Question about Whirlpool GFE461LVS Stainless Steel Electric Range
I have a fault code of f6e1
The oven temp is to high and it had 1 failure which is broil k3 bad and 1 fault f6e1
3 Suggested Answers
  • 464 Answers
SOURCE: GR465LXKS does not preheat to correct temperature.
did you check both the broil and the bake elements to make sure they were ok?
Posted on Oct 24, 2009
dmftrucker
  • 1922 Answers
SOURCE: oven faults at high temps
replace oven temp sensor
Posted on Nov 09, 2009
F6E1 WHIRLPOOL OVEN CODE
what is the model #? sounds like a fused relay on the control board, or an element that is grounded to the frame. call a tech on this one, 240V appliances are not to be trifled with!
Mar 24, 2016 | Whirlpool 30" Self-Cleaning Freestanding...
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Whirlpool RBS305PD Electric Single Oven
1.Our gaz range (with electronic range control) Amana ACS3350AS oven bake works normally at 350 F for 40 minutes, then stops. While the broil can still work at this point, it's likely the Oven - High...
Ovens temps are generally controlled by a probe with two wires called the oven probe(1100 ohms at room temperature for a good one) This probe connects to the main erc control board, which as temperature rises, it changes resistance reading, which is read by the board.......These usually show a fault code on the display when one fails........
The oven ignitor is glowing which ignites the flame. Usually this has to read between 3 to 3.5 amps to be good. (can be 2 or 2.5 and glow and the gas valve will not open) If the ignitor is glowing after 40 minutes, it is most likely the ignitor is bad. (the broil has a separate one, the bake has a separate one) If you do not have a amp clamp to test, you will need to replace part and see what happens, if it fixes problem.......good luck (it could be a sticking gas valve or relay but the ignitor is the most common failure, fragile part also, do not drop it)
Feb 11, 2011 | Amana ACS3350 Gas Kitchen Range
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
Aug 14, 2010 | Kenmore Ovens
Oven takes too long to preheat. 20 minutes to get t0 300.
3 possibilities:
1. Broil burner is cycled with bake burner during pre-heat ... make sure both burners are coming on during the pre-heat ... could be ignitor or gas valve failure on one burner ... you can check Broil mode to see if the broil burner ignites...
2. Temperature sensor bad or connections corroded ... this can signal the electronic control that the oven is hotter than it actually is...
3. Fault in the controller itself. If this seems likely we can test/repair it for you if you like.
Best Regards,
Bruce
www.fixyourboard.com
Jun 23, 2010 | Amana ACF3355AS Gas Kitchen Range
When I try and Bake or Broil the oven beeps and gives a fault code of F3EO
HI. Generally, this will be the cause of a failed oven temp sensor. If your unit's orientation is doubled, the top oven sensor will be the culprit. Some model will incorporate a sensor fuse at the wiring harness. Check the fuse, if equipped, for continuity. If the fuse is bad, replace it. If the fuse is ok, replace the oven temp sensor.
F3E0 - Failed oven temp sensor(top sensor if double oven)
Mar 01, 2010 | Whirlpool Ovens
Ge true temp oven with an F1 code...what is it...model #J KP15AOA
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Feb 10, 2010 | Kitchen Ranges
The oven function (broil, bake, etc) knob does not light
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
Sep 08, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Oven flashes F2 and beeps in the middle of baking or broiling something. Our oven is all electric and recently whenever we start to broil or bake something, after a little while it will shut off and the...
HI. an F-2 during a baking cycle is the result of an out of control oven temp that has reached Temperatures above 615F-630F
If this actual over temperature condition occurred, Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred, Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Aug 04, 2009 | GE Ovens
Whirlpool GFE461LVS Stainless Steel Electric Range Logo
296 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
