Question about Whirlpool WFW8300SW
Washer kenmore elite 110-47081-602 code f71 - Whirlpool WFW8300SW
3 Suggested Answers
  • 92 Answers
SOURCE: keep geting FL code even after unpluging the
sounds like bad pump
Posted on Jan 13, 2010
Daniel S
  • 4323 Answers
SOURCE: How do I know which
Hi
F71 is a communication error and is displayed when there is no communication from the User Interface to the Central Control Unit. First check the user interface harness for continuity and then check the wire harness to the user interface and CCU. If the drum rotates then replace the user interface, if the drum is not moving then replace the central control unit (CCU). Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 11, 2011
Fault code f71 door locked. Is there any way to open door?
Here is a page tells you what to do to try to fix the issue. As it says if it persists Have it looked at. Page 23 of Kenmore Washer User Manual ManualsOnline com
Sep 30, 2014 | Kenmore Elite HE5t Washer
Kenmore Elite HE 3t steam washing machine shows a code of F71
The F71 error code means "User interface heartbeat failure" to put that in simple terms what it means is,the touchpad/cycle selector is not talking to the main control board. To check to see why that code is being displayed ya would need to make sure that all the wire plugs between the selector and the control board are tight and in fully pressed in and making good contact at the respective connection point on the circuit board.
If ya find the wire connections to be good and tight,ya would need to start the washer and if the drum rotates the cycle selector would have to be replaced. If the drum does not rotate the main control board would need to be replaced. oldtech2332_146.jpg
Oct 20, 2011 | Kenmore Elite 45986 Front Load Washer
What does error code f71 mean?
F71 means it is an Central Control Unit(CCU) communication failure.
http://www.fixya.com/support/r6709094-whirlpool_duet_f70_f71_error_codes
There is an detailed article by one of our senior experts in the above link.. Kindly look into the same.
Mar 03, 2011 | Kenmore Elite 45986 Front Load Washer
I have Kenmore HE5T Error code F71 Pls advise handling. Thanks.
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
Nov 07, 2010 | Kenmore Elite HE5t Washer
I got an F70 code . After unplugging the machine and then plugging it back in, I now get an F71 code. What to do?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Oct 16, 2010 | Kenmore Elite HE5t Washer
I have gotten F70 and F71 messages and the door will not open. What do I do about this?
Hi.
Regards.
Ginko.
Jun 23, 2010 | Kenmore Elite 45986 Front Load Washer
No communication between UI and CCU
Hi.
I think that by this time you already fixed the problem. The codes indicate usually a fault that is either CCU or MCU.
Regards.
Ginko.
May 03, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite H3 Error Code F71
The computer needs to be reset most likely. You might try turning it off, uplugging the washer, leaving it off for a bit and starting over. They are touchy little machines, I've found, not just your brand either. Mine comes on everytime the power blinks on and off in a storm :0) Best of all have a look in your manual and if you don't have it go to the manufacturer's site and download a new one or look for support there. Good Luck to you.
Jul 31, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool WFW8300SW Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
