Question about KitchenAid KFXS25RYMS - KitchenAidR 35 5/8-Inch, 25.0 Cu. Ft. Standa
Mildew smell from new KFXS25RYMS refrigerator
New refrigerator 8/2012. French door with pull out freezer and middle produce door. Strong mildew odor when the compressor /fan running. Happens when nothing in the refrigerator.
  • 958 Answers
SOURCE: Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Posted on Feb 19, 2008
bestdarngood
  • 3037 Answers
SOURCE: chemical odor...
try putting crumpled newspaper in it daily to get rid of the smell, the coolant if leaking should not cause any horrible smell, Freon they use today has very little smell to it. Frost free units have heaters and fans in them to keep them frost free. It could be that a fan quit and the heater overheated something around it."
Let me know if this helps, good luck
Posted on Mar 29, 2008
  • 27 Answers
SOURCE: Kitchaid Superba KSRG25 not cooling freezer or
either stuck in defrost or compressor failure or loss of gas
Posted on Jul 29, 2009
  • 5 Answers
SOURCE: Surface rust on GE Profile Stainless Steel Refrigerator
I would try a product called Evapo-Rust! Evapo-Rust will remove the rust without damaging the stainless steel finish on your refrigerator. After you remove the rust you will then want to apply a rust inhibitor to keep it from coming back. You can go to a website call http://www.rustremover.biz to learn more about Evapo-Rust. You will also find that they sell a water based rust inhibitor that will work to keep the rust from flashing back for up to 6-months.
Posted on Aug 02, 2009
SOURCE: burned plastic part on refrigerator compressor
side by side refrigerator freezer, smelled melting plastic, found a plastic box connected to the compressor burned. What is this and how much does it cost to replace?
Posted on Dec 23, 2009
We have a very foul in our mobile home, and we think it is coming from our empire heater! is there anything we can do to fix this odor
Oder doesn't seem to be electrical smell or you would know a house fire may occur. We normally know the electrical smell I'm worrying you about, and if it is that, do not use it and call a professional! It may be mildew in the unit or in the ductwork. Mildew is quit common, mold is not. No one LEGALLY can tell you it's mold unleased certified by you state or province. Mildew can grow anywhere we have a warm surface that comes in contact with a cold surface. This means uninsulated ductwork, or aged ductwork. The unit itself can also produce some mildew due to lack of maintenance. And also, water can get inside the duct for many reasons if you have cooling. If water is trapped it can produce "growing" stuff and a smell. Varmints can also cause this, either by dying inside the unit/duct or by leaving their droppings, to say it nicely. Temporary fix is what we call in Texas a Odor Cake. These are sold at the HVAC parts houses. Come in a little Tupperware style cup, and are mainly used for fire, smoke, and mildew damage to a structure. You just set em inside the airflow and the help, but don't solve the issue. If mildew is present inside the unit, have a tech out to inspect/clean. And a ultraviolet light may be needed to help control the growth. Internet U.V. Light for HVAC to study on them. Hope this helps!
Sep 04, 2017 | Empire Heating & Cooling
Ice smells like mildew! We purchased the refrigerator/freezer new 6 months ago. It does not seem to be a problem caused by other foods in the freezer. Model number: FFTR2126LW
Mildew smell in your ice is caused by one of three things. 1. Old, dirty, clogged water filter 2. Bad water quality from your house water supply 3. Ice that has not been used and sits in the bucket for time can become stale tasting.
Sep 01, 2011 | Frigidaire FFTR2126LW Top Freezer...
Water taste and smells like mildew
Hi and welcome to FixYa. I am Kelly.
How about the house tap water same odor and taste or just the fridge?
If it is just the Fridge I am assuming your unit has been around for a while.
If you have a mildew build up in the plastic tubing of your ref it can be a tedious cleaning procedure to get it all out of the system The stuff ends up sticking to all of the plastic tubing inside the unit and is so hard to get rid of. What you can do is have all of the plastic lines changed out in the Refridgerator from the water valve outlet to the the water in door and icemaker. It is just time consuming to do it.
Water supply to unit off for the steps below.
You can try using a small baster (I use a hair dye applicator bottle) and a bleached water mix that is not too strong. I would recommend that you start AFTER the water valve in the bottom of the unit. You have got to be able to introdue enough pressure through the system so that when the water in door switch is activate that the bleached mixture will flow out of the spout. You will have to introduce the water until you can smell it in the water you get from the glass you used to catch the water. Then let it stand for an hour. Re-intorduce the same amount of bleached water as before and wait another hour. After the second mixed water bleaching reconnect the water supply and purge it at the water in door outlet with a glass.
Probably sounds a bit much but this is from experience and believe me it does take lots of time.
I am sure this is not what you were expecting but it really is the only way your going to rid yourself of the bad smelling and tasting water CURSE.
Thanks for using FixYa!
Kelly
Feb 18, 2010 | Pds GE Profile Bottom-Freezer Drawer...
New freezer. 15 days old. mildew smell in the
There is a curing process for the foam used to insulate these. It can give off a pungent odor until it is fully cured. Only experienced it a couple times in the last 20 years. eric
Jul 08, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Last few weeks there is a foul odor coming from the washer
How old of a unit? The new high energy effeciency washers are known for their "odors" due to the fact they dont drain out all water and it can mildew inside. Some solutions...leave door ajar after wash cycles , water will evaporate, there is products you can add every so many loads, one product being "affresh" ,,,some other people will run strong bleach load every so many loads it will kill mildew. These washeres have been out for years in Europe and they have same problems, its just inherent with product
May 21, 2009 | GE WSXH208A Front Load Washer
Odor coming from front door jams after shutting car door
I have the same problem in my 2011 sonata and i finally figured out where its coming from, its inside the doors! Put your window down and then smell the top of the door where the window slides down in...its so gross....its been making me sick to my stomach!
Apr 11, 2009 | 2002 Dodge Durango
Mildew smell coming from bottom front of refridgerator.
Carefully empty the drain pan under the fridge and empty it.
Then clean with a bleach and water solution.
Feb 22, 2009 | Hotpoint HTM17BBSSA Top Freezer...
Odor in front loading duet washing machine
The following link explains how to minimize wash tub odor, and what generally can cause it:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
I personally own one of these washers and have followed this same regiment since I purchased it new 9 years ago. I have never had a mildew or odor problem. Consumers that are not in the habit of using hot water very often will also run into odor and mildew problems, because detergent alone does not always kill bacteria. It is recommended that you run a "Clean Cycle" from time to time, to sanitize. Some newer models have a clean cycle added on the control panel.
NOTE: It is normal to have residual water in the drain lines and in the drain pump. If you need to clean, or check the drain pump, please follow the advice in this next link:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Debris caught in the drain pump reservoir can often cause some unwanted odors.
If the rubber door bellow develops mildew and mold, use a non abrasive pad (the little green pads are considered non-abrasive) and scrub the rubber with bleach diluted with water (50/50 mix). This will often kill and remove unwanted mold and mildew. If the door bellow becomes embedded with mold or mildew, it may have to be replaced in order to get rid of it.
If you establish and maintain a diligent routine, these washers will not mold or smell. Often what seems to be a dream appliance that is supposed to make your life easier, may actually require more attention in order to maintain it properly.
If you have questions or comments, please let me know. I hope this helps you.
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mildew Smell
Let me add...I was having a problem with the washer draining. I followed these instructions http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet from this website. I found two socks and they were extremely mildewed and the junk that came out smelled. It may be worth it to check and see if there is something in the pump. It wasn't very hard to do. Let me reiterate something that was mentioned...if your washer is not in a garage or somewhere you don't mind a good bit of smelly water leaking out...definitely use a shop vac first.
Feb 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
KitchenAid KFXS25RYMS - KitchenAidR 35 5/8-Inch, 25.0 Cu. Ft. Standa Logo
32 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
