Question about Valor ITS-700W
Want to set clock - Valor ITS-700W
How to set clock ON GE- JB860SJ1SS
RANGE SETTING THE CLOCK NON-ELECTRONIC CLOCKS: To set the clock:
  1. Push the center knob in.
  2. Turn the clock hands to the correct time. If the Minute Timer pointer should also move, let the knob out, and turn the Timer pointer to OFF.
DIGITAL CLOCKS: To set the clock:
  1. Push in the center knob of the Minute Timer.
  2. Turn knob in either direction to set the Digital Clock numerals to the correct time
ELECTRONIC CLOCKS: To set the clock (models with Clock or Set Clock pad):
  1. Press the Clock pad
  2. Press the + / - pads or number pads (depending on model) to set the time.
  3. Touch the Start pad. The time of day will show in the display.
To set the clock (models without Clock or Set Clock pad):
  1. Press and hold the + and - pads for 3 seconds.
  2. Press the + / - pads to set the time.
Nov 05, 2017 | Audio Players & Recorders
Setting clock on GE electric stove
Range Setting the Clock and Timer Non-Electronic Clocks: To set the clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
Digital Clocks: To set the clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
Electronic Clocks: To set the clock touch the Clock pad. Touch the number pads. Touch the number pads. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
Nov 06, 2016 | GE Kitchen Ranges
How do I set the clock
On some Galanz models setting the clock is a bit unusual.
You have to press the clock/preset button once then press pause/clear. Now it is in Clock mode setting and you can set the hour then press clock/preset again to set the minutes then press once more clock/prest to finish the operation.
Mar 27, 2013 | Microwave Ovens
How to set clock in pioneer deh4000ub
here is the link for your manual:
http://www.pioneer.co.uk/uk/support/manuals/DEH-4000UB/index.html
Setting the clock
This function is available only for DEH-4000UB.
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Turning the off clock
display on or off
If the off clock display is turned on, the clock
appears on the display when the sources are
off.
OFF CLOCK.
2 Press MULTI-CONTROL to turn the off
clock display on.
# To turn the off clock display
Cheers!
Feb 07, 2010 | Pioneer DEH-P4000UB CD Player
I cant set the clock on my pioneer deh 21001b cd player
Adjusting initial settings
1 Press SRC/OFF and hold until the unit
turns off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select one of
the initial settings.
CLOCK SET (clock)—AUX (auxiliary input)
# To return to the previous display, press
DISP/BACK/SCRL.
# To return to the main menu, press and hold
DISP/BACK/SCRL.
# To cancel initial settings, press BAND/ESC.
Setting the clock
CLOCK SET in the initial setting menu.
Refer to Adjusting initial settings on this page.
setting mode.
Hour—Minute
right.
Sep 26, 2009 | Pioneer DEH-2100 CD Player
CANNOT RESET CLOCK
1) Press SOURCE and hold it until the unit turns off.
2) Press AUDIO and hold until clock appears in the display.
3) Press AUDIO again to display the setting u need to configure.
- when u found clock, press < or > to select the segment of the clock display you wish to set.
- press /\ or \/ to set the clock.
- press BAND or hold AUDIO when finish.
YBC (/\)
Apr 27, 2009 | Car Audio & Video
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
To check the clock, press CLOCK.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
How to set a deh-p4000ub car radios clock
try this:
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
1 Press SOURCE and hold until the unit
turns off.
2 Press SOURCE and hold until function
name appears in the display.
3 Press FUNCTION to select one of the initial
settings.
Press FUNCTION repeatedly to switch between
the following settings:
Clock—AUX (auxiliary input)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down SOURCE until the unit turns off.
Setting the clock
1 Press FUNCTION to select clock.
2 Press c or d to select the segment of
Pressing c or d will select one segment of the
clock display:
Hour—Minute
3 Press a or b to set the clock.
Turning the clock display on or off
You can turn the clock display on or off.
! Even when the sources are off, the clock
display appears on the display.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Aug 05, 2008 | Pioneer Audio Players & Recorders
Have Pioneer DEH 1900MP CD receiver. Do not know how to set time. Have no amnual. Also information on the remote control
It's on page 12 of the manual. Here you go:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/372010482DEH1900MPOperationManual1030.pdf
from this unit.
turns off.
settings.
particular setting.
Setting the clock
clock display:
Hour—Minute
on or off.
on or off.
Operating this unit
12 En
Aug 05, 2008 | Car Audio & Video
Valor ITS-700W Logo
21 people viewed this question
Top Valor Car Audio & Video Experts
David Payne
David Payne
hoyzee1
Tom Chichester
Are you a Valor Car Audio and Video Expert? Answer questions, earn points and help others
