Question about Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome...
Single moen faucet base plate moves - Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome...
    Novelist:
    Champion:
  • 231 Answers
The mounting nut below has come loose. Have someone hold it in position while you go under and tighten the nut. You may need a basin wrench to do theis.
Posted on Mar 20, 2017
frcs68
  • 1605 Answers
SOURCE: hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Posted on Apr 06, 2009
  • 44 Answers
SOURCE: I cant stop my Moen single lever kitchen faucet
1. If it's "leaking" from the body then, the O-Rings between the body of the faucet got gunked up with minerals from your water. This interferes with the seal.
The answer is to take some grit cloth/very fine sandpaper and clean the inside of the spout body. Wipe clean. I would also suggest replacing the O-Rings on the faucet body, but at the very least wipe the O-rings and faucet body clean.
THEN: lubricate the inside of the spout body AND the O-Rings with silicone grease. It's translucent and readily available and the only thing I would ever use for a faucet repair. NOT plumber's grease, NOT WD-40.
Reassemble and enjoy.
2. If it's dripping, the you need a new cartridge. You can get them for FREE from the hardware store if you have the old cartridge to trade them. The problem is that Moen cartridges are water-sealed into place and you need a special tool to break that water seal. The special tool (just a tiny piece of specifically shaped plastic, really) comes, you guessed it - with the new cartridge.
Two possible solutions: a) bite the bullet and just buy the cartridge (~$25) or buy a Moen cartridge puller, usually available from the hardware store as well for about the same price. Ask, they might even lend you one.
The point of whichever tool you end up with is to rotate the cartridge itself inside the faucet body to break the water seal so that you can pull it out with a set of pliers. There will be a retaining clip to pull out as well.
www.plumbingpartsdepot.com/moen7300.gif
http://img2.timeinc.net/toh/i/a/plumbing/faucets-toilets-07.jpg
Good Luck.
Posted on Sep 09, 2009
Testimonial: "this will give me something to work on. thanks"
  • 129 Answers
SOURCE: My moen single lever faucet is loose, how do I
On the back side of the lever you should see a button cover. It pops out exposing a allen key. this will tighten the lever
Posted on Nov 08, 2009
FixinFax
  • 3085 Answers
SOURCE: need to replace cartridge in single lever moen
Turn off water
Remove the handle with an allen wrench, usually 1/8".
Unscrew the dome with a pair of channel lock pliers with a rag to prevent scratching.
Wiggle out the old cartridge with the channel lock pliers.
Clean all innards with WD-40.
Reverse procedure
Posted on Dec 12, 2009
Testimonial: "Thank you for the speedy reply it was needed at the time because the part was jammed or at least it seemed so."
  • 25 Answers
SOURCE: repair moen single lever faucet
All Moens are the same- so no matter what model u have- u do the same thing. U have to pull the valve out. It's very hard to pull. It may take several tries- don't be afraid to pull. My husband is a plumber. He said they're difficult to get out. U just have to pull. Hope this helps! Good luck!
Posted on Jan 04, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Moen cathedral keeps coming loose and it base moves when you rotate the spout from sink to sink.
    tighten the lock down nut under the sink , also,, unscrew the cap (at the base of the spout,, and Lube the O ring ( with either plummer grease if you have it, or if not with vasoline) this should cure your problem
    May 04, 2011 | Moen Monticello Single-Handle Kitchen...
    Moen 7700 leaking at base of faucet. how do you get to o-rings
    Here's a link to show you how to get the spout off using "strap wrenches" The allow you to get the nut off at the base of the faucet spout without harming the chrome finish.
    http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html
    There is also a video at the bottom of the blog post showing how I did it.
    Oct 17, 2010 | Moen Monticello Single-Handle Kitchen...
    Single handle Spray faucet leaks at it's base, leaking under the kitchen sink
    If you still have the receipts from the purchase call Moen directly as they warranty their faucets for life and will send you the replacement parts you need. If you need to purchase replacement parts then you can purchase a Moen single lever repair kit from your local hardware store which should run you around $10. Go the the Moen website and look for your model. They generally have an exploded view of every one of their models that will assist you in dissassembling the tap without any surprises. Reassemble the tap with the new o-rings etc installed and test.
    Aug 10, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    How to insert bearing washer on moen single handle kitchen faucet
    I have the exact same problem! The gray plastic washer has popped out from between the plate and the brass groove below the washer! I can't for the life of me get it back under there. Because it's sitting too high, the handle doesn't fit and the metal plate is loose.
    Please help!
    Apr 10, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    I have a Moen Single Handle kitchen faucet, it's leaking at the base and below the neck (where is swivels for the faucet to move side to side). How do I fix it?
    Replace the "O" rings that are behind the spout portion. You will have to remove the top of the faucet and pull up on the spout section. There will be a couple of "O" rings there. It is best to have Moen send the parts to you as locating the proper size "O" rings can be difficult.
    Mar 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
    I have a kitchen single lever moen faucet and the cartridge wont come out. I have removed the retaining clip and all screws
    you may need to get the moen cartridge puller,either moen brand, or brass craft, they can be tough to pull some time's
    Feb 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Moen kitchen faucet spout
    there should be a removable "button" on the faucet base below the handle. under there, there should be a set screw. loosen the screw, remove the handle. now u can adjust the base, collar, etc. to ur liking...don't forget to reassemble everything the same way u removed them.
    Dec 13, 2009 | Moen 7310 Legend Single-Handle Kitchen...
    Can't tighten single handle moehn kitchen faucet
    there is supposed to be a nut with a washer under the sink in the center, the metal plate is just for decoration, the nut and washer have to be installed before the sprayer is attached the stem that it connects to has threads on it for the nut your faucet should have came with a long socket made of plastic to install the nut
    May 30, 2009 | Moen 87530 Touch Control Single Handle...
    Moen 7065 leaking at base of lever control in kitchen faucet
    Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
    Apr 05, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
    524 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
