Question about Vizio P50HDTV10A 50 in. Plasma HDTV
My Vizio TV had a strange dark grey line, it was almost in a rectangular shape with rouned edges. We went to rest it the TV, now the TV won't do anything but flash from grey to red to green to bl
    Top Expert:
  • Vizio Master
  • 77,932 Answers
You most likely have a circuit board that has failed. Read about that at the link I will provide. TV Boards Buying Guide
Posted on Jul 01, 2017
  • 19 Answers
SOURCE: Vizio L32 - Picture has turned red and pink.
Posted on Jan 01, 2009
SOURCE: Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...
Posted on Feb 18, 2009
  • 56 Answers
SOURCE: My 37'' Vizio LCD TV has a green haze and lines on the TV
It is a very simple fix. Replace the LVDS cable will fix it. This cable connect the mainboard to the panel.
  • 187 Answers
SOURCE: I have red lines up/down on my Vizio, how can I correct this?
Your sympton need to be more specific, but if what you see is 1 or more tiny lines running from top to bottom of screen (verticaly) and those lines change colors (red/green) depending on the background color on the screen, then your control board need to be replaced, you will need your TV model and product code, both located in the back of the TV next to serial number
Posted on Jun 03, 2009
SOURCE: Vizio LCD Green Pixels
Our Vizio started doing the same thing after only three weeks, except it was also showing green pixel when we watched DVDs.  After checking this site and others and trying all the "tweaking" advised, I finally called Vizio's customer support.  They were extremely polite and tried to help over the phone, but had to send someone to the house to make the repair (anything 40 inches or larger earns a house call). The tech arrived on time and was extremely professional and pleasant -- he had to replace the daughter board and LVDS cables.  So far, so good.
Posted on Jun 29, 2009
How to fix dark spot in middle of screen on led smart tv?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 20, 2015 | Vizio E701i-A3
65" vizio new and my remote won't work
i think that you have to program the remote
Mar 24, 2013 | Vizio VBR220 Blu-Ray Player
My Vizio VX37L HDTV won't turn on. Was watching it one day & it turned off by itself. Replaced power supply with new one with no luck. Orange light comes on but will not turn white.
reset the tv with the tv off, but plugged in hold down the soarce botton on the tv for 5 seconds it should click on and work. if not then there may be curcuit board issues. i found the same tv on the side of the road as somewone was throwing it out, it was leaning aganst their trash can. i brought it home. plugged it in and it went on and inediatly went to the orange vizio light. i rest it and it's been perfect ever since is my comoute monitor now...good luck i hope that fixes it for you..
Nov 25, 2012 | Vizio L37 Television
LCD TV lines
The shop is in business to make money so no free fix--Someone with a good eye who opens the set may see where the water went and then Google the model for a list of boards......several dealers (not Vizio) stock and sell all or most boards in the newer sets.
Nov 04, 2012 | Vizio M420sv 42 Inch Class Edge Lit Razor...
Strange symbol on display screen left hand side coloum. Dark grey shaped like a chip in a windscreen, or a tiny firework type shape. Is this telling me i need to get it fixed?
It is in fact a tiny firework. You have the camera set for "fireworks" mode.. There should be a setting in the menu where you find different "scenes" where you can change it back to Daytime or some other standard setting .
Jun 20, 2011 | Cameras
Brand new 47" "Edge Lit" LED, model MV4(Cant
I believe there may be another setting, it has to do with auto contrast which can make the TV seems to have high contrast ratio but sometime it does not work right, espically on the scene with dark sky with stars, someitme it will will reduce the brightness to make black real black and you can loger see the stars in the scene. I forget the name of this setting, it may be in the user manual. Do you see that in TV HD mode in other movies with a lot of dark scenes?
Dec 01, 2010 | Televison & Video
61" tv quit working
This is a strange problem , but it sounds like you got a broken mirror.take the front (fresnel,lens) off and you`ll find out.
Nov 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
57 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
