Hi, The biggest fuse to be replaced is a 30amp. I don't know what you have that is that big. Could be a relay you have. Usually under the steering wheel and left. Good luck.
disconnect the negative batery terminal be fore you mess with the horn. the cover should come off easily and you will the wire for the horn on my car the wire is green
LOOK UNDER THE LOWER AIR DEFLECTOR FROM BELOW THE RADIATOR. IF YOU HOT WIRE CAR HORN AND IT WORKS.YOU HAVE TO REPLACE THE WHOLE AIRBAG IN STEERING WITH HORN CONTROL BUTTONS.YOU NEED TO DISABLE AIRBAG IN STEERING WHEEL WHEN REPLACING AIRBAG AND HORN CONTROL BUTTON PAD.JUST TURN OFF RADIO FIRST, THEN DISCONNECT REMOVE THE NEGATIVE BATTERY CABLE.WAIT 20 MINUTES BEFORE WORKING ON AIRBAG AND HORN PAD IN THE STEERING WHEEL.
Check your fuses (often located on the outside side of the steering wheel (I don't know what country you're in, therefore which side of the car the steering wheel is on)), if they're all fine, then check the relays- these are often located under the hood/bonnet, in the engine bay. It'll be a black plastic box (most likely) mounted off to the side somewhere, that's pretty easy to get to, usually.
It's time to replace the flasher relay.The signal flasher is located under the dash near the steering column.Also check for the indicator bulb.Replace them if damaged. Front Turn Signal Light Bulb Size: 3457ALL
Rear Turn Signal Light Bulb Size: 3057 Hope this helps.Your valuable feedback would be appreciated.Thanks
I have or should say had same issue on 1996 cirrus quick fix just remove the HORN RELAY located on the left side of dash relay only controls horn. To really solve the issue at hand you must replace the clock spring on the steering wheel dis-arm air bag before messing with steering wheel to avoid activation of air bag disconnect battery for 10 min then its safe to fiddle with steering wheel safely. Chino S.G.V
This is kind of an open question because I don't know if your fan (blower motor) is not coming on or if the fan is working and it's just not cold which means the A/C compressor clutch isn't engaging. I am giving you the most common and that is the compressor. In your power distribution box located in the engine compartment (see picture of location below) is the A/C cltch fuse and the A/C cltuch relay itself. The A/C clutch fuse is located in the number 13 position and should be a 15 amp fuse (see other picture below for layout of fuse panel). then in that same box in the number 204 position is the A/C clutch relay itself. If it's the fan not blowing there are many possible fuses for it and like I said i wasn't sure what you meant by A/C fuse. All of this should be in your owners manual if you have one. If you don't and would like a copy, you can email me at [email protected] with your make, model and year and I will be happy to email you a copy. Or if you just want to know where those other fuses for the fan are you acn email me as well. I hope this helps and good luck.
