Question about LeapFrog ClickStart Educational Software: Scout Puppy Pals
Black and white and lines go across the screen
When I plug in the Leap Frog to the TV the sreen on the TV turns black and white, fuzzy and lines go acrsoss the TV and the lines Scroll down. I tried a different TV and on that one only turned black and White and Fuzzy.
I checked all the wires and everyting looks attached.
SOURCE:
  • 72 Answers
SOURCE: Little Leaps DVD Code
Apex- 003
029
103
104
106
Phillips-002
004
022
027
036
066
114
115
122
123
Posted on Mar 21, 2009
  • 10865 Answers
SOURCE: My daughter's Leap Frog Tag reader pen will simply
Hello I will try to help you. If the pen was working up until the batteries died then the problem logically would be solved by putting in new batteries. That said, remove the "new" batteries and install them in another device to be sure that they are good. Some new batteries die in the package before being used.
Then make sure you are putting the batteries in correctly, pay attention to the + and -.
Finally, you can clean the ends of the battery chamber by using a pencil eraser and rubbing it on the metal contacts.
Let me know if one of these things fixes your problem as I have additional ideas.
Posted on Jun 08, 2009
SOURCE: little leap frog baby
Quick Set up Code is 01.
The Manual Code is 000, 001, 006, 013, 014, 052, 068, 075, 111, 112, 113, 117, 118, 140, & 141.
Posted on Jun 26, 2009
  • 2976 Answers
SOURCE: Leap frog globe pen no longer works
Either the wire is broken inside the insulation, or the batteries are dead.
Posted on Sep 17, 2009
jyackle5
  • 8197 Answers
SOURCE: manual for zippity leap frog.
You can get the manual on the link below.
http://www.leapfrog.com/etc/medialib/leapfrog/support0/parent_guides.Par.51415.File.dat/10250_Zippity_Parent_Guide.pdf
http://www.leapfrog.com/en/pages/support/top_product_list/Zippity.html
Good Luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 18, 2010
Screen keeps going black then grey and white lines start to come across the screen.
This is not the fault with remote control. It is with your TV itself. Contact any service technician.
Gopakumar Gopalan Google
Mar 24, 2014 | Televison & Video
My LCDTV has a problem, Model number is 6626LCT, Now on to the problem, While doing yearly cleaning on my tv as normal, after i plugged it in it was normal for 40 seconds, It flickered and the screen went...
Only suggestion is if set was plugged in when you did what you did--unplug it and any box or receiver plugged in and wait a while--plug back and let the equipment try to reboot.
Jun 06, 2012 | Sylvania Televison & Video
Screen turn green tv is 57 rear projection
Good Day,
It appears that you may have a green drive issue. Try adjusting the Sreen Control it is located in the front of TV.
1) Remove Speaker Grill (it just pulls off) start at one end, 2) Remove cover (5-6 screws), 3) Adjust control. The control is located on lower right side towards bottom. A small black device with 2 rolls of controls, adjust the center control on bottom row counter clock wise, until you get a black and white picture.(adjust with color control to min).
If this does not work you light bulb (CRT) is bad about a $750.00 repair.
Good Luck, Big Irish.
Dec 07, 2009 | Toshiba 57H83 57" Rear Projection HDTV
Rca 32 inch tv
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
time to buy a new tv
Sep 04, 2009 | Sanyo DS24205 24" TV
Black Screen with white line across the
the vertical IC most likely has failed
Jul 19, 2009 | Televison & Video
How do I install the leap frog by Terk?
to install the leap frog it has to be installed directly into the tv. cannot plug leap frog into directv satellite box, will not work. hope this helps! your question is a little unclear
Mar 31, 2009 | Terk LeapFrog LF30S
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
LeapFrog ClickStart Educational Software: Scout Puppy Pals Logo
79 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
pramey3
Level 1 Expert
Keith Koene
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
