Heat will not blow hot air model #310aavo48090oabjd serial #0205a42429
  • 38 Answers
Give name make of unit and set up of system oil/gas ect...
Posted on Nov 03, 2012
I have a 2007 Saturn, Aura. Heater does not blow hot, slow coolant leak, & it also over heats. Please help! I'm freezing when I'm in my car!!!
You need to fix the coolant leak, then refill and bleed cooling system, then you will get heat and cure overheating problem too
Dec 16, 2015 | Cars & Trucks
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
I have a Rheem Heat and air unit. Model # RGAC-080AW Serial # CM3D104 F4782 4794 and need to find out where the filter for the unit is located.
What filter are you talking about?
Air filter: Usually with a heat and air unit, the air filter is located behind the return air grill.
Return air grill looks similar to ordinary ceiling or floor grill where the hot or cold air blows into each room. Except the return air grill is larger and is usually put close to the heat-air unit.
Remove the grill and replace filter every 3-6 months.
If no filter is present, then dust and hair get stuck on the coils and unit will not meet temperature setting.
See image of typical air filter:
http://www.instablogsimages.com/images/2009/02/12/air-filter_IYR3W_69.jpg
Jul 30, 2011 | Rheem Water Heaters
Dryer isn't heating. It turns and blows air but
make sure lint screen and vents are clean. next shut off electric and check heat element for broken element. then get model # and serial # order and change thermocutoffs located on heater box and fanhousing ck these steps one by one
Dec 09, 2009 | Kenmore 75962 Gas Dryer
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
Hot air coming out of back
portable air conditioners mainly have two hoses one hose is exhaust thats the one that is blowing hot air. the one pulling is return.. the hot air blowing out should be exhausted to the outside. the blowing air needs a hose and to be laid out a window the back should have model and serial maybe product number. the two holes are either 4 inch or three inch and most portable units other than hand me downs come with a window frame that allows the hot exchanged air to go outside and cooler air to be used for heat exchange.
May 28, 2009 | Maytag NMPEB08F2A Air Conditioner
Dehumidifier
Again, if your model is one that can be used in cooler temps so as not to ice up, the heat prevents this.
Aug 07, 2008 | Maytag M7DH45B2A Dehumidifier
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
