H,would anyone know how i can make computer faster safely & easily please
Have tried to solve the slowness looking at u tube SO Complicated ! & microsoft help .as a newby id welcome an easy way please.thanks in advance!
  • annie Oct 30, 2012
    thank you to all the helpful people! will try your suggestions.
  • Computers & ... Master
  • 5,660 Answers
1) Go through all of the applications, and programs YOU have installed.
(NOT Windows based one's)
Delete the ones you do not use.
2) Copy off all of the personal information on your computer, that you can do without. Photos, video, and music, plus documents you have created, or downloaded.
When a computer's Harddrive reaches 50 percent full, the computer slows down. When it reaches 70 percent, or more, YOU really start to notice it!
Have to free up space in that harddrive.
3) Run Disk Defragment;
Basing the example on Windows XP versions. If you have Vista, or Win 7 post back in a Comment.
Click on Start > Control Panel, then Performance and Maintenance.
[ A note before I go on;
There are two different views available for Control Panel.
Category View, and Classic View.
The above is if you are in Category View.
IF you are in Classic View, I would like you to temporarily switch to Category View. You can switch back if you like when you are done.
Go to the left side, and click on - Switch to Category View ]
After you have clicked on Performance and Maintenance, click on Rearrange items on your hard disk to make programs run faster.
After it has loaded click on Analyze.
Even if it states "You do not need to defragment this drive",
(C: Drive), go ahead, and click on Defragment.
(C:Drive should be highlighted)
Also would suggest you download, and install the free CCleaner.
Not advertising, I have used it for years.
It's a Registry Cleaner.
Works as good as paid for cleaner's, and better than some paid for cleaner's.
I can guide you step by step in downloading, installing, and using CCleaner if you wish.
After you have deleted programs/applications, there are fragmented files (Bits), that are left behind.
Windows Disk Defragment does not wipe these out.
Also every time you visit a website you pick up cookies.
Harmless, but DO take up valuable harddrive space.
CCleaner removes all of this 'junk', and this helps to speed the computer up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Oct 31, 2012
SOURCE: Making my computer run faster.
help about this question
Posted on Dec 30, 2008
SubliMation
  • 219 Answers
SOURCE: very slow computer
A slow computer can be caused by a multitude of reasons, but it is not due to your Internet speed. Typically the most popular reasons are:
1. Too many things running in the background (including viruses, malware, and spyware).
2. A fragmented hard-drive.
3. A messed-up registry.
So, to check how many processes we have running in the background we press Ctrl + Shift + Esc. Once the task-manager opens head over to the processes tab. Here you have a readout of all processes running on your computer. At the bottom of the application is the total number of processes running. Typically for Windows operating systems you want the processes to be between 20-30 for good system operation. The processor (CPU) should also be jumping between 0 - 2 percent usage like a heart-beat while you're not doing anything. If any of your numbers are above the, "norm" you can expect slow-downs.
The first thing I would do to clean up a system is to head into, "Add/Remove Programs" located in the, "Control Panel." Once inside I will look for applications that I know I will not need or have no use for. Once I have cleaned up my system in this method I will download CCleaner (Which I know is free of malicious files). Once installed I will run the cleaner to clean up temporary files sitting on the hard-drive. Afterward I would defragment the hard-drive. In this instance the default defragmenting tool located in Start>Programs>Accessories>System Tools>Disk Defragmenter will work. However it is not as powerful as some of the payware versions, such as O&O Defrag. I recommend that you try out the 30-day free trial of O&O just to clean up your system. Once installed find a time period where nobody will be using the system for 3-5 hours. Then run a COMPLETE/Access defragmentation on all hard-drives listed.
Depending on how badly your hard-drive is fragmented you may have to run the same defragmentation process more than once.
After defragmenting I would use Auslogic Boost Speed to clean up more junk files, erase bad registry entries, defragment the registry, and even boost my Internet performance just a wee-bit. I'm not sure if Auslogics provides a free trial for their product, "Boost Speed." But if they do, you should download it just to help speed up your computer.
After finishing all these steps your computer should have sped up dramatically. If not, there's still too much running in the background. Go to Start>Run and type in: services.msc
After pressing OK the services window appears. PLEASE READ THE FOLLOWING CAREFULLY! If for some reason you stop a critical system-service, restart the computer. It will be started again upon the system restart. HOWEVER, if you disable or set to manual any of the services and they turned out to be critical services, they will not start upon a system restart and you could be looking at a re-install of Windows. So PLEASE research any service before deciding to disable it or setting it to, "Manual."
Within here you can define which services you want stopped, you don't want starting with the system, or you don't want starting at all. Some services are for popular applications installed on your computer such as Ipod services, Yahoo services, etc... Setting them to, "Manual" means they won't start with the system in turn freeing up the processor of yet another process allowing the computer to run faster, if even just marginally.
However, make sure to research any service you are uncertain about as setting it to manual or disabling it could be a very bad idea.
Let me know if I can help you further, or if I need to explain any steps in more detail.
Posted on Mar 11, 2009
alexvelez052
  • 40 Answers
SOURCE: There is no sound to my computer
wow...okay this can all be resolved if u uninstall and reinstall the driver... easiest way however if the speed of the computer is that important to you u have to revert the steps and add more ram to the computer and disable certain things on the startup menu instead of disabling sound..disable things like messenger progams and torrent programs and music programs from starting at the beginning not necessary things like sound....
I’m happy to help further over the phone at https://www.6ya.com/expert/alex_32392698f23d119d
Posted on Jul 12, 2009
LASITHA-VEGA
  • 428 Answers
SOURCE: I am trying to REMOVE Easy Media Creator 10 from
here u go
solution is from Roxio
Cheers :)
Please rate the answer
Posted on Nov 11, 2009
SOURCE: HP Pavilion Elite m9517c Desktop PC stuck on welcome screen
hi
there is problem with windows OS
u have to reinstall wondows befor you go for reinstall just tak backup from you C drive
Posted on May 21, 2010
My 09 fusion has week bass It worked fine then one day it stopped???
If it has the Audiophile system, you have top mounted subs with a dedicated amp by the back glass. You can easily remove the sub covers and see if they are working. If not I would then look at the sub amp.
Nov 27, 2014 | Cars & Trucks
Tip
How to fix Errors with your Computer
<p><span>For being your computer much faster you have to fix errors which are making your slow. I will provide you some tips that will help you to how to fix errors. Here are some things you can do to make your <span>computer</span> faster. </span><br /> <p><span>First thing is that you have to organize your computer folders, files. This is called fragmentation. You can repeat it once in a week or two weeks. For doing de-fragmentation you run it by using link (start&gt;all programs&gt;accessories&gt;system tools). Windows and other operating standard they offer a De-fragmentation program to your <span>computer</span> to get rid of found fragments. This loading programs and files will much faster. </span><br /> <p><span>Second things to remove all junk files that you can have. Lots of people tend to not realize that their Internet browser folder for temporary files, cookies, history data. You must clean it at least once in month to for improving the performance of computer.</span><br /> <p><span>Third things to know the scanning for viruses, such as spy-ware and mal-ware. When you make sure to scan them, you have to run computer in safe mode. For running in safe mode window, you simply turn on your <span>computer</span> and press F8 at the time of booting & select safe-mode option.</span><br /> <p><span>Operating systems during safe mode run only the bare minimum load files and programs are under way for the operating system. By the help of this you can get rid of them safely.</span><br /> <p><span>By using these tips you can get rid of many unusual files and folders from your system. <span> </span></span><br />
on Dec 24, 2010 | Computers & Internet
Hi please help me..my acer aspire 4738G i bought a month ago is really so slow.what would possibly happen to it.how can i fix it.please help me..thank you.
Hi there !
It is simple to solve by pressing F8 when booting up and running your computer on safe mode. Safe mode will fix some errors because of some faulty drivers or multiple drivers installed with the same drivers.
After that restart again you computer and then defragment your computer by going to start menu, choose accessories, choose system tool, choose disk defragment. Do it every week and surely will run your computer faster.
I hope it helps you.
Jan 16, 2011 | Computers & Internet
My window xp is taking a long time to boot up can i solve that problem
For details on speeding up a slow computer, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r5946321-fixing_slow_laptop_desktop_computer
Oct 07, 2010 | Computers & Internet
Computer is slow
When a computer is slow, there are a lot of reasons out there that may cause the issue: system errors, registry issues, too many unneeded programs running, poor security software etc. These are manual ways to ahieve, for a tech geek, it's easy; for a computer newbie, it's hard. As a result, l recommend this computer tune up tool to you, which can help you easily and instantly speed up your PC & fix all issues. Hope this helps.
Mar 13, 2010 | Dell Inspiron 530 Desktop Computer
My emachine is slow loading and constantly buffin, not being able to watch movies on utube My final question is how do I know my computer needs to be upgrade other that the fact that the emachine is an...
Hello
Well, the buffering on you tube is purely proportional with the speed of the internet connection you have, it means that the video plays faster than that which your internet connection is able to load, thus it starts to buffer.
To solve this you need to upgrade your internet connecting, upgrading the performance of your computer itself will have no effect on the internet connection.
As for the upgrading of your desktop, if you are happy with the performance, you don't need to upgrade. Most common upgrade is ram modules, which makes loading programs and such faster.
I would say a good method of knowing it is time to upgrade is to have a look if the parts for your computer is still widely available, if so, and you are happy with the performance, don't upgrade. If the parts for your desktop is discontinued of not very widely available, i would say it is a good choice to upgrade. Hope this can help you.
Kind regards
Andrea
Nov 17, 2009 | Computers & Internet
How do I remove the battery?
The problem is easily solved by removing the ten screws including the ones hidden behind the lower part of the rear seat and the bottom of the rear seat.
Jul 15, 2009 | 2005 Aston Martin DB9
MY MAC LAPTOP IS RUNNING KIND OF SLOW- I DO NOT KNOW HOW TO CLEAN
Well, generally speaking there are a number of reasons that may causing a Mac computer running slow, but commonly two factors: hardware part & system part. For hardware part: I guess it's OK if your Mac is not that old. For system part: there might be a lot of junk files, caches, registry errors... out there which largely slow down any Mac machines. about 80% slow Mac caused by this reason, if so, try cleaning the system from: http://www.howtospeedupmac.com/
Jan 17, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
Slow computer
YOu computer meet the average power requirement nowadays. HOwever if you want to make more faster performance. U only need to add more memory. 1Gb is faster than my computer which is 512Mb.
Ok adding more memory make the computer faster from 1 Gb to 2GB this is much faster.
hard drive is nothing to do with the performance of the system. its only a storage of all files.
but besure to know the model of the memory before you buy. it should be identical to your current memory.
melnavz
Jul 16, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Hello Kalono:
There are many different solutions to making your PC run faster.
Try www.pcpitstop.com. It will run a free full diagnostics on your PC and offer solutions.
Good luck my friend!
Seek Pc Repair
Feb 09, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
