Question about ASUS A8N-E Motherboard
ASUS A8N-E motherboard dosen't boot up
My computer with a AMD Athlon 64 cpu and a motherboard of Asus A8N-E motherboard don't want to booth up. I have check the PSU and found out that it was ok. I can see the LED inside the motherboard is on everytime I turn on the power supply but still it does not booth up. I remove all the connection of the hard disk and CD rom just to test it but still no repsonce. I don't have any clue on what happen pls. help?
  • 1 more comment
  • edselcabrera Jan 04, 2009
    No fan is spinning and it's like the power will run on a millisecond and then stop. But the LED is still lit. I try the psu to another computer and its works fine. I already test it bare bone with one memory inserted still no response. Could it be the battery of the bios died out? I have this board almost going to 3 years.
  • ehostin Feb 22, 2009
    I have had a similar issue with the A8n-e motherboard. I have had chipset fan problem in past and replaced the fan.
    have had a couple of instances where the computer would not turn on. But, after a "rest period" would come on when power switch pressed.
    Now, the machine will not come on AT ALL. There are no lights, no fans turning, nothing. I checked that the PSU was functional by disconnecting motherboard power cable and jumping the green cable to a black, common wire. (saw this on another forum). The PSU fan comes on and using digital multi-meter, all wires deliver juice (red give +5volts and yellow deliver +12volts).
    Any suggestions? Is MB clearly the issue or are there any other possibilities?
  • Chris Fell
    Chris Fell May 11, 2010
    Do you have a processor cooling fan spinning? does the hard drive spin? do the cd/dvd drives operate ? if yes to all then you most likely have a failed motherboard processor socket. Contact me for further support compdoctor2005@btinternet.com
Hello. The manual says that all the power connectors must be in place, the main connector and two ATX 12V 4 pin plugs. It states that there will be no attempt to boot without all three power plugs inplace.
Posted on Oct 31, 2012
    Scholar:
  • 40 Answers
Make a deep examination of the board, look for burned/broken microresistors. You might need a magnifying glass and good lighting. Any resistor showing a little blob or browning is burned. Microresistors are those minuscule black,gray,brown or white rectangles lying all over the motherboard's traces. Check first the ones near the power supply connector and near the chips, specially one that says winbond on it, this last ones may get burned from USB overloading, from using non-self powered hubs also called passive hubs.
You may check for blown capacitors, capacitors are those standing cylinders with a plastic cover around them with numbers and letters printed in those covers. On top they are left without a cover and they are aluminum color, they may be flat or have one or more grooves runing across the top. A blown capacitor, looks different from the others because it looks a little bloated on the top, or may have spilled some sort of transparent varnish from its bottom to the motherboard or its top to other components around.
After that, you might want to check that your memory is OK in another computer and seated right in your motherboard, check the graphic card if it isn't of the integrated type. Finally you may suspect of the CPU, athlons get very warm and they can get burned too. Never start your pc without a cpu.
Posted on Jan 03, 2009
    Scholar:
  • 172 Answers
This points towards a blown board, in particular the processor socket is the culprit. Replace motherboard.
Posted on Jan 04, 2009
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
Jun 29, 2010 | ASUS A8V-VM Motherboard
Want to upgrade to amd athlon 2
Hi........Socket 939 is an outdated processor and not compatible with Athlon 2. You may find a 939 dual core on ebay, but suggest you save up for an AM3 mobo. Hank
May 10, 2010 | ASUS A8N-E Motherboard
What amd cpus does this mobo support? are there any that I can get off newegg for this mobo? and which sli connector should i get from Asus? like what length?
939 pin Athlon 64 X2 / Athlon 64 FX / Athlon 64 are the supported CPU's.
For the SLI connector, it's a 2 1/2 inch connector. (63.5mm).
Oct 26, 2009 | ASUS A8N-SLI Deluxe Motherboard
Motherboard dont see all installed ram after changing cpu's.
You might want to update the bios. Flash the bios on your new motherboard.
Aug 11, 2009 | ASUS Computers & Internet
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
2 x UltraDMA 133/100
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
Cup fan erro
Firt remove the covering of the cabinet then locate a battery take it out rub it for few seconds.Place it back the way it was.Now if you have another cpu fan port on the mother board then plug your cpufans cable to it.Now restart your computer start pressing F2 ie bios settings.Now check the time and date. restart it again. See if it fixes the problem.
Please rate me> Karatela ;-)
Dec 07, 2007 | ASUS A8N-VM Motherboard
ASUS A8N-E Motherboard Logo
1,298 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
