Question about Honda EG5000 Generator
Model EG5000, one year old;last fire up in March, now it doesn't start. Has fresh gasoline
I'm sure you primed it - or go get a can of ether spray in carburetor
Posted on Oct 28, 2012
  • ariksamson
    ariksamson Oct 28, 2012
    This model doesn't have a primer button, and the carburator is a closed unit, how would one spray ether into it?
2002Chrsler Sebring 2.7 eng new sarter but still won't start up
Do you mean the Starter won't turn over or
Starter turns over but engine won't fire.?
Apr 12, 2014 | 2002 Chrysler Sebring
Tip
Basic lawnmower spring maintenance
Before it gets too late its worth firing up the lawnmower (and any other garden power tools) to make sure they are running well for the coming months. Here are a few basic tips to make sure it will be worry free for the summer.<br /> <br /> Give it gas: fill it up with fresh quality gasoline (mixed properly with fresh oil if its a 2 stroke). Old gas is not the same as new gas, volatile compounds will evaporate over time leaving you with gas that is harder to burn. Ideally you have used up everything in the tank the previous fall.<br /> <br /> Let it breathe: make sure the air filter is clean. For foam filters you can just clean them with a bit of gasoline (you can use the old stuff if you still have some). Paper filters need to be replaced, typically every year.<br /> <br /> Light the fire: a strong spark is the key to reliable ignition. If the first two tips don't give good results its probably time to change the spark plug.
on Jun 13, 2011 | Garden
My car has been sitting for 2 years and won't start. The engine turns over but it sounds like not getting gas. I read somewhere to spray gas starting inside air intake valve. Where is the air intake v
Safer is to use 'carburetor cleaner' which is also flammable but a little less dangerous than using gasoline.After sitting a long time, our modern gasoline gets tired; never allow something to sit so long without adding some 'fuel stabilizer.'If possible with your car, I would drain (siphon) the tired gas out and replace it with a few gallons of fresh.
Really tough starting problems can also be overcome with 'starting fluid' which is pure ether and very flammable.Any of these may require the removal of the engine air filter so the liquid gets into the intake manifold.
Stale gasoline can also gum up the fuel injectors which may have to be removed for service if none of the fluids causes the engine to fire.
Nov 23, 2011 | 2005 Jaguar S-Type
My John Deere leaf blower (BH25) will not start. I've had it for several years and have had no prior trouble with it. It uses two-cycle fuel. I usually get the stuff you mix with regular gasoline...
Fuel is no good get rid of it start fresh. First you need to take off the the carb and clean it very good put it back together with new fuel and start blowin, the season is upon us. Good Luck....
Aug 27, 2011 | John Deere Garden
The motor missed fire an acceleretion . after the truck was stop over 1 mounth.(escape 2003)
I'll bet it misfires because of the old gasoline. Since it was sitting for that long, you should remove the old gasoline from the car and put in fresh gasoline. You might want to put in a can of seafoam in the gas tank as well to clean up anything the old gasoline could have left behind.
Next time, if you're planning to have your car sit for a few weeks or more, put fuel stabilizer (such as Seafoam) into the gas tank before you leave. That way, you can safely start it when you come back.
Aug 18, 2011 | 2003 Ford Escape
My rear tine tiller, 18 inch - model #21AA40M1029 by yard machine has been sitting in my storage shed for two years and will not crank. I have changed the old spark plug with a new one and I have drained...
need to check for spark---- magneto [magnet-pulse to coil] may have rust causing failed spark can clean lightly with sandpaper but more than likely u need to clean the carb-buy a rebuild kit about 10 bucks -take off carb tear apart and let soak in parts cleaner use a carb cleaner and spray all the nooks and crannys in carb rebuild replace and try firing up because more than likely the carb is completely gummed up from the old gas
Jun 08, 2011 | Yard Machines Tiller 208cc 18in Tilling...
Our pellet fire seems to take a long time to ignite and start flaming we are using a sack of pellets from last year can you helpp it is taking aboout 20 minutes to produce a small flame
I suspect that the sack of pellets left over from last year, have absorbed a lot of moisture during that time. Therefore, they are hard to light and slow to get up to a roaring flame. Really, there's not much you can do to correct this. Other than stop using that sack of pellets to get the fire started. Use a new fresh bag to start the fire and add the others to the hopper, after the fire gets really hot.
Hope this helps you.
May 17, 2011 | Heating & Cooling
My snowblower will start but stop after a few minute. I think it is the old gasoline. Is it the gasoline?
If you are using fuel that has been in the tank since last winter then it should certainly be drained and replaced - gasoline degrades with time.
Of course I can't be sure that is the problem but I would advise trying fresh fuel first.
Jan 29, 2011 | Garden
Toro Recycler with Techumseh enging will not start
Make sure it can breath. Check the airfilter element. If its oil soaked replace it. Sounds like this engine cannot breath. This engine is set ,there are not jets to replace. Champion Plugs are not the problem FIRE IS FIRE . Fresh Gas if it aint less than 30 days old it aint fresh. Todays designer fuel goes stale quickly.
Jun 27, 2009 | Garden
The edger does not start
HI, ALEX
1st thing is to take the remaining gas out of the edger and wash out the tank with fresh new gasoline. it is most likely the problem is in the old fuel. it will in as little as 3 weeks start to varnish or seperate into less combustible properties and will smell a little sour or vinegar.since it was running at the end of last season i would replace the spark plug and refill with fresh gasoline. i would also add a additive seafoam acording to the bottles recommendation which is 1 0z per gallom\n of gasoline. it won't hurt to add this to what ever gasoling can you are using because this is recommended for all gasolineengines. give it a try and it should get you up and running. happy edging!
Mar 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Honda EG5000 Generator Logo
143 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
