Question about Philips FR931 Receiver
Phillips fr931 owners manual
Need further explanation of hookups
Cable hookup
here is the owners manual: http://www.manualslib.com/manual/263845/Sylvania-6842pe-M.html
refer to pages 18-20 for proper connections
Nov 27, 2013 | Sylvania 6842PE 42 in. HD-Ready Plasma...
I HAVE PHILIPS AMP FR931 AND I HAVE A HITACHI HT4 TURN TABLE THAT PRODUCES A LOW VOLUME SOUND WHEN THEY ARE CONNECTED.
I can't find anything about the HT4 but it should be connected to PHONO (nowhere else) if it has a moving magnet cartridge and you should set the PHONO/LINE selector to PHONO.
http://www.p4c.philips.com/files/f/fr931_p00/fr931_p00_dfu_eng.pdf
Mar 26, 2011 | Philips FR931 Receiver
I just purchased a Sanyo Hdtv Lcd and the picture quality if off the picture seems to come out greyish or pale....i'm not getting a true color. Is there some adjustments that I should know about? I tried...
Check hookup connections. If you are using the component input (3 wire video green ,blue and red). Be sure both ends are in the correct colors. if switched or not all 3 connected color will be off. Composite video uses only 1 wire ,yellow. See owners manual for hookup explanations.
Mar 07, 2011 | Televison & Video
I NEED HELP CHANGING MY TV VIDEO FORMAT BACK TO NTSC I THINK I CHANGED IT TO PAL OR MULTISTANDARD. I HAVE NO PICTURE SO I CANT SEE MY SETTINGS . CAN U PLZ GUIDE ME THREW THEM.
Download the manual from :-
http://www.bose.com/pdf/customer_service/owners/og_321_2.pdf
Page 47 would have the explanation.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 22, 2010 | Bose 321GS Series II System
I have a dvp 3960/37 player I am trying to hookup to a Sony KV 32fs120 TV using YPrPb as a component. The Sony manual says the DVP must be Setup before connecting. The Phillips manual says to use the TV's...
If you are using the component output from the dvd player (3 wire video) progressive scan connect corresponding cable to tv . Besure to match colors. If you are getting a black and white double image you need to set the output of the dvd player to progressive scan. See owners manual for dvd player to set this. The yelow color jack on the tv is composite video and is not compatible with the 3 wire video .
Nov 20, 2009 | Car Audio & Video
Owners manual & remote
I just downloaded the manual for the DSR704 (except fo the inside of the front cover which I now need).
I went to directv.com/manuals. It gave a list of the manufacturers of their recorders. Choose Phillips and then select the DSR704. It was very easy once knew where to go. Good luck.
Aug 18, 2008 | Philips DSR704
Needing a manual/guide - onkyo tuner t-4310r
Please e-mail me the manual for Onkyo TX906 - I'm trying to hookup a subwoofer. Thanks!
disciple@email.com
Oct 23, 2007 | Audio Players & Recorders
24 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
