Question about Kodak EasyShare Z740 Digital Camera
Kodak Z740 Dropped camera, SD card came out. Took 2 more pictures, camera turned off. Replaced batteries, camera comes on for 30 sec. and then turns back off.
  • 2,335 Answers
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Posted on May 01, 2010
I have replaced the battery and memory card, the camera keeps saying I need to format the card, but then it says it is formatting, then gives another message saying the card needs to be formatted....
If the memory card replacement is an SDHC model card the Kodak z740 will not work with it. The memory card has to be a standard SD card of 2 gig size or less to properly function. Take card out and turn on camera. See if you get same error. You should get missing card error but otherwise be able to operate camera controls such as zoom, flash, etc. If that is fine find old card you used and place back in camera... or purchase a standard SD card from Walmart for 10 dollars
Jun 11, 2010 | Kodak EasyShare Z740 Digital Camera
I have pictures on a memory card but when I put it in the camera and turn it on it says there is no card there.
Double check first if you are using a recommended card for your camera Z740. The recommended card for your camera are those SD/MMC card 1gb to 2gb card.
Feb 07, 2010 | Kodak EasyShare Z740 Digital Camera
SDHC Card 4 GB SanDisk will not format. get
The Z740 uses SD cards, not SDHC cards. SDHC cards will physically fit into the card slot but are not compatible. It's a hardware incompatibility, not updatable in firmware. You'll have to stay with 2GB and smaller SD cards.
Feb 06, 2010 | Kodak EasyShare Z740 Digital Camera
Pictures taken can be reviewed in the camera. But,
It's a one way street...from camera to computer...not the other way around. Doing it that way will eventually corrupt the card and sometimes even the camera.
Jan 17, 2010 | Kodak EasyShare Z740 Digital Camera
Kodak Z740 camera sd card formatting problem
Remove the card...turn on the camera and go into the menu...find "reset"...follow the on-screen instructions. Then try to format the card again.
Dec 18, 2009 | Kodak EasyShare Z740 Digital Camera
Koday EasyShare Z740
I have the same problem, its as if the voltage sensor has raised it's cut off point. Originally when the batteries dropped to around 1.4v the camera would cut out, ( normal I would say ) a fresh set would sort it out. Don't use rechargeable batteries as they operate at a lower level and last a far shorter time. My problem I think is terminal and must be a fault on one of the printed circuits, so I bought the Kodak M380, not good quality pictures indoors even though 10.2 mp. Good luck.
Jun 12, 2009 | Kodak EasyShare Z740 Digital Camera
Camera starts, then immediately shuts off
I took out the card.
Erased the photos on the built-in memory (after making sure they were copied to my computer.)
Replaced the card.
Voila!
Took some photos and it turned off when I wanted.
I wonder if it will last, or if it is a fluke.
Try it.
canoesailorjoe@yahoo.com
Jan 17, 2009 | Kodak EasyShare Z740 Digital Camera
Dropped camera, SD card came out. Took 2 more pictures, camera turned off. Replaced batteries, camera turns on and then back off.
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
I hope that helps.
Jan 03, 2009 | Kodak EasyShare Z740 Digital Camera
Kodak Z740 digital camera
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Oct 08, 2008 | Kodak EasyShare Z740 Digital Camera
Kodak Easyshare
Remove the batterty andclean the internal battery contact with an
eraser on the end of a pencil- take a flash light to look inside the compartment to enfure they are bright and clean.
Make sure the battery door and contact srip are a good tight fit
Hold the door down with a finger whilst switching on
Other than that there is little moreyou can do
Jun 28, 2008 | Kodak EasyShare Z740 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
269 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
