Question about Vtech V.Smile TV Learning System
Various Smartridges stopped working
We've had a the Vtech Smile for a while and all of the sudden some of the Smartridge games have stopped working (about 5 of the 10 we have). We've turned the cartridges around, unplugged the machine, mumbled incantations, and did the mystical "make the game work" dance. So far. . . nothing. Any ideas?
  • 8,596 Answers
You may need to inspect the inside of the cartridge slot for dust/dirt - swab it with a tiny amount of cleaning alcohol and see if you get better results.
Posted on Jan 04, 2009
My Vtech vsmile didn't work a the time I push the power button never happend my batterie are test and are brand new an i try to connect direct with a power supply never work again
There are problems with the power adaptors. Did you use a VSmile power adaptor, or something that just seemed to fit the unit? Using the wrong power adaptor (like unknowingly plugging a Leapfrog power adaptor) into the unit can cause damage to the Vsmile Board.
Push and hold the power (smile) button for one minute, then install fresh batteries. if it powers back up, then try:
Dirty Smartridges (the game cartridges) are to blame for about 90% of VTech Vsmile products not powering up.
In some instances, the cartridge slot on the unit itself can become damaged and will cause no power up.
Kids (of all ages) can dirty a smartridge in less than a second, and render the whole system dead.
Sep 30, 2010 | Vtech V.Smile TV Learning System
Our v tech v smile system won't stay in the on position
Remove all Smartridges, controllers, adapter or batteries.
Examine the Smartridge slot for loose objects, Blow into it to
remove dust or debris.
Pull back the plastic sleeve on the Smartridge and clean both sides
of the metal contact with alcohol and a q-tip.
Insert the Smartridge into the Smartridge slot and remove quickly
twice without turning on the V.Smile unit.
See if that will help.
Jun 29, 2010 | Vtech V.Smile TV Learning System
We have a vtech vsmile and it will not work correctly!!! it will turn on with no game in but as soon as you put a game in to play...it goes blank and will not play the game. It won't even let you turn it...
We had the same problem. Put alcohol on a q-tip. Pull back the plastic sleeve on the Smartridge (game) and clean both sides
of the metal contact. Insert the Smartridge into the Smartridge slot and remove quickly. Then insert Smatrige and turn on the power.
I did this to all of the games and now it works like new!
Hope this helps!
Jul 02, 2010 | Vtech V.Smile Pocket
I plugged in my vsmile and there is power but there is nothing coming on the tv screen
Pull back the plastic sleeve on the Smartridge and clean both sides of the metal contact with alcohol and a q-tip.
Insert the Smartridge into the Smartridge slot and remove quickly wice without turning on the V.Smile unit.
Then try to see if that fixes the problem.
Jun 26, 2010 | Vtech V.Smile TV Learning System
Not playing on the screen. green light is lit,
of the metal contact with alcohol and a cotton swab.
May 15, 2010 | Vtech V.Smile TV Learning System
Vsmile shuts down when cartridge inserted
Insert the Smartridge into the Smartridge slot and remove quickly twice without turning on the V.Smile unit.
This should fix the problem.
Mar 28, 2010 | Vtech V.Smile TV Learning System
My childs vsmile switched on but then switched itselfs off,changed the batteries & it worked for a few seconds then switched off again & will not switch on.
Try this: press and hold the ON button for 45+ seconds WITHOUT the batteries. Then put new batteries in. It worked for me. I bought a second unit at the thrift store and thought it was broken until I tried that. Works just fine now.
Jan 06, 2010 | Vtech V.Smile TV Learning System
Need to clean games and games keep freezing on my son
You can use a pencil eraser to clean the contacts on the game cartridge
May 07, 2009 | Vtech V.Smile Smartridge: Dora's Fix-It...
Won't work with smartridge
Make sure the V.Smile is turned off before inserting the cartridge. If it is still acting funny:
Things you can try to get the V.Smile TV Learning System to work:
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Dec 29, 2008 | Vtech V.Smile TV Learning System
Vtech V.Smile TV Learning System Logo
145 people viewed this question
Top Vtech Toys Experts
Stephan Reichert
Stephan Reichert
Are you a Vtech Toy Expert? Answer questions, earn points and help others
