Question about 8 HP GX240 Engine OHV Horizontal Shaft
Honda gx240 generator leaking gas from carb
Leaking gas from carb
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 52 Answers
SOURCE: gas in the oil on my honda generator
Your needle/float is stuck, which will allow fuel to flow though the intake...past the piston..and into the crankcase. If has been awhile since you used it, most likely the gas has gummed up the insides of the carb. Otherwise, you may have had something get into the fuel bowl that is keeping the needle from closing. Best way to solve is to remove and clean the carb. Replace fuel filter if needed also.
Hope this helps
Posted on Mar 11, 2009
  • 10865 Answers
SOURCE: Honda 8HP GX240 willnot start after working fine.
Your carberator has crud, or rust, or glaze in it. The carberator will have to be removed, soaked in cleaner for three hours and then rebuilt using the proper carberator kit from any auto parts store. If you need to hire this done expect to pay about 35 dollars.
Posted on May 20, 2009
  • 48 Answers
SOURCE: Does a GX240 Honda carb have mixing adjustments?
No, the only adjustment on the carb is the high/low idle. Check your engine gaskets for leaks using either water or carb cleaner, preferably carb cleaner. Otherwise just replace the carb, it's around 60 dollars.
Posted on Apr 18, 2010
  • 77 Answers
SOURCE: why is my honda cr 125 2000 year dumping gas out
the float in the carb is getting stuck give it a couple of taps and if that doesnt work u need to take the carb off and clean it
Posted on Aug 08, 2012
jerardi
  • 14162 Answers
SOURCE: my Honda 3000 electric electric start generator / inverter is leaking gas
problem with my generator Honda EU3000
Generator Engine Leaks Gas
AND YOU MIGHT CONSIDER READING THE LINK BELOW AS WELL FOR ADVISE, TIPS AND TRICK.
About those generators Tips and tactics to keep it running through the...
Posted on Jul 23, 2015
Honda generator leaking gas from carborator
that is your fuel drain screw so if you get any water in your carb you can drain it and it was loose thats why gas drained out of it
Dec 16, 2012 | Briggs & Stratton Measuring Tools &...
Coleman 6250 PoweLeaking gas at bottom of motor housing. Can not
The gas is leaking from carb but in the motor not out.
You should check and repair the carb flow valve. The floating unit may be full and bent down.
Jun 20, 2010 | Coleman Powermate Powermate 5000W...
Does a GX240 Honda carb have mixing adjustments? It floods after running for 2-3 minutes then fouls the plug and stops. Thanks, Mike in SC
Apr 11, 2010 | Honda 8 HP Engine
I have a 3000is not starting. Has gas spark oil.
Use fresh gas! Dont just pour some on top of the old...Change it out.
Drain the carb bowl (Honda carbs have a drain screw slightly off-center of the bowl bottom).
The Honda EU3000is uses a vaccuum-operated fuel pump and old gas will ruin it also.
Take the fuel supply line off the carb inlet, direct it in a container and spin the engine over. It should pump a stream that is FULL LINE DIAMETER.
If still no start, take it to an AUTHORIZED Honda Power Equipment Dealership.
Find one here.
Hope this helps.
Sep 27, 2009 | Honda 3000 Watt Portable Generator
May 20, 2009 | Honda 8 HP Engine
Gas in the oil on my honda generator
Hope this helps
Mar 11, 2009 | Honda 3000 Watt Portable Generator
8 HP GX240 Engine OHV Horizontal Shaft Logo
220 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
