Aug 16, 2009 | Washing Machines
Kitchen aide front loader washing machine won't finish cycle
On ours, i think that those codes were overload codes.. i had to go downstairs and turn the circuit breaker right off for about 5mins - when i clicked it back on, the washer reset.. i took some of the extra wet towels out and ran another wash with no issues..
good luck
tpug
Apr 27, 2009 | KitchenAid KHWS01PWH Global Horizontal...
Kitchen aid top loader washing machine does not spin
Peace Friend,
ngfam1 At your service!
Sounds like a belt problem!
Or the linkage connecting the transmission to the agitator.
Or the WORST THE TRANSMISSION IS GOING!
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 30, 2008 | KitchenAid KHWS01PWH Global Horizontal...
Kitchen aid washer
Hi , washer is not spinning . found motor coupler had broken . need help on the best way to replace .
Jun 08, 2008 | KitchenAid KHWS01PWH Global Horizontal...
Washing Machines Logo
101 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
