Question about HP Photosmart D7160 InkJet Printer
HP D7160 Wont Print From PC
I have a D7160, it will print from the memory card of my camera directly in the slot but will not frint from the PC.
I have tried all types of paper and quality combo's - no joy.
What happens is that the first print is sent and a proportion gets through then nothing, it hangs there, I cannot cancel this 1st print job. For example the status will say printing, under size it will say: 9.71k/1.50mb but it never completes the file.
If I send another print it will queue behind the 1st, I can cancel the 2nd not the 1st, the 1st effectively blocks the printer and wont cancel.
The only way I can get it to cancel this job is to physically unplug both printer and PC from mains power.
Can anyone help?
  • 32 Answers
Did you check the manufacturers website for a new driver. This is the first step in the process. Your steps so far have been good. But the process is stepwise.
Posted on Jan 20, 2009
My SanDisk 8GB will not download in the printer - an error saying Memory Card Error shows on the screen
The D7160 works with SD cards. Your 8GB card is an SDHC card. While it fits into the slot, it is electronically incompatible and will not work with this printer. You need to use SD cards, 2GB or smaller.
Oct 09, 2013 | HP Photosmart D7160 InkJet Printer
How to connect a printer to a digital camera?
If the photos are stored on the memory card (SD) in the camera, then remove the memory card from the camera and insert it into the memory slot in the HP printer. You can then print the photos that are stored on the memory card.
Jun 03, 2011 | HP Officejet 6500 Wireless All-in-One...
To print photos my machine requires a memory card. What card should I ask for and where/how do I install it?
Hello!
You can print photos from your computer too. Usually, people use memory cards from their digital camera, when they want to print photos directly from the memory card. If you do not have a digital camera or any other device that uses a memory card (i.e. a mobile phone), I am not sure you need one in order to print photos. However, here is the answer to your question:
You can use several memory cards in your printer, but only one memory card at a time! You can use:
  • SmartMedia, xD-Picture Card (fits in bottom right of the slot)
  • Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro
  • CompactFlash (I, II)
  • Secure Digital, MultiMediaCard (MMC)
Here is a picture, so you can see how to install them:
You can buy either one of these memory cards, it's up to you to decide which one you want.
Hope that helps!
May 06, 2010 | HP PSC 1610 All-In-One InkJet Printer
How do you transfer pictures on thememory card inserted in the print to the computer?
if you plug the memory card in the slot. software will see it and start automaticly.
May 30, 2009 | HP Photosmart C4480 All-In-One InkJet...
HP C5180 All-in-one : Memory Card Error, No memory card in it
  1. Remove the memory card from the camera.
  2. Locate the memory card slot on the product that is compatible with your memory card. Figure 1: Memory card slot locations c01331721.jpg 1 - CompactFlash (I, II) 2 - Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card 3 - xD-Picture Card 4 - Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro 5 - Front universal serial bus (USB) port (PictBridge-enabled)
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass storage port on your product. These partitions are added by the manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive.
  3. If it is not already on, turn the product on by pressing the power button (c01324469.gif ).
  4. Turn the memory card so that the label faces inward and the contacts face the product. Figure 2: Inserting the memory card c01335108.gif CAUTION: Inserting the memory card in any other way might damage the card and the product.
  5. Gently push the memory card into the memory card slot until it stops. The memory card does not insert all the way into the product; do not try to force it.
  6. When the memory card is inserted correctly, the status light next to the memory card slots flashes and then remains solid green. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. You can safely remove a card only when the status light next to the memory card slots is not blinking. Do not pull out a memory card while the light is flashing green.
Step two: Print the photo
  1. Press Photo Menu . A message displays on the control panel with the number of files found on the memory card.
  2. Press the right (c01185072.jpg ) and left (c01185108.jpg ) arrow buttons to browse through the photos on the memory card.
  3. When the photo number you want to print appears, press OK .
  4. After selecting the photos, press Photo Menu again.
  5. Press the right arrow button (c01185072.jpg ) to select Number of Copies , and then press OK .
  6. Press the right arrow button (c01185072.jpg ) to select Layout , and then press OK .
  7. Press the right arrow button (c01185072.jpg ) to select Paper Size , and then press OK .
  8. Press the right arrow button (c01185072.jpg ) to select Paper Type , and then press OK .
  9. Make any other appropriate changes to the settings, and then press Print Photos .
May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
I have a HP Photosmart 7160 and a brand new Fujifilm digital camera. I took 4 pictures and tried to print photos. When I place the SD 4GB card in it reads "memory card error" on the printer. What do I do...
You are using a new camera with an old printer.
Check the following:
- Try using a 1 to 2 GB SD card. The printer may not be able to hande one this size.
- Try taking a photo, in a smaller resolution, and save as JPG.
- Try plugging in the camera to the printer and print from the camera.
And the best option, is to transfer your photos to your computer, and print from there.
Take a look at a program called "Thumbs Plus" it has worked well for me. http://www.cerious.com/
If you have lost your manual, see: www.HP.com/Support for other answers.
Jan 01, 2009 | HP Photosmart D7160 InkJet Printer
Ink not printing the same image quality that is on computer
Issue When printing directly from a memory card, the printouts have an abnormally high red tone.
NOTE: This does not affect the prints that were originally sent from the computer. Solution Press the Photo Fix button to turn off the Photo Fix feature before printing from a memory card. Cause The Photo Fix feature was originally designed to reduce/enhance printed pictures by making colors more vibrant. However, it can also have a side-effect to make some prints have more red tone than desired. In the HP Photosmart D7100 series printer, this feature is “ON” by default.
Dec 15, 2008 | HP Photosmart D7160 InkJet Printer
Compatible memory sticks
That's right. If the printer doesn't use the existing stick, you can't do a direct print. Do it thru the computer: plug the stick into the pc and then print the photos out to the printer.
Jun 28, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Exif Print or PIM Print feature
The printing information that is included as part of the Exif 2.2 header in the JPEG file, is read and used by a Print Image Matching enabled printer. If you have a compatible printer that has a built in media slot, you can insert the digital camera’s memory card into a card reader and then into a printer’s media slot. If you do not have a printer that accepts a card directly, you can use a plug-in for a graphics program such as Adobe PhotoShop 7.0, to utilize this information. CAMEDIA Master 4.03 and above supports Exif Print and PIM.
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
HP Photosmart D7160 InkJet Printer Logo
60 people viewed this question
Ben Johnson
