Question about Linksys Wireless-G WRT54G Router
Computers have limited connection to linksys wrt54g although signal is full strength
I have a wireless internet setup and it was connected at one point but has since not been able to connect. I have two computers that are not connecting despite having full internet strength.
  • Linksys Master
  • 32,281 Answers
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Posted on Oct 29, 2012
XBRMann
  • 38 Answers
SOURCE: Cannot connect to wireless network
I agree with JonwVBFL, it sounds like the DHCP server is not enabled on the router. You can enable this using the administrative web interface on the router (http://192.168.1.1). The default username is admin with a blank password or vice versa.
Posted on Feb 02, 2008
drlalitv
  • 488 Answers
SOURCE: Wireless connection is showing unsecured wrt54g
you can use the installation CD and log into the router configuration or type either 192.168.1.1 or 192.168.1.0 in the browser..the default login and password are admin and admin or admin and blank(no password)once you are in the settings go to the wireless security and configure..you have lot of options there..
do look at this helpful site:
http://tinyurl.com/3xwffu
hope it helps,do get for any help..regards
Posted on Nov 28, 2008
  • 51 Answers
SOURCE: unable to connect to the internet
Open your web browser. Type in 192.168.1.1 into the address bar A dialogue box will pop up. Leave the username field blank and the password is admin. Once the webpage is displayed, scroll down until you find Local IP Address. Change this to 192.168.2.1. Scroll down and click save settings. Now attempt to access the intnernet.
Posted on Dec 24, 2008
  • 68 Answers
SOURCE: Linksys WRT54G can't connect 3rd wireless computer
log into the WRT54G wireless router and ensure that you do not have it set up for only handing out 4 IP addresses also check the laptop to see if it is set to have a DHCP or static IP address, if it has a static IP and your network is dynamic then this is why it wont connect.
if this resolves your issue and you are happy with the answer please grade me accordingly.
thanks
Posted on Aug 25, 2009
SOURCE: lost connectivity to Internet
with all the connectivity problems with linksys, maybe it is the router
Posted on Dec 16, 2009
Unable to stream novie sites with my linksys wireless-g router
Check the connection (signal) strength of your wireless connection in the status area of the task bar in Windows. Also, hovering the mouse over the wireless connection should reveal the connection speed. 54mbps is the highest you can expect on a wireless connection, which is generally OK for streaming video..Any less of a signal strength/connect speed will likely not be adequate for streaming video.
A poor signal strength is usually because of too much distance or too many walls between the router and the computer.
Hope that's helpful.
Jan 15, 2011 | Linksys Wireless-G WRT54G Router
Low signal strength
Having many users connected to a single WAP (wireless access point) will not affect the signal strength. It will however, affect the speeds each user is capable of.
Most Linksys routers have a homepage address of 192.168.1.1 - Enter this in your web browser.
From there you will be able to find wireless settings and enable either a password or a WEP key for security.
If you found this helpful please leave feedback.
Feb 05, 2010 | Linksys Wireless-G WRT54G Router
I have a Linksys WRT54g which worked beautifully for 10months. I have an ethernet connection and used it for my PC and a laptop. Now it logs on and off every couple of secs. I tried resetting the whole...
If you disconnect the router , you are able to go online. Go to the Linksys web site. www.linksys.com/download and download the Firmware of the router.
You will need to select the correct model number and the version number of the router.
The model n umber and Version number will be on the back side of the router. You will see model number in small letters like WRT54G and just after that you will see V 5 or V6 or V8. this number will be the version number.
Download the file on the computer.
connect the computer and the modem to the router again and open the router set up. Upgrade the firmware.
Click Here to know more about how to upgrade the Firmware.
Nov 18, 2009 | Linksys Wireless-G WRT54G Router
Having trouble connecting. I see my encrypted router, but it shows as "unknown." And when I try to connect with it, connection fails. Says not in range although I'm in my own house. :o)
you said that you can see the wireless network but it shows as unknown network
I think SSID broadcast on your wireless network must be disabled.
You will need to enable the SSID broadcast of your network.
Also try to change the wireless channel on the router.
WRT54G router's IP address will be 192.168.1.1. if you have not changed it.
Do you have any other computer connected to the router woth the ethernet cable ?
If you do not have the computer connected to the route then connect 1 computer to the rotuer with the ethernet cable.
Do not change any wireless setting on the wireless computer.
You will need to open the set up page of the router
Click Here for more info about how to change the wireless settings
Nov 13, 2009 | Linksys Wireless-G WRT54G Router
I have two computers receiving wireless internet via my Linksys WRT54G router. I recently purchased an Acer Aspire one (mini computer) Can hook up to wireless at my daughters and at other places, but...
For you to resolve this problem, you'll need to reset the router. Press and hold the reset button for 5 seconds, and when you are prompted for the user name and password just input "admin" in both fields.
Try connecting your computer to the router after this process.
Good Luck.
Oct 13, 2009 | Linksys Wireless-G WRT54G Router
RV Park,50 sites everthing A Ok. My House 1000FT from Linksys WRT54GL Router Signal Weak Can'Tget on line.Have repeater on House roof some trees on the site dnd@tyler.net
Routers generally have a 1000 foot limit, at the edge of the limit, the pc can see the router but usually will not connect, anything under 40% signal strength is usually not a connection that will work. Try moving the repeater and also try adding an amplified antenna,they are about 50$.
Aug 29, 2009 | Linksys Wireless-G WRT54G Router
Limited or no connectvity
you can use the WinSock XP Fix tool to reset TCP/IP protocol to original state: http://www.snapfiles.com/get/winsockxpfix.html
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Wireless rounter
in your address bar type 192.168.1.1 and go into your admin screen. if you have password type it in. Go to wireless tab and look up your security settings
Dec 05, 2008 | Linksys Wireless-G WRT54G Router
My laptop is not working
you mean not working wirelessly? please elaborate so we can help.. :-)
Jul 14, 2008 | Linksys Wireless-G WRT54G Router
Limited or no conectivity
hello!
-- are you connected hardwired or wirelessly to the router?
-- do you have other computer working on your network?
-- what is the operating system of your computer?
May 06, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
138 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
