Question about Frigidaire FTF530FS Front Load Washer
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Since you hear a humming noise, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Posted on Nov 01, 2012
SOURCE: frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Posted on Oct 15, 2008
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Nov 12, 2008
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Frigidaire GLTF2940ES Front Load Washer
heatman101
Jan 03, 2011 | Frigidaire Affinity ATF6000F Front Load...
Sep 08, 2010 | Frigidaire Affinity ATF7000E Front Load...
Aug 31, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Dec 25, 2009 | Frigidaire Washing Machines
Oct 19, 2008 | Frigidaire FTF530FS Front Load Washer
Oct 07, 2008 | Kenmore 43142 Front Load Washer
Feb 19, 2008 | Maytag Neptune MAH5500B Front Load Washer
Oct 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Dec 17, 2006 | Hoover Nextra HNF 2137 Front Load Washer
Jun 07, 2014 | Frigidaire FTF530FS Front Load Washer
181 people viewed this question
