Question about Crosley Songwriter CR248 Shelf System
Has no sound coming out at all
Tape player CD player record player am and FM radio all in one the sound just won't come out took back off and everything looks fine help plz
    Master:
  • 444 Answers
It is cooked.
Posted on Oct 29, 2012
A CD is stuck in the player of my'08 Ultra Classic
Disconnect the battery for 5 minutes and reconnect.
Mar 06, 2013 | Harley Davidson 426290 AM/FM Radio
2002 xj sport jaguar am-fm radio not working. CD changer & tape deck work fine. How to fix?
Visit the on-line store, known as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem. Best Manuals
Feb 15, 2018 | 2002 Jaguar X-Type
I have a CD and in my car it won't playback discs. It allows me to insert/read the disk, it even shows the data, track number, and position in the song but it won't play to my speakers. The AM/FM...
What i found i have had that problem in the past,This may sound stupid but it works.Spray aftershave over the cd then push the cd into the player when the aftershave is wet.This will clean out the dust inside your cd player .i can say this will do no harm.ok pippall,Hope that solves it for you m8.
Aug 24, 2011 | 2003 Toyota Corolla
Trying to record music from my dj equipment not sure how to connect
out put from the dj stuff to the input lines on the amp your using to record on, once the CD or tape, or whatever your recording onto, is set to record, it should pick it right up , now if your doing all of this off your DJ equipment everything that's used, from record players, to CD to tape, will be run through the main amp your using, if the selection switch is set to whatever, you should be able to just turn on the unit your recording to, and it will pick it up , everything leading to the main amp will be plugged into, a line in, and some, ( tape player ) will also have a line out, ( so should the cd player if its a recordable one, which in turn would be supplying the lines output to each unit .
Jul 25, 2011 | Audio Players & Recorders
I don't know if you can help or not, but i picked up a pioneer stereo/cd/dual cassette player - model xr-p260f at a garage sale. It's really clean and looks like it hasn't had much use. The...
Tape players have several rubber belts in it and if we do not use them frequently belts loosen and become useless and they need to be replaced... . To accomplish this however you need some sort of handy man ability.. Take out the metal cover of the player by removing the screws on the sides .after removing the cover you can access the tape head /transport mechanism. if you look carefully to underneath of tape transport you will see the motor unit which belts will be there...check the belts for the moving mechanism and make sure the belts are not loosen / worn out or broken . You can replace it with a new one that may available in radio Shack stores. Take care..and let me know if it does not work out..
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Pioneer Audio Players & Recorders
How do I get it to record a voice?
Many portable 'boombox' recorders do not include a microphone for recording ambient sound, but can only record from one internal source to another, like radio or CD to Cassettte. Some do include an input jack for microphones or other audio sources, but you'll need to check your device's specs/ports to be sure.
May 18, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
Crosley CR704 record player wont work, HELP!!!
Make sure the switch on the back for line in, is off! I had mine on and it would not play. Switched it off and all works fine!
Aug 01, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
No sound out of speakers, but radio powers on.
Hi, im a retired ford auto elec inst. Tech so ill see if i can help you out. First, the orginal plugs, there are several radios and systems used. Was your oem radio am, am fm, or am fm tape? Next, if you had 2 plug that look similar but has 6 wires and the other has 8. Or does it have 4 wires. I should ask was your oem radio digital or analog? If was old school shaft type you will have a yellow, thats 12v + switched. Blue/red stripe is dial light, and a thick red wire which is ground. If its digital, look for the keyway on the plug. That is the top. First wire will be constant hot. Usually it a light green. Then the yellow, blu/ red, then another dail lightl ground then the power ant/ amp turn on wire. If you have a long plug and a small square one then you have fords premium sound. Which means there is a seperate amp. Lastly, if you have an 8 wire plug thats the speaker plug. If its 5 wire its a common ground system amd you will have to run new speaker wires or your new radio will have issues. Hope that helps
Apr 19, 2017 | JVC KD-G140 Car CD Player
Sony Xplod no radio in 2000 Ranger
if you have lost am and fm it sounds like the antenna connector on the back of the radio has come off, if you find that is the case put it back on and secure it with a strip of tape
Dec 04, 2007 | Sony XPLOD CDX-GT200 CD Player
Crosley Songwriter CR248 Shelf System Logo
159 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
