Question about Briggs & Stratton 20-Amp Extenda Panel - 1659
Troybuilt 7000 xp generator, new out of box will stay running/ checked oil and gas, they are full
Honda eb 7000 inverter generator won't stay running. It runs for 12 seconds and stops. I tried disconnecting the oil sensor but no luck.
it appears to be insufficient fuel flow to the carby
check for blockages in the tap , lines , tank filter, needle and seat area
Aug 03, 2016 | Honda Electrical Supplies
Dewalt 7000 generator will not stay on
Oil level switch that protects engine is activated. Check your oil level.
May 22, 2014 | Dewalt 7,000 Watt 13 Hp Portable Generator...
Runs but shuts off automatac
check the oil, most of these have a low oil shut down. If it's full make sure it's sitting level while running. If it still shuts down and is full of oil and level, bypass the low oil shutoff and see if it stays running.
Dec 04, 2012 | Coleman Powermate Premium Plus 6250W...
Troy-bilt extenda panel xp 7000 generator paney will not display
My Troy-Bilt XP generator doesn't work it runs but it doesn't seem to be put out any electricity. It's new what could the probelm be
Jul 22, 2012 | Briggs & Stratton 20-Amp Extenda Panel -...
I have a Briggs and Stratton 7000 watt propane generator. When running this morning after two hours, it quit. It starts back up for about three seconds or so then quits again. I put a new tank on...
does this engine have a low oil shutdown unit on it
if so check the oil level an top it up it could be interupting ignition
be sure your tanks are full and connections are good and tight
brush soapy water around connections to see if any have a leak
if not oil level shutdown , then sounds like a fuel problem
suggest have a gas serviceman take a look
these units can be tricky to solve
Aug 11, 2010 | Briggs & Stratton 15,000 Watt Home Standby...
Mower starts for 15 seconds then stops.
if it is still new. call troybuilt and ask who in your area does service work on troybuilt mowers, because it is still under warranty...good luck
Apr 07, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Onda generator engine starts and then 3 or 4 seconds later stall
Oil pressure switch. Check it and make sure oil level is correct. The oil switch will cause this
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 31, 2009 | Electrical Supplies
Generator Starts But wont stay running after a few mins.
check the oil level most products like this have a safety valve.
Jul 15, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
Long storeage of troybuilt gen
i have had my generator for 6 years. i use fuel stabilizer and do as you did in shutting it down. I do not drain my fuel but it doesnt hurt. I would question putting anything in the engine that could in time cause problems. I use synthetic oil, this should coat all internal parts well enough to not need extra oil. I do start the engine a few times a year and let it run 5 mins. or so. I live in SW La so having a generator that doesnt work during hurricane season is not a good idea. The steps you are taking should keep your engine fine. It is a good idea to run it and use the power every now and then. This keeps the magnets in the generator in good shape.
Oct 12, 2008 | Electrical Supplies
Briggs & Stratton 20-Amp Extenda Panel  - 1659 Logo
98 people viewed this question
Top Briggs Electrical Supplies Experts
John Trevino
jdthefixer
rlev_7
Level 1 Expert
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
