Question about Bushnell Weather FX7 7 Day Forecast AccuWeather Stations - 95
My FX7 weather station won't connect with satellite. It just cycles through all the colors. That's as far as it gets. I unplugged the unit for several days. Before unplugging the unit the
For three days my FX7 weather station was stuck on 68 degrees as the outside temperature. I unplugged the unit for several days. When I plugged it back in the unit will now only cycle through all the colors on the screen. It does this for hours and hours and never connects to the satellite or displays any information on the screen. I don't see anywhere on this unit where there is a reset button.
4 Suggested Answers
SOURCE: I own three FX5 weather stations and none of these
me too i have been through 4 of the fx 5`s myself, they work from five days to two weeks then they quit, as there is NO place to register ? no instructions if you have to register ?, as far as i am concerned these are not worth the time, effort or mostly throwing your money away, and don`t try to call Bushnell, you will be put on hold, i guess everyone that got these for Christmas of 09 is calling about what to do with them, this may be one of the big mysterys of 09 not solved., and it does not matter what location you try from they just plain don`t work !! ` end of story!!!
Posted on Dec 30, 2009
greenspot621
SOURCE: New Bushnell Backtrack won't turn on.
I have the same problem with my Backtrack. I unlock back battery cover, unscrew some screws. Then I take the screen, check connection - it's ok. Then I try to close power switch with screwdriver. It started, but doesnt worked. There are some symbols on the screen. It's all I can do. My BackTrack still won't worked. For comments: greenspot@mail.ru
Posted on Sep 12, 2012
SOURCE: the sensor from my weather station is not registering outside temperature
I've had the same problem since I bought this unit 2+ years ago; when the outside temperature moves into the freezing zone, the sensor stops transmitting. I contacted Lacrosse-- all they could suggest was change the batteries. My solution: throw it in the trash!
Posted on Dec 08, 2012
My station has quite registering the rainfall amount
This is nearly always due to the batteries not having quite enough power. Oddly enough, it is normally the battery in the head unit, not the satellite unit. Mine are powered by CR2032 button batteries. I buy them 10 at a time in a bulk pack from here.
Battery Buyer Batterybuyer com
Oct 10, 2016 | Klockit AcuRite 02001A1 Weather Station...
Weather FX7 not changing
I have the same unit and have had the same problem . There should be at least two to three bars on the most upper right hand corner of the screen which pulls in the updated conditions If you have none I have tried , there is a tiny pin hole on the bottom back (center) - with a small pin I stuck it in and the unit rebooted an works fine now
May 14, 2013 | Bushnell Weather FX7 7 Day Forecast...
Weather station won't work
i have the same problem and have had 2 of these now. outside unit blinks like it is transmitting but nothing on base. SYNC per manual does not fix it.
Jan 29, 2013 | Brookstone Wireless Weather Forecaster
Taylor 433MHZ cable free thermometer won't show outdoor temp
Check battery in outdoor sender and reset main unit to receive transmission of data. If nada could be that you have an issue either with the sending unit or the receiving unit of your weather station. Has happened to me a few times already so .................
Jan 22, 2013 | Measuring Tools & Sensors
I can't get my wind speed sensor to communicate with base unit
My PC, only that one not a portable PC, gives noice over USB that blocks communication to windsensor etc. Gives very poor reception with USB connected. Works quite fine without USB..
Dec 24, 2012 | Oregon Scientific WMR88 Full Weather...
C Tech Weather Station. How do i reset the outside temperature. Meter says it's off?
Is the outside unit LED on? I replaced the battery on the outside unit and in doing this reset the outside information.
Jul 05, 2012 | Coghlan's CTech Wireless Weather Station...
How can I get intructions to adjust the data on my RCA WERE 1001 Made in China Black oval approx 5 1/2 " high weather station?
You should be able to press and hold the 'set' button on the back of the unit, then press the + or - button, also on the back, at the same time as pressing the 'set' button. Hold for about 2 seconds and it should beep. then it is just a matter of going through each item on the station and adjusting the time, etc., with the + or - buttons.
Jun 09, 2011 | RCA WERE1000 Weather Station
Air ware xm2go
The unit has an internal antenna (that is really poor) that is activated when you unplug the external antenna. This is why you get some signal when you unplug the unit.
I assume the problem is the antenna itself.
My suggesion is that you charge up the unit, take it to a place that sells XM equipment AND has a demo unit working. Be sure to take your docking station with you (it has the plug in for an external antenna). Ask the sales rep to please connect your unit to an external antenna to test your unit as you are trying to determine if your antenna is bad. If it works, you need a new antenna (cable may be cut on the inside or antenna may have water/weather damage). If it does not, then there is an electrical issue inside the unit and the unit itelf will need replacement/repair.
Jul 03, 2008 | Pioneer AirWave XM2Go Satellite Radio...
Bushnell Weather FX7 7 Day Forecast AccuWeather Stations - 95 Logo
Top Bushnell Measuring Tools & Sensors Experts
Ian
Level 1 Expert
Vernon Taylor
Are you a Bushnell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
