Question about Carrier Heating & Cooling
What does code E2 mean on carrier thermostat - Carrier Heating & Cooling
5 Suggested Answers
SOURCE: My Heat will not work
the e2 code on a carrier comfort zone thermostat is indicitive of the external safety sensors which are located on your units ductwork in the attic. the e2 code are the hpt/ and lat sensor codes. the hpt is the heat pump temperature sensor and the lat is the leaving air temperature sensor. you can pull off the cover of the panel and behind it will actually give you all the fault codes associated with you carrier tsat.each sensor has a certain ohm rating and if its out of the range it will fail. now as to the reasons for failure, the indoor coil could be dirty, filters dirty, refrigerant charge incorrect.
Posted on Dec 22, 2008
  • 38 Answers
SOURCE: Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Posted on Jun 30, 2009
  • 47 Answers
SOURCE: I have a carrier heat pump that will run for about
Sounds like something is going on with the compressor or the outdoor unit. Call a service company
Posted on Nov 23, 2009
SOURCE: The thermostat is flashing and E2 error
It means the trailer is too warm for the thermostat to work - above 90 degrees inside. Take some ice and put in ziplock bag - place over thermostat and cool it down. Unit will start working when thermostat senses it is BELOW 90 degrees. FAULTY DESIGN.
Posted on Jul 15, 2011
Totaline Thermostate P274-1100 works fine when following programming but when I adjust the temperature manually it will start the furnace and after a few minutes the screen displays E2 error, blanks out,...
E2 is the error code for low line voltage. I would think that this is a erroneous code witch would indicate that the thermostat is defective. do you know if this is true line voltage 120v or transformer voltage 24v?
Mar 05, 2014 | Carrier Totaline P291-1003 Capacitor 10mfd...
The thermostat is flashing and E2 error code...what does that mean
Jul 06, 2011 | Dometic Rooftop RV Air Conditioner
Displaying E2
E-2 in Carrier Thermostat-Not enough voltage for the thermostat. Contact dealer for further information. Thanks.
Jan 31, 2011 | Carrier TSTATHCP Programmable Thermostat...
I have an E2 error message on my air conditioner. It has stopped working and resetting it doesn't help.
means you have less that 24 volts to thermostat check transformer or wireing to tstat
Aug 13, 2010 | Goodman CLQ36AR49 Air Conditioner
What does a flashing E2 code mean?
Check in your paper work for the unit,there should be a chart explaining fault codes.
Oct 07, 2009 | Carrier 38CKC060 Air Conditioner
Jun 29, 2009 | Carrier 38CKC060 Air Conditioner
I get the error code E2 It only shows 2 zones on my 4 zone syst
I reset the circuit breaker to the panel and everything is good now.
Jun 24, 2009 | Carrier 38CKC060 Air Conditioner
Air conditoner won't go on and receiving E2 message on panel
E2 code is 24 volts loss. Check transformer and control voltage should be 24 volts.
Jun 05, 2009 | Carrier 38CKC036 Air Conditioner
My Heat will not work on my upstairs unit. I am getting an E2 error code on my carrier thermostat. what does that mean?
Dec 03, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
167 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
