Question about Protron PLTV3250 32 in. LCD Television
Tv will not stay on and will not give a picture
The tv will only stay on for 3 seconds. i tried unplugging it and nothing helps.
  • 3 Answers
Turn it on with button as u turn on the plug after 10 mins
Posted on Jan 03, 2009
55hds69 hitachi plasma
I have had some issues with high ESR readings in the capacitors in the scaler circuits in those units. Do you have an ESR meter to check the caps in circuit?
May 14, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Turn on the TV, red light stays on, picture goes blank after a second.
I have the same problem. Factory reset did not help (hold Vol-minus on set and menu on remote five seconds, then unplug). Can there be something in service mode that would help?
Aug 04, 2012 | Panasonic Viera TH-50PX80U Plasma TV
My TV has been having a shacky picture when it first turns on for a few minutes, then clears up. the other day after using the TV for most of the day, it shut off unexpectidly, and now it will turn on and...
1. YOUR flyback is going bad 2. Peform a removal and replacement 3. check your error codes first to ensue nothing else exists 4. Proceed to change out the required parts 5. Observe all electrical risks 6. Order replacements from jimmyparts.com 7. Ensure to always remove power 8. Ensure to always use electrostatic wrist strap
Jan 31, 2011 | Panasonic PT-47WX49 47" Rear Projection...
No Picture or Sound on Vizio 52" Plasma TV
Try to use the reset factory reset feature. Unplug the set. After unplugging press the power button for 30 seconds. Plug the set back in and turn it on.
Apr 21, 2009 | Vizio L32 32 in. LCD HDTV
Sharp aquos 46 picture disappears intermittently
it might mean there is an intermittent connection or cold solder joint somewhere inside the set.
But I wouldn't just settle on that.
Here are some other things to check:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Here is what I suggest:
ONE: Give it a hard reset. Possibly the software codes in the power management are corrupted. Just unplug the tv line cord for 4 hours. That will reset everything internally to factory defaults.
TWO: Give it the old whacking test. Just bang on the cabinet in many places with your hand or fist. That will restart any cold solder joints or loose connections.
THREE: If the above procedure does not help, then you will have to call in an expert tv tech; OR just live with it and put in a line cord switch so that when it is OFF, it is really OFF.
Jan 17, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
TV turns on then off no picture
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
Protron PLTV3250 32 in. LCD Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
