Question about HP Officejet 7210 All-In-One InkJet Printer
Printer makes loud whining noise
Device began to emit loud noise (high-pitched squeal) right after it said black cartridge was defective and I replaced it. Prints okay, but I can't keep it running because of the noise.
SOURCE: high pitch noise
Try backing off on the screws that hold the fuser in place.Start with
the bottom right.
Posted on May 20, 2008
myob247
  • 1342 Answers
SOURCE: makes noise
Click HERE for HP troubleshooting for your printer.
Posted on Jun 07, 2008
aicaxz
  • 511 Answers
SOURCE: HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
Posted on May 29, 2009
  • 26 Answers
SOURCE: HP Deskjet F4240 Printer & when I turn it on loud clicking noise
Try the steps given in the below document.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00587637
Also try the following resets and check
Perform a partial reset
A partial reset will return user settings to factory defaults. On some models, language and country/region settings are also reset. Perform a partial reset of the product by following the instructions below.
* Unplug the power cord from the unit.
* Reconnect the power cord into the unit.
* When the lights begin to flash, press and hold the On/Resume and Paper Size buttons.
* When only the On/Resume light is flashing, release the buttons.
* When the On/Resume light is steady, the reset is complete.
Wish
Posted on Aug 01, 2009
  • 59 Answers
SOURCE: printer keeps saying remove and check cartridge
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01091133&cc=us&lc=en&dlc=en&product=1141647
>copy and paste this on your browser and follow the steps and see if this will resolve your issue
Posted on Sep 23, 2009
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
What is making this 08 caliber 2.0L sxt cvt have a High pitched whining sound at idle and driving?
Possible bearing in one of the drive pulleys. I have changed numerous alternators for this noise. Take the belt off and start the car. If the noise goes away you know it will be pulley related and not transmission related. If noise goes away, spin all pulleys by hand to determine the defective/noisy one
Aug 03, 2015 | 2008 Dodge Caliber
My Hp 1200 laser printer makes a high pitched squealing noise and I have to pull the plug out to stop it.
The fuser is the part of the printer that heats the toner to the paper. turn the printer around and open the back cover. You should see a long black bar with green clips on either side to release a paper jam. There may also be rollers in there. Make sure there is no debris in the fuser, and that those clips are in the functioning position (usually down). If the fuser is removable, which I don't think it is in this model, take it out and then reinstall it. Then give it a shot. Usually though high pitched squeal is a toner cartridge thing. If you are using reman cartridges try a new (actual hp) cartridge from office depot or staples.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
May 13, 2014 | HP LaserJet 1200 Printer
Piaggio mp3 125cc motorcycle, won't start and emits high-pitched "whining" noise, last garage-serviced October 2012
chec alternator for health--sounds like bearings are bad--du u gut a repair book for that model--git one online or checout library sec 629--its a basic component so othr manual can help u
Feb 25, 2013 | Piaggio Motorcycles
How do I fix a high pitch noise when spinning?
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings.
Jan 28, 2011 | Asko W6222 Top Load Washer
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
2006 AUDI A4 2.0 HAS A HIGH PITCH SQUEAL AT IDLE TAPERS OFF AT HIGHER RPM -THEN MAKES A WHINING NOISE WHEN ENGINE IS SHUT OFF --ANY IDEAS?
hey not sure if its totally right but the high pitch squeal at when its idleing could be the tentioner pulley bearings on the engine belt not sure about the whining noise when its shut off
Oct 04, 2009 | 2006 Audi A4
Red lights flashing
check you have nothing jamming the printer spool, i fixed one of these last week only to find that the person kept it on the floor and had dropped peanuts inside, once cleared obstructions printer working fine
Aug 19, 2009 | Epson Stylus C84 InkJet Printer
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
HP Officejet 7210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
