Bang & olufsen beogram 3000 starts up then stops
I turn my record player on it starts to spin and the needle arms lights up . this will last for around five seconds before just stopping. the needle arm will not move either when i use the controls for left and right. any help please?
5 Suggested Answers
  • 864 Answers
SOURCE: B&O Beogram 2000 turntable arm won't go down
Check to see if there is a cueing lever that is holding the arm in the up position.  If no cueing lever and it has worked recently then something has happened to the changer mechanism.  Open the bottom and look to see if there is an obvious problem like something stuck or broken.  You may be able to make the mechanism go through its cycle slowly by rotating the platter with your  hand so you can see where it is getting stuck.
Posted on May 30, 2009
  • 122 Answers
SOURCE: Need pick-up needle for old type record player.
you can replace with mmc4000 mmc20s mmc20e mmc20en if you can find one,been discontinued for a long time.
Posted on Jan 11, 2010
  • 122 Answers
SOURCE: Bang & Olufsen BeoSound 2000 door doesn't open (disconnected)
Push the door to the left this normally engages the door to the mech.it is designed to detach if the door is jammed or too stiff to move.Cleaning of the guide rail and door carrier is usually the cure.this can only be done properly be removing the central cd clamper and control panel assy.
Posted on Jan 22, 2010
SOURCE: Bang & Olufsen Beosound 9000 - CD does not play
gently open cd player clean laser with a cotton bud and wipe all round laser part and lugs at top and bottom of unit
Posted on Mar 29, 2010
My bang and olufsen 7002 wont select the phono stage
The Phono/Aux input has a slider switch to the left of it to choose whether to make it a regular line-in jack or to utilize the phono stage. The ground terminal is just above the jacks. The Beogram 4002 likely has a muting circuit that's in effect when the tonearm is in the lift position, which would explain the lack of hum til the stylus lowered to the record.
May 19, 2015 | Bang and Olufsen Audio Players & Recorders
What's wrong with my Beocentre?
If the sound is affected on all systems then yes something has gone inside. Try a pair of headphones, if the sound is still bad, then either the pre-amp has failed or the power amp.
Apr 26, 2014 | Audio Players & Recorders
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
I have a beomaster 5000 which will cut out at any time sometimes it goes for ages,other times it will go almost immidiately,also i have the beogram 5000 and the cueing function doesn't seem to raise the...
O.k. The Beomaster 5000 needs new Quiescent current presets , you can temporarily solve the problem by turning the two presets (in the main amplifiers) fully anti - clockwise .
Your beocord needs new belts for sure .. availiable from CPC of Preston .. Hope this helps ..
Oct 29, 2010 | Bang and Olufsen Beosound 2000 Shelf...
B & O Beocenter 4600: The record player won't spin
the turntable wont spin unless a record is on the platter,the centre 45 adapter weighs the record to determine 33/45.try pressing 33 and turning the platter by hand(remove expensive cartridge first!),if it starts to spin the motor leaf switch is at fault.is the belt in position.the motor pulley can become unglued.
Jan 08, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
May 30, 2009 | Bang and Olufsen Beosound 2000 Shelf...
Where can I buy an optical reader for my cd player?
cd mech no longer available.try cleaning laser lens.try replacing 30tr6108 and30c2103 bc338 and33/16v
Feb 12, 2009 | Bang and Olufsen Audio Players & Recorders
Jan 11, 2009 | Bang and Olufsen Beosound 2000 Shelf...
Beogram 1800 wont play the record!!
possibly some kind of obstruction inside.
I had something similar with my turntable, and it had a dirt dauber nest inside it!
no kidding.
Dec 03, 2008 | Audio Players & Recorders
102 people viewed this question
 Grubhead
Grubhead
