Question about Ultimate Sound Cyclone Rake Commercial Pro Leaf and Lawn Vacuum
Tecumseh starts won't idle unless you hold in the choke bulb
    Sergeant:
    Champion:
  • 278 Answers
If you mean your having to pump the primer bulb to keep it running. Then the main jet is plugged.
1. Take jet(bowl nut) off the bottom of the carb
2. spray carb cleaner through all holes. (up to 4)
3. find a hemming pin and break of the sharp tip, run that through all small holes there may be one hidden in the threads.
4. repeat step 2. and dry with a shot of air( air dusting cans are ok).
These steps are for emissionized carbs( no mixture screws )
Posted on Oct 28, 2012
My chainsaw won't run without full choke on and
Fuel starvation, start by replacing the fuel filter in the tank, check the fuel hoses for leaks up to the carb.
May 22, 2013 | Garden
2003 ford focus...won't start unless it's manually choked under the hood
How do you choke a dry intake system
All your doing is reducing air intake during
the starting
That should tell a trained technician something
Have to look at all data with scan tool & go for a road
test & collect data
We can't guess over the internet you need the car
It is all about testing every vehicle component until
something is not as it should be & then correcting that
Mar 07, 2013 | Cars & Trucks
13 hp tecumseh riding mower won't start unless gas is poured into carb. removed the bowl from carb has a wire snap holder float and needle and seat works OK and all passageways seem to be clean
hi
remove the bowl again and get the centre jet out and lok very closely use a jewlers eye piece you wll find a passage that is plugged on the side of the jet look around it you ll see some sign of a hole that is not clear through its pretty small use a welders torch cleanng tool with various size rods use very thin one dont make the hole bigger
Joe
Oct 01, 2012 | Tecumseh Garden
2001 Shadow Sabre, Won't idle with choke off unless giving it some throttle.
Hi, Rickgilbreat and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Starts but won stay running unless with choke Discussion
Won idle without choke
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 23, 2012 | 2001 Honda VT 1100 C2 Shadow Sabre
2007 Yamaha 115 Hp 2 stroke idle problem
Check the idle mixture. Sounds to me like it is too lean.
Mar 20, 2017 | Clymer EvinrudeJohnson Outboard Shop...
Tecumseh TVT691 not getting spark in one cylinder
Did you check for spark of assume that since the spark plug was not dirty that it is not firing. I am leaning toward water in the gas since you have to keep the choke on and it is blowing white smoke. You may want to drain the fuel tank and carburator and put in fresh gas. Good luck!
Dec 30, 2011 | Garden
Toro Model 20041 sputters and stalls out; If I cover the primer bulb the engine will rev up and run. Also the mower won't start unless I clean the spark plug. What do I need to do?
Most likely you'll have to remove the bowl nut, under the carb's bowl. You'll most likely find varnish in the jet, or maybe water. These are some typical jets, Tecumseh. Briggs, similar (baymee Lehigh Valley PA, 2009).
Jun 08, 2011 | Toro Personal Pace CARB Walk Power Mower
2002 Honda VT 1100 C2 Shadow Sabre will not idle without the choke being on
Hi, Esw2035 and the usual suspects are:
Need Help Bike won run choke in
Apr 21, 2010 | 2002 Honda VT 1100 C2 Shadow Sabre
Is my choke on my 97 suzuki vz800. Supposed to be
You should be able to adjust the choke to where it will stay in without holding it by turning the rubber piece behind the choke clockwise towards you until the choke stays out on its own. You can adjust this so the choke automatically adjust as the bike warms.
Hope this helps..
Jeff
Apr 09, 2010 | 1997 Suzuki VZ 800 Marauder
I have an old pressure washer that uses Tecumseh H30 engine. After pumping the choke bulb on the carb, it will crank, run maybe 5 seconds and quit. Thanks
When you get it started, move the choke to the middle, then let it warm up. you might have to move the choke back and forth until it warms up, keep the throttle wide open.
Jun 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Ultimate Sound Cyclone Rake Commercial Pro Leaf and Lawn Vacuum Logo
187 people viewed this question
Top Ultimate Sound Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Ultimate Sound Garden Expert? Answer questions, earn points and help others
