Question about LG W1941S-PF Monitor
Monitor gets off after some time of taking start
  • nsrmpf
    nsrmpf Oct 30, 2012
    display disappears but power indicator glows as normal, after switch off of the monitor power and restart after some minutes, it again appears for about 5 to 10 minutes. Also one mote problem is being accompanied is that a vertical 2 inch width sky color belt on right side seems leaving a vertical 2 inch column on right side as unchanged color. This sky color belt some times disappears automatically and sometimes appears automatically but it remains appeared generally.
Veiwsonic VP2365wb backlight flickering
If it's not under warranty, buy a new one from newegg dot com.
Mar 27, 2013 | ViewSonic VP2365WB 23 inch LCD Monitor
VX2835M takes a long time to turn on depending on the time turned off
You have a unit with a failing power supply. When the parts called capacitors in the power supply start to fail they can't hold the charge like they should and it take a while for them to build up the charge and allow the power supply to turn on. Once they have a charge built up they work fine until the unit i turned off for a while and their charge drains then it starts over again. Here is a link to a parts kit that you can use to rebuild the power supply board and return the monitor to a working condition.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=178
I hope this helps, if so please rate my solution.
BuddyMc
Mar 10, 2012 | ViewSonic VX2835wm Monitor
This is a new monitor, had it running 2 days, screen started flickering on/off every 8 seconds, then it went dead. All connections were tight. I just plugged in a old monitor to get on line since I am...
The monitor you just bought died - hardware failure. Take it back to the one from which you bought it and either replace it or get your money back.
May 27, 2011 | Samsung Computers & Internet
It takes time to open the monitor. it only starts when the surface is hot
Faulty Screen. If under warranty get it repaired or buy a replacement. Do Not OPEN The Monitor as it can remain live even after unplugging it.
Jun 13, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
I have a 1780U. When computer starts up the
What I have done is boot the computer then wait a few seconds then reset it. That usuallu gives the monitor enough time to wake up so you can catch the bios info. It may take a few times to get it to behave but this works.
Nov 04, 2009 | Computers & Internet
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
Creeping black pixel line.
Hi mrtaz187,
Well it sounds like the monitor pixels are starting to fail. Once you notice the pixels starting to fail, you will probably notice that over time it get worse. I had the same problem on one of my monitors too. I think it's time to replace that monitor. On the good side, new monitors are relatively inexpensive. You might think about getting a name brand for your new monitor too as it will usually have a warranty for problems like this in the future.
Hope that helps,
Take care,
Michael
Nov 11, 2008 | Balance CM2019 19" LCD Monitor
Black screen
As in almost all lcd type tv/monitor the backlight will go out and the inverter should be replaced at the same time. Your cost about 50.00 if you do it yourself.
Take care
Kevin
http://www.fixya.com/support/t859266-koss_kld2700_lcd_tv_no_picture
Jul 14, 2008 | Philips Brilliance 107T20 17 in.CRT...
Monitor is failing to start although power is on
Sounds like you've got some blown capacitors on the internal hardware of the monitor.
Unless you are a seasoned computer hardware expert or electrical engineer I'd recommend you replace the monitor.
The capacitors that are blown are likely controlling the power aspect of your monitor, and aren't totally defective yet.
Most computer shops would not be able to repair your issue, due to lack of skills related to monitor repair. So you're going to find replacement the easiest / cheapest solution.
Of course you can try to ride out the problem as long as you can. But it will get worse over time.
Jan 08, 2008 | Xerox XA7-192i 19" LCD Monitor
LG W1941S-PF Monitor Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
