Question about Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer
Canon pixma mx340 scanner error codes 5, 145, 61
Scanner won't scan, sends back these codes
SOURCE: Canon MP145:Stop error E5 , use scanner only
THIS SOLUTION FOR PEOPLE WHO CANNOT RESET THEIR OWN PRINTER LIKE ME
hi, now i got a solution how to SCAN if your printer have E-5 error or something. First u must remove the both cartridge from your printer and make sure u connect your printer to your computer, after that, do this
With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
And then you will see no error in your printer (the LED shows number 1,and the alarm is in green)
NOW U CAN SCAN USING MP NAVIGATOR!
Posted on Apr 28, 2010
solofixya
  • 34 Answers
SOURCE: Canon PIXMA MP145 Scanner Problem
Take it to a Canon Repair company, It has a 1 year warranty and needs to be replaced or call 1-800-ok canon.
Posted on Nov 10, 2008
SOURCE: Canon Pixma MX700 Scanner Problem
I was having the same problem, and thanks to the person who posted solution number two which simply highlighted the fact that the apparently software that came with the Canon Pixma MX700 unit is not compatible with Window Vista.
The reason I was confused is because the printer was working perfectly fine across the network, but when I went to scan my computer would tell me that it can't communicate with the scanner. I'm thinking ... "well since you can communicate with the printer, you should be able to communicate with the scanner, after all, they're the same device!"
As a workaround, I used a third party program to do the scan (in this case, Photoshop) and everything worked fine. If you have Photoshop, just go to file > import to start the scan. If you don't have Photoshop, I would think whatever program you are using for image editing may have the same functionality.
Hope that helps,
Brian
Posted on Jan 11, 2009
SOURCE: scan gear error code:22500
Check Cannon support site, it has all solutions. Good Luck
Posted on Feb 19, 2009
SOURCE: Canon PIXMA mp240 All-in-one InkJet Printer. Error code: 2,140,2
I had exactly the same problem (error Code:2,140,2) in Canon PIXMA MP250, and it was solved when I replaced both ink cartridges which were almost empty (almost without ink). I know an scanner problem is not supposed to be in relation with ink or printer problems, but that's the way I've fixed it. Good luck!
Posted on Jul 27, 2010
Cannon error codes
Printer is in use or an error has occurred. check status. Scanner driver will be closed.
code 2,140,2
if scanner is not in use there is a problem using it with the USB unplugged.
May 15, 2013 | Canon PIXMA MX892 multifunction printer
Code:7,202,15- My Canon MX-870 (Twain) gives me this error code when I try to resizew in B/W or grey scale. No problem in color.
"Internal error occurred. Scanner driver will be closed. code 7,202,15"
Received the above error while inserting scanner image using MS Word with Canon printer/scanner Pixma 439.
The solution is via the following MS Word software choices:
From Word tool bar choose: INSERT/PICTURE/FROM SCANNER/then one of two choices, either: WIA-WIA Canon MX430 Series, or choose CUSTOM INSERT (Preferable).
R
Aug 21, 2012 | Canon PIXMA MX870 Wireless Office...
Scanner is disconnected or Turned off.
Try going to manufactures web site and downloading drivers for the printer from there. Also you might check your device manager to see if the unit is being recognized by your computer. it should show up iunder USB or Printers. I had an Epson that did the same thing but mine was a wireless and I had to re-establish coneection and go through setup again to have my IP address recognized. Most of the time plug n play will pick up the new device.
You might also try running security and windows updates on your computer, there might be an update that is keeping the computer from recognising the printer anymore.
Its just a start of what could be going on, hope its an easy fix.
May 29, 2012 | Canon PIXMA MP495 InkJet Printer
Scanner gives me code 5,145,61 how can fix it ?
RE: Scanner gives me code 5,145,61 how can fix it ?
I was using wireless router and receive exactly the same error code as above.
SOLUTION: Turn-off printer/scanner; reset or turn-off the wireless router power and then turn-on again. Turn-on the scanner. Start scanning.
Mar 11, 2012 | Canon PIXMA MP495 InkJet Printer
Canon pixma mx 700 won't scan showing error code 0x00000015
This is a windows or software error code,Uninstall the scanner/printer software and reinstall from the CD
If you have lost it you may download new drivers from here
http://support-au.canon.com.au/P/search?model=PIXMA%20MX700&filter=0&menu=Download
Aug 16, 2011 | Canon PIXMA MX700 All-In-One InkJet...
I am trying to scan a document using the Canon PIXMA MG6120 that is connected via wireless LAN to my laptop. I get an error message on the laptop as follows: START OF ERROR...
Your firewall block the communication. You will need to get into your protection software and allow 'full' access of MP Navigator (EXT)
Aug 03, 2011 | Canon PIXMA MX870 Wireless Office...
Printer will not print, error code 5010 is
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Scanner won't work
If you are using a wireless connection, your scanner will not work.  I was told the printer does not have the capability to scan wirelessly....prints wirelessly, wont scan
May 11, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer Logo
1,710 people viewed this question
old marine
old marine
