Question about SimpleTech 1TB SimpleDrive USB 2.0/eSATA External Hard Drive
Simpledrive 96300-41001-170 solution for 1 tb portable drive and windows xp problems
5 Suggested Answers
orko1978
  • 9 Answers
SOURCE: i formatted the simpledrive 320g portable hard
Does the software perhaps have a hidden attribute? Does anything happen when you depress the one click button on the top of the drive?
Posted on Mar 28, 2009
  • 126 Answers
SOURCE: General questions regarding simpletech simpledrive.
You probably have to initialize and/or format the drive.
Right click my computer and click Manage (assuming windows xp)
Go to disk management
See if you see the drive listed somewhere there. Should show approximately 950gb disk drive
If so right click that drive listed and choose either format, or create partition.
If you create the parttiion, make sure to click quick format, otherwise it will take a long time.
Hope this helps
Posted on Jul 09, 2009
lock123
  • 6831 Answers
SOURCE: My simpletech simpledrive 750gb external drive is
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
bronk50
  • 27725 Answers
SOURCE: SimpleTech SimpleDrive Portable USB 2.0
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on Apr 22, 2011
Error 1920 while installing seagate dashboard on windows xp
This problem is related to RTCHDomain services. If you add admins to the services you can easily solve this problem. To visit the detailed explanation and step by step solution visit the following link - http://www.techyv.com/questions/error-1920-service-%E2%80%98office-software-protection-platform-failed-start
Hope it helps
Apr 05, 2013 | Seagate Backup Plus 1 TB USB 3.0 Portable...
I have a 1 TB SimpleDrive external USB drive. The drive is now making a repeating, beeping noise, slow and methodical, and it is not recognized by either my MAC or my pc. WHat does the beep-beep-beep mean...
the beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active until turned off.
make sure that your RAM is securely seated,
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
when you plugged the external disk drive you got that windows could recognize the USB device change the cable just replace the cable of the hard disk everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 30, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
The hard disk inside it doesn't responds to the controller - hardware failure, the disk has failed.
Nothing can fix that, your unit is truly dead and you need a new one.
I dropped my simpletech by fabrick 1.0 TB (re)drive from about 4 feet, is there any way i can fix it?
No there is no way to repair it just give it to service center for replacement if it is physically not damaged.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 28, 2010 | SimpleTech SimpleDrive Portable USB 2.0...
Have a simpletech portable drive300 gigs-worked fine with windows xp-new computer has windows 7-suddenly cannot access drive anymore-windows 7 sees the drive but says drive is inacessible
Hi ,
This is neo , When did the setup for win XP the file system would be FAT32 . FAT32 is not supported in windows7. You can format the external drive BUT note the files in the drive will be deleted.
Nov 01, 2010 | SimpleTech SimpleDrive 160 GB External USB...
Hope this helps
Jul 09, 2009 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
SimpleDrive 1TB Hard drive not connecting
Windows XP and vista can both automatically detect harddrives, especially with USB connections. The only problem I can see is with the connecting cable. Maybe it is not connected properly. Try another set of cables to see if it solves the problem. Also, try plugging it into another usb port. Also, trying rebooting windows with the harddrive plugged in. Another possibility could be that the device drivers for the drive is corrupted on widows. Go to control panel on windows and look at the device manager and try to manually reinstall the drivers using the disk that came with the harddrive.
Jun 12, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Installation of an usb flash memory 2.0
What operating system are you using? If xp/vista it should do it automatically. If 98 then you will need to get drivers from the makers website ;)
Dec 26, 2007 | SimpleTech SimpleDrive Portable USB 2.0...
SimpleTech 1TB SimpleDrive USB 2.0/eSATA External Hard Drive Logo
318 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
