Question about Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C)
Using a linksys g adapter card in my laptop cannot get internet
I am using a linksys -g adapter card in my laptop computer and have a linksys -n router. when i power up my laptop i get message that i am connected to the access point but that the internet cannot be found. help
    Problem Solver:
  • 12 Answers
U have to configure the router.Then & then your internet will work.You can see the instruction set given with the linksys router or instruction set cd.Follow the steps,which will ask you ip,user name,password etc. information.Fill the right information save & reboot it must work.
Posted on Jan 04, 2009
Trying to connect to internet cant find wireless & cant find a ethernet place either
The laptop in question does not have a place to plug in the ethernet cable. The laptop is not fitted with wi-fi or bluetooth adapters either. The best and cheapest way to connect this laptop to the internet is using a PCMCIA Card Adapter (type two or three as both are supported.) such as the product supplied by linksys. If yours is similar to the one in the photo then it should include a cable with the required network connection on the end. The "linksys" card you mentioned is no doubt the correct one, but minus the vital cable!
May 20, 2016 | NEC Versa LX Notebook
I have an old laptop that has a linksys wireless-b notebook adapter and my new computer with a linksys router attached is a linksys dual-band wireless-n. I can not get the notebook to link to the router...
Most of the newer routers use a newer type of encryption (WPA or WPA2) which is not supported by older 802.11b hardware.
Either set the Linksys router to use WEP encryption, or get a newer 802.11g card for the old laptop which can use WPA or WPA2 encryption.
Older versions of Windows XP also need to be upgraded to Service Pack 3 or apply this patch:
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=662bb74d-e7c1-48d6-95ee-1459234f4483&displaylang=en
Mar 22, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
Sharing internet from dlink 510g to linksys wap54g AP
yes, the manufacturer doesn't really matter as long as they are 802.11g (usually backwards compatible with a and b) so as long as the router and the adapters are installed properly NO problem
May 14, 2009 | D-Link High-Speed 802.11g Wireless PCI...
Wrong ip address, need to reconfigure
Im assuming youre using an integrated ethernet card since you say "adapter port" and "unplugged". So....
Since you reformatted your HD with O/S re-installation you may also have to reinstall or update it to the correct ethernet adapter driver. As far as the ethernet card set-up - copy your ethernet card property configurations from the other computers. Also copy configuration settings from your Internet Explorer options.
Jan 11, 2009 | Linksys Wireless-G WRT54GS Router...
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Linksys WPC54GS adapter card not connecting with wireless router
for one you could try and manually connect to the network by clicking site survey then choose your network on the list then connect. make sure to adjust the channel of your router to 11.
another option is to right click the green icon on the lower right corner of the screen down by the time/clock. the linksys icon green icon that has waves on it, right click then choose use windows wireless zero configuration. then confirm it by presing yes.
an icon that look like 2 small computers will apear at the system tray just right that then view available wireles network then connect to your network.
Sep 17, 2008 | Linksys (WPC54GS) 802.11g/b Wireless...
You are connected to access point but the internet cannot be found.
Do you have a connection wizard that you can run on your computer? Linksys offers them for downloading at their website. Try that -
have you named your home network so your wireless connection can "find" it? You don't mention how your main computer is networked in. A wireless adapter for a notebook will need to have a Linksys connection wizard run on the laptop.
If you have a Linksys router connected to your main computer, it should already have the piece of software you need. Most likely, you'll need to put it on a flash drive and install it from that onto your laptop. the wizard helps also to diagnose the right settings.
If you want to post what you are using for your main network (linksys router?) and which operating systems you are using, that will help.
For example, in Vista, you'll need to enable the option for "network discovery" under your laptop's control panel/network and sharing center.
You also need to have certain settings on your main computer for the wireless to work - there are two main types of wireless connections - B and G. Most of today's routers and cards will do both, but if you have an older router, it might not be set up to handle the newer or combined types. They run on different frequencies, so your laptop might not be "reading" your router's frequency.Also, if you have other wireless/radio frequency equipment near your laptop, it can interfere with the signal being received right.
You also need to be sure that your firewall allows the linksys system to access your computer (allowed programs).
Dec 10, 2007 | Linksys WPC54G Wireless-G Notebook Adapter...
Can't connect to internet by using LINKSYS Wireless-G card
I am assuming you have a dual boot machine meaning it runs either linux or windows and not both at the same time. Linux on the other hand may not configure the card automatically and as you should consider changes to the laptop in terms of configuration and devices are actually changes to two computers the windows computer and the linux computer. You probably did some configuration for windows to enable the wireless card (if there was no encryption windows may have done it for you). Linux on the other hand may not recognose and configure the card automatically and as you should consider changes to the laptop in terms of configuration and devices are actually changes to two computers the windows computer and the linux computer. The many flavors of linux also have almost as many means to configure devices. In order to assist you I will need to know which distribution and version of linux you are using. I will also need to know the manufacturer and model (possibly number and not description) of the wireless adapter to be configured. Warning this may be easy and in other cases it may not be and I have access to few linux distributions to experiment with.
Dec 09, 2007 | Linksys WPC54G Wireless-G Notebook Adapter...
Open Questions:
Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C) Logo
182 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
