My Epson R220 printer is making really loud noises. It sounds like the paper roller. this started happening last night after it sucked in too many pieces of paper. I got the paper out but it still wo
    Problem Solver:
  • 12 Answers
Need open printer maybe gear disaligned only
Posted on Oct 29, 2012
  • 300 Answers
SOURCE: Printer will not grab paper
You may need to obtain the HP Paper Feed Cleaning Kit from Customer Service by contacting them here. While your speaking with them you may want to ask about any issue that have came up with your particular model because I have read they have replaced some models that were even out of warranty.
To use:
It seems that by what Im reading, this is mostly caused by a dried out roller (especially if they are grey so you also may have some other options:
NOTE: These options may void warranty.
  • You may try applying a thin layer of vaseline on the rollers that pull paper. You can usually access these rollers from a door at the back of your printer. This should also soften the rubber. I would suggest running a sheet of plain paper through a couple times to clean off any excess.
  • You can try the Rubber Rejuvenator listed here.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Nov 19, 2008
1861bohdan
  • 3 Answers
SOURCE: IBM 9068-A01 printer loads paper crooked
I have 20 IBM 9068 at work and some of those problems I had also. The noice can come from Ribbon drive assembly. This part has plastic weels inside and tooth on it is droken. You have to open printer and check that part. If you need more info you can e-mail me at 1861@att.net
Posted on Apr 03, 2009
SOURCE: printer will not feed card stock
Sorry. I have not solved this problem and I cannot afford to pay anything for your services.
Posted on May 02, 2009
SOURCE: keeps saying no paper Makes loud clicking noise
The clicking sounds seems to be made by the small gears on the side of the tray. When you move the gears, it should push a plate beneath the paper upwards, and the paper with it, allowing the paper to be feed.
I'm not sure what I did to fix it. I removed the paper and cleaned both feeding rectangles (to the front of the tray -- nearest you). One is underneath the paper and the other is in the front, center.
I then made sure that, when I move the biggest gear (the one that isn't round) that the paper moves upwards.
Posted on Sep 01, 2009
SOURCE: epson sx600fw displaying paperjam, No sign of any jam
did it happen after physically cleaning/flushing the head? I've had this a couple of times and clearly no jam. I removed the cartridges again, ran the rollers backwards and forwards a few times using the white gears, and powered up .... it recognises no cartridge present so went through the replacement again and the fault then clears. I think the s/w gets its knickers in a twist Printer is a heap of poo, and clearly designed to use asmuch ink as possible as it needs cleaning far too often. Wasted too much time on gettingit to print
Posted on Apr 20, 2010
When I am printing, there is a loud noise. Like something is not rotating correctly. Everything prints good, but that noise is really loud. It seems to happen when it feeds paper.
Hello there,
If there is a loud and buzzing noise inside it, the encoder strip, or the one that guides teh cartridge must be dirty. this causes buzzing sounds and mis alignment.
another is the rollers having too much paper residue in it.
i would recommend for you to clean the rollers with a lint free cloth and some water (just to dampen it)
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
Mar 16, 2011 | HP DeskJet F4280 All In One Printer InkJet
My printer will not grab the paper
I have an R2400 and it is very finicky about grabbing the paper. I have to hand feed sheets of thick matte paper one at a time with just the right amount of pressure and even then sometimes it takes two tries. Make sure you keep the rollers very clean.
May 04, 2010 | Epson Stylus Photo R220 InkJet Printer
I'm having trouble printing on cds (they won't load) with my epson stylus photo r220. I've followed the directions, lined the tray up properly. Set the settings for cd/dvd. Tried old and new software.
Depends how long you have had your printer, epson are well know for the rollers that takes the paper in getting worn, and so does the cd/dvd tray, eventually you have to push the tray in by hand to get the thing started, somtimes changing the disk tray helps, if youve got a spare one,
Dec 21, 2009 | Epson Stylus Photo R220 InkJet Printer
Hi! The paper won't feed to print..what am I doing wrong please? We have tried new paper' older'less'and more' the roller part just will not grab!
Check paper feed machism.Ensure that the feed roller is rotating when you command print.See also that there is no obstraction in the paper path.Sometimes there could be a foreign pacticle.Also try to clean feed roller so that there is friction between paper and roller.
Jul 28, 2009 | Epson Stylus Photo R220 InkJet Printer
Printer will not feed card stock
May 01, 2009 | Epson Office Equipment & Supplies
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
Blinking both the ink botton ligths and the botton paper
I just today threw away my R220. If your 2 red lights are going and the power light is off, then your printer has died. It just happened to me. It sucks, but there is no way to fix it.
May 04, 2008 | Epson Stylus Photo R220 InkJet Printer
220 wont pull paper into the printer
It need a technical job make carboard extend to guide ,clip it firmly and bye bye hand guided.
Nov 02, 2007 | Epson Stylus Photo R220 InkJet Printer
Paper Jam with no Jam
You may have overloaded your paper feeder with heavy card stock and caused a very tiny jam that you have not found yet so that it will act oddly as it is. Look right up inside unit with a torch and down back where the paper goes in.Try printing on plain a4 agian, place a small stack in feeder, reset paper guides too. Also could be your paper sensor, fixable under warranty.
Aug 12, 2007 | Epson Stylus Photo R220 InkJet Printer
47 people viewed this question
k24674
