Question about GE Spacemaker JVM1640SJ Microwave Oven
Need to remove GE microwave JVM152J
Seems connected to back wall, but I cannot determine where the screws are, if any. Doesn't seem to slide.
  • rick_olson Jan 03, 2009
    This microwave is mounted above a cooktop. I get move the bottom away from the wall, but it's connected at the top. Is there a mounting bracket with a lip a few inches down from the top?
    Sergeant:
    Champion:
  • 239 Answers
First remove the two screws inside cabinet right abve microwave then let it come down from front an then lift back up itt will com off
Posted on Jan 03, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, try raising the microwave a little before pulling out.
Good luck and Thank you for using FixYa.
    Sergeant:
    Champion:
  • 201 Answers
Remove the louvered cover across the top of the unit and you will see the two Phillips screws(one on each side) that hold the unit fast to the cabinet. Once removed the unit tilts down and unhooks from the cabinet frame. Have an extra pair of hands to control the tilting and lifting for the unhooking. Hpes this help
  • 15,935 Answers
Check for 4 bolts in bottom of cabinet above
once those are removed, it will come out.
There is a bracket at the rear. Some microwaved need a little bump UP to remove out of the bracket.
    Genius:
  • 1,036 Answers
Most are fixed through screws on the base - in the feet area, and sit on a heavy L bracket connected to he wall.
Try looking underneath.
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
Remove mounted GE Spacemaker Microwave JVM140K
There should be 2-3 screws thru the floor of the cabinet above the m/w that secure it in the front. Once those are removed the m/w will slide straight out on rails mounted to the wall plate.
Dec 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
There seems to be no power. No clock. no nothing. It was working fine and then jut stopped. Circuit is not tripped. I tried unplugging and plugging again.
most likely you will have to remove the louvers or trim above the cooking cavity to get to the fuse, look for screws holding the trim/louvers on, if no screws are apparent, the piece may slide to the left or right and pop off.
Unplug your microwave. Although it might seem like no electrical current could possibly be running through your appliance, it could still have stored electrical current somewhere in the system. Be safe rather than sorry and unplug it before you begin.
  • 2
    Find the wiring diagram for your model of GE microwave. You can contact GE directly to get this if you cannot locate your owner's manual. Note the fuse locations and get a screwdriver. Some GE fuses are located under the louvers, while others are located in the door.
  • 3
    Open up the microwave and locate the blown fuse. Sometimes you cannot determine a blown fuse by visual inspection so check it with a multimeter for continuity across the terminals.
  • 4
    Replace the blown fuse. Go to your local hardware store and pick up a matching fuse. Make sure you check the model numbers of the fuse as well to be sure you get the right component. Install the new fuse and put everything back together.
  • 5
    Check the continuity of the circuit if you continue to have power problems. If you have a problem with continuity in the circuit, then you may have a bigger problem than just a blown fuse. Sometimes a power surge will fry a GE microwave's circuit board, which you will need to replace.
  • Dec 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    I want to remove/replace a 2000 GE JVM1640WB microwave and don't know how to access the mounting/securing screws to allow me to remove the old unit. Are they behind the top grill, which looks like it's...
    I have found and provided a link installation instructions for your existing model. The front is held in place by two screws through the cabinet above into the top of the micro and the back is supported by a wall bracket. A new microhood will fit into the space, but will install a little differently. link to instructions:
    http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003675895.PDF
    Dec 25, 2009 | Microwave Ovens
    I have ge under cabinet microwave model jvm1331 004 that i need to remove. what holds the unit in place?
    Look in the cabinet above the microwave. You should see a vent if it is vented outside. You will need to remove the vent. Then look in the same area to find two screws that will need to be removed. Disconnect the power cord and have someone hold the bottom of the unit and remove the screws. It will fall at this point so hold it good. With the screws out and vent removed you will be able to let the front of the microwave down a little. This will allow you to now lift the back to release it from the channel hook in rear. Then you will see the mount plate on the wall. It should have screws securing it to the wall on stud locations. remove these screws and remove the wall plate. Hope this helps. Good luck.
    Jul 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    How do I remove an old wall mounted Microwave.
    I just removed mine this morning and was having the same problem, though mine did have the screws above going into the unit. You may have to pop the front vent cover off to locate the screws going to the wall bracket, if so remove those. Also,there are 2 tabs on the bottom of the wall bracket that the back bottom edge of the microwave slip into, keeping the microwave from being pulled forward. Tilt the microwave slightly forward and push the bottom back edge of the microwave up to clear the tabs. Hope this helps.
    Mar 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    HOW DO YOU REMOVE AN OVER THE STOVE GE MICROWAVE ?
    open doors of your cabinet above the microwave, look carefully toward the front you will see two screws one on either side, remove theses screws while a helper holds bottom of microwave, after screws are removed lift up on rear of microwave it will slide up and out of a rear clip mounted on the back wall. remove wall bracket and job is complete. oh yeah unplug microwave, or turn off circuitbreaker first. easy as 1, 2, 3. hope this helps.
    Nov 05, 2008 | Microwave Ovens
    1985 GE Microwave Spacesaver Uninstall
    A possible solution:
    I was facing the same problem with my (1998?) GE JVM48006. In this models case, the microwave was housed in a support cabinet that was fastened to the wall behind. First, I removed the phillips head screws behind the louvered vent above the microwave. Then, I removed the screws of the slanted bottom panel that give access to servicing the stove top lights (underneath the unit) which were integrated into the support cabinet (separate from the microwave itself). On the right side was an electrical wire harness hidden behind a cover that had to be unplugged (similar to a car wiring harness). Then, I removed (4) 5.1/2 inch hex head bolts that secured the unit through the cabinet above. Now I was able to slide the microwave out towards the front (with some rocking back and forth). All that was left then was to remove the support housing (fastened to the back wall).
    Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Removing Old Built-In Microwave
    You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
    First make sure the Power Cord is UN-PLUGGED from the wall.
    1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
    2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
    3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
    GOOD LUCK!!
    Jan 31, 2008 | Microwave Ovens
    Removal
    There are 3 mounting screws that anchor the microwave to the cabinet above it and a bracket on the wall behind it. Once you remove the mounting screws from the top, pull the oven straight out from the front and it will slide off the wall bracket.
    Nov 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
    GE Spacemaker JVM1640SJ Microwave Oven Logo
    149 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    D. E. Hev
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
