Question about Kenmore 24902 Top Load Washer
Water will not drain, we have some exerience working on maytag washers but don't know how to change out the water pump on this unitl. Help.
  • Anonymous Feb 10, 2009
    the water will not pump out the tube.
  • 113 Answers
Maytag or Kenmore? Can you get me a model #? Ill create a tutorial for you to help you replace it. Ill post it here. www.shop.washermd.com Dave
Posted on Jan 14, 2009
Maytag top load washer MAV7200AWW does not drain water sometimes
this is a very good washer, if you are not getting the water out first check the belt , second check the pump the pulley on the pump should turn freely and no play in it back and forth if you notice play in the pump replace it, next how is the washer drain hose , is it in a standpipe or connected with no air gap, if you do not have an air gap you may not be able to pump the water out plus getting sewer water back in (smells) there are products out there to clean the inside of the tub (tide makes one also afresh)
Jul 04, 2017 | Maytag Washing Machines
Maytag bravos washer will not complete cycles
Remove clothes from drum. Siphon out (or wet vac out) visible water in the drum. Blow into drain hose. This back flushes the system. After hearing gurgling and seeing bubbles come up thru the drum, you know its a fairly clear line. Now take your wet vac and siphon out remaining water by connecting it to the drain line using duct tape. The lights will correct themselves and your washer will now work normally. At least this is how I fixed mine without disconnecting anything or making a big mess. Good luck.
Apr 17, 2012 | Maytag Bravos MTW6600T Top Load Washer
What does the code nd stands for on the maytag front load washer?
ND No Drain Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer. 1.Check for pump/drain restriction. 2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
May 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
Pumping water out slowly , takes several spin cycles and resets to empty , changed pump already
It sounds like you have something stuck in the hose coming in or out of the pump, possibly even in the tub where the water drains out. You could also have a kink in the hose. How high is the drain from the floor? Let me know if I can help you out further.
Ken
Mar 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500BWW is giving an "nd" error. The washer will not drain water. All I here is a hum.
Remove water pump, check for thongs, baby socks and sometimes hair pins or even screws can obstruct the water pump.
Simply remove the pump and remove the obstruction that is keeping it from draining.
Let me know how that works out.
http://www.pdxappliance.com
Feb 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer is not draining. I used to be able to reset it and it would work but now it wont start on any setting and is full of water. Is there anything i can try.
If your Maytag washer is not draining, follow these procedures to find out what is the problem.Set the timer in the spin cycle and pull the knob to turn the washer on. If the washer motor doesn't run, check the following parts.
The wall outlet: Make sure that there are about 120 volts present at the wall outlet. Connect a good working hair dryer to see if it works.If the hair dryer works ok, then the problem has to be in the washer. If the hair dryer doesn't work, then look for a blown fuse or tripped circuit breaker.
The lid or door switch : The lid switch is a safety device use to stop the motor from running if the washer door is opened during the agitation or spin cycles. A bad lid switch could be the reason for your washer not draining.
The pump : Check for obstructions inside of the pump and inside of the tub.
Check the pump impeller, the pump belt, check the drain hose for any kinks. Any problems in these parts could be the cause for the Maytag washer not draining.
Lower the drain hose to a bucket to see if the water drains out. If the water won’t drain or just trickles out, most likely there is an obstruction on the pump or inside of the tub and that could cause the washer not draining.
To check the pump, remove the front panel, lean the washer against the wall and bail the water out with a plastic container.
To check the pump, remove the pump belt and turn the pump pulley to make sure that the pulley is turning freely.
Put a couple towels near the pump to catch any water from the pump. Remove the tub to pump hose at and check inside of the pump for any obstruction. If you find an obstruction remove it.
If you don’t find anything, reinstall the hose and remove the hose at the tub, and check for obstructions.
A Maytag washer not draining could be cause simply by a kink drain hose.
You need to make sure that when you replace the pump, you adjust the belts properly.
Jan 29, 2010 | Maytag Washing Machines
My 3 year old Maytag SAV5710AWW top-load washer
It is your water pump. If you don't know what you are doing it could be tough.
Nov 20, 2009 | Maytag SAV5710 Top Load Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
Kenmore 24902 Top Load Washer Logo
63 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
