Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius WF541 will not switch on
My Hotpoint aquarius WF541 will not switch on, when switching electric power on all the lights flash on once and then nothing its totally dead.
So far I have cleaned the filter and blown down the pressure switch rubber pipe and it makes no differences.
The machine is nearly two years old, there is no sign of the motor bushes wearing out (Black carbon) I had this fault on my old Hotpoint and there was tell-tell signs of black carbon everywhere and it was much older.
Ideas please
Elctrics want switch on i checked fuse and plug socket with a lamp any1 help me
Posted on Aug 03, 2011
  • 679 Answers
If the washer doesn’t operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power, or, if the motor stopped mid-cycle, the machine’s overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself. Then restart the machine. Otherwise:
1) Be sure the machine is plugged in and turned on. If necessary, check the receptacle it’s plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely.
2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit.
3) Unplug the washer, and check the power cord. If necessary, replace the cord.
4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch. If it doesn’t click when you do this, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call a repairperson.
5) If the washer still doesn’t work, the controls may be faulty. Call a service person.
Thanks for your question
Posted on Jan 03, 2009
    Sergeant:
    Champion:
  • 239 Answers
Unplug for 5 minutes
Wf541 problems
if you mean the mains switch power this is available to buy on its own fairly easy to do,only four wires are connected to it.
Nov 06, 2013 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint wf541 shows the on/off switch as on but machine will not start. i have cleaned the filter, tried cancel switch and unplugged at the mains
Please check the power to the mains controller unit and if present please check if the door switch is contacting to give the OK signal for the controller to start the function . So if the inlet does not open and allow water into then is seems that the program controller unit is a suspect.
recheck once again to confirm, try to swap a similar board to confirm and then replace.
Sep 13, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF541 problem
Technical Fault is Pressure switch jammed on empty: check switch & module... in laymans terms its either a blocked sump hose or faulty pressure switch/module
Mar 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Same problem
Power it off at the mains for 60 mins and then rety. If it still does the same then call in a repair man as it is most likely thatthe main controller board is faulty and needs replacing.
Sep 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Flashing lights
HI, this is a control fault that may be corrected by unplugging or shutting down the breaker switch for about five minutes. this will reset the microcomputer to its original state. after the five minute reset, plug or switch the machine on and observe the results.
If the unit is still blinking and the unit is not operational, this will confirm a major control fault and you will need to replace the control board(microcomputer/timer control)
May 18, 2009 | Ariston Technologies Washing Machines
WF541 Hotpoint
Have the control board checked first
Apr 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
1,245 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
