Question about Whirlpool GS465LELS Dual Fuel (Electric and Gas) Kitchen Range
What's your problem?I have a whirlpool stove model gs465leks that initially the oven ignite but afterwards wont re-light (to maintain temperature). you can hear it spark but will not re-ignite.
aborcass
  • 2651 Answers
SOURCE: WHIRLPOOL SUPER CAPACITY 465 SF385PEGZ3 NO OVEN/BROILER
sounds like an issue with the spark module, altough that module tends to be really relliable.i would try removing pawer to te unit. checking the outlet for proper grounding,and replugging unit see if that works for you
Posted on Oct 27, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Oven will not light Model SF385PEE Help its Turkey time
i would check the wiring tothe gas valve, sounds as if you wired incorrectly
Posted on Nov 23, 2008
SOURCE: Whirlpool Super Capacity 465
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tries turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
Posted on Jan 04, 2009
frcs68
  • 1605 Answers
SOURCE: Whirlpool gas range spark ignition problem.
check the burn head, there is a tube from the ignitor to the burner head. that is where the gas get ignition. now look at the burner head, there should have 2 small pin hole align with the tube. use a paper clip clean out the hole.
Posted on May 21, 2009
Maytag317
  • 1136 Answers
SOURCE: whirlpool gas oven sf315pemb1- oven not heating
Hi, It sounds like the ignitor has gone bad. Remove the floor panel in the oven and locate the ignitor fastened to the burner. There should be 120V going to the ignitor harness.
If you have voltage but no ignition, change the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on May 27, 2009
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
GAS OVEN KNOB STUCK
The valve is 'seized'. Grease gets into them and over time turns acidic corroding the valve from the inside out. Replace the valve. Any appliance parts seller can get it for you. Turn off the gas before starting repairs!
Apr 30, 2017 | Whirlpool SF325 Gas Kitchen Range
I have a Whirlpool super capacity 465 gas oven that won't stay lit. It often lights up the first time just fine but then it turns off which is normal but when it tries to relight itself the ignitor...
That sound to me like yall have some carbon buildup on the igniter. On this stove the igniter does 2 jobs. It lights the burner and verifies back to the control that Houston we has ignition. If junk is built up on that ignitor then she won't be sending verification of ignition back to the control. That white residue needs to be removed. NOTE: I don't have your model number I am going by what you describe that this stove is a Direct spark ignition model. If you have a normal ignitor it probably is weak and not drawing 3.5 amps to open the valve. Post a model number (bottom drawer frame)
More Here
Sep 08, 2011 | Ovens
Oven will not light the stove top lights but not the oven electrical ignition
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jan 28, 2011 | Whirlpool SF111PXS Gas Kitchen Range
Model # 36275621302 stove not maintaining proper temperature. Takes long to bake. Broiler comes on ok. Bottom burner gas comes on and ignites in preheat but then the igniter glows hot but the gas doesn't...
Oct 28, 2010 | Kenmore Ovens
My oven wont light but the stove does
Oct 03, 2010 | Whirlpool SF362LXS Kitchen Range
Whirlpool electric oven not heating (has a functional stove top)
Hello Daniellel583! We are terribly sorry to hear of your concern with your Whirlpool Range. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Daniellel583), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool RF111PXS Electric Range
Maytag gas stove model CRG9830CAE the oven will not work
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, the igniter needs to be replaced. Good luck.
Mar 27, 2010 | Maytag Kitchen Ranges
Oven Not Working
Your igitor mat be glowing but it is not generating the proper amps to ignite the gas. The proper solution is to replace the oven igniter
May 27, 2009 | Whirlpool GS460 Gas Kitchen Range
Whirlpool GS465LELS Dual Fuel (Electric and Gas) Kitchen Range Logo
52 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
