Question about Blaupunkt IDC-A09 5-Disc CD Changer
How do i eject Cd in 2004 peugeot 307 estate
Can some one tell me how to eject the CD. I cant find the eject button
    Master:
  • 444 Answers
Use a pair of pliars to eject it,LOL:
Posted on Oct 28, 2012
SOURCE: Cd changer will not work
I had the same problem with my 2002 307SW.
I read on another forum to switch ignition off, remove CD changer from dash and disconnect. It then told me to remove the lid from the case unscrewing the screws marke 1 to 5 then remove the Cd's. The only problem with this is you need a special size 'star' driver bit which i did not have at home and could not unscrew them. What i did was to use a terminal screwdriver in the 2 larger screws that fasten the front plastic cover on the unit. Once I had done that I could remove the CD's.
I then connected the changer back up and inserted it back into the dash. I then powered the radio back up anf loaded a CD and the problem had gone away so I loaded the 5 CD slots and everything works fine now.
Posted on Jan 23, 2008
Warf135
  • 137 Answers
SOURCE: Peugeot 307 Blaupankt CD Changer IDC-A09
Hi, I know this is an old post, but I'll reply, so that other readers may get the benefit of my answer.
2004 was the year that Peugeot/Citroen changed from VAN bus to CAN bus wiring on their stereo's. If your car is before or early 2004 you will need the IDC-A09 blaupunkt in dash changer, which should just plug in and work straight away.
However, If your car is later 2004 onwards you will need the IDC-A04 Blaupunkt changer which will plug in and power up, but will not work properly untill you go to a peugeot dealer and they hook up some diagnostic software to tell the car a changer has been added. Both the IDC-A04 and A09 changers look identical.
I would say that you got the wrong changer, as the IDC-A09 changers in pre/early 2004 should just plug in and work.
Remember: Pre 2004 cars need IDC-A09 (plug and play) and Post 2004 cars need IDC-A04 changer (get pug dealer to reprogram cars computer)...its a costly mistake if you bought the wrong one!
Posted on Apr 05, 2010
Eagleeyes
  • 199 Answers
SOURCE: 307 5 disc cd changer wont play or eject cd,s 2003 307.
hi there is a repair kit for this unit.
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html
mark
Posted on Jul 21, 2008
SOURCE: 5 cd changer on a
cd changer off set common fault had it happen three times due to buttons being pressed to quick take changer out remove leads for a minute replace them turn on ignition should reset if not cd drive wiil need to be relined see dealer repaired one but really tricki
Posted on Dec 19, 2008
SOURCE: peugeot 307 04 plate
just disconect leads on cd changer should reset
Why has the cd player has stopped working,it only goes from tape to radio and back again.
Do you have a digital display? Are there any lights on the player to tell you it is playing? Have you tried to open the CD drawer? There might be a button on it, so you can put a CD in it. I suggest you try to put a CD in it, because it might play automatically when you insert a disc. If that doesn't work, come back and let us know.
Apr 27, 2014 | 2004 Peugeot 307 1.6
Blaupunkt cd5 changer does not have an eject button how do i retrieve my cd's?
If it has a magazine, you'll have to remove it. Some magazines push in to latch and you can push to unlatch and pop out
Sep 18, 2012 | Blaupunkt IDC-A09 5-Disc CD Changer
How do i eject a cd from a peugeot 307cc
cd will not eject from puegoet 307 cc coupe
Sep 05, 2010 | Car Audio & Video
Car CD player won't load Cd's - Peugeot 306
Yeah, the sensor that detects the presence of the disc is knackered - probably broken off. The eject will always eject the disc. Just press the button with no disc and you will hear it try. Look at ebay for a replacement - theyre dirt cheap!
Jul 13, 2009 | 2006 Peugeot 505
Peugeot 307
having same problem. faulty after disconection of battery
Jun 03, 2009 | Blaupunkt Car Audio & Video
Oct 28, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 cd player wont load or eject cd five red lights flashing down right hand side of it ?
First things first:
1) deffective rotor for the onboard devide.
2) time to change your burner.
3) RMS the burner if warranty is available, for another new.
good Luck
Mar 07, 2008 | Computers & Internet
5 cd incar stereo
Hi in most cases the mod kit will fix the problem. other wise its a new unit as Blaupunkt only supply the mod kit or a new mech...
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html?osCsid=b7ce3a0b7b492ec864e29579ad046166
Regards
Mark
Dec 13, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC-A09 5-Disc CD Changer Logo
916 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
