Question about Air Conditioning and Heat for Pontiac G6
No heat in a 2005 pontiac G6
Have checked everything, could the radiator be the problem even if the car doesnt overheat
  • 3 more comments
  • Rocky Degelman Nov 01, 2012
    Have you had it checked out at a garage? This is a Stromper When you stay you check every thing, . Does the car have a temperature Guage ? Where is the Needle at on the temp guage. When car is warm up After driving for a while.
  • Rhonda Sparks Nov 01, 2012
    Everything works fine, changed the radiator, thermostat, flushed heater core twice, both actuators are finee
    still no heat
    The Blend door in the heater control box is not closeing, Or your temperture control switch is shot,
    that all works, checking hvac
    Master:
  • 444 Answers
Have you changed the thermostat,?
Posted on Oct 28, 2012
Can I run my car with only one of the radiator cooling fans working
Easy to fix maybe probably a bad relay
25641364-gbcwolhsts3eo5ciz23y3phn-4-0.jpg Check the rad high one
Apr 11, 2015 | 2009 Pontiac G6
No heat in Pontiac g6 2007
troubleshoot!
are the heater hoses (firewall) gettin just as hot as the radiator hoses? If not, focus on blockage in the heater core.
If they are same temperature, might be a mechanical/vacuum malfunction in the climate control system.
Feb 06, 2014 | 2006 Pontiac G6
Heat doesnt work
check your fluids radiator should be full and resavor should be at full level if you dont have enough anti freeze it wont push fluid into your heater core also pay attention to your tempature gage if the temp is low you wont get good heat your thermostat could be stuck wide open I would try adding anti-freeze first though that usually fixes it make sure its 50/50 if you just add water sooner or later that water will evaporate
Dec 08, 2012 | 2005 Pontiac G6
Y WOULD A PONTIAC G6 2005 BE RUNNING HOT
check the cooling fan and thermostat
Sep 22, 2012 | 2005 Pontiac G6
After changing the battery on my 2005 Pontiac G6 the radio will not display anything. Not even the
did you hook the cables up backwards (ground to positive) as this could short out your electronics. are there any other electronic issues. if you didnt and everything else is ok you radio may have an anti-theft program. you can try disconnecting the ground connection to the battery for about 30 secs and reconnecting it. if it still doesnt work look in your owners manual how to reset the computer also check your fuses.. if all fails you may need to get the radio reprogrammed good luck
Jun 16, 2012 | 2005 Pontiac G6
How do I vent air out of a 2006 Pontiac G6 after replacing thermostat
The generic method of bleeding air from the cooling system is to use a floor jack and raise the front of the car as high as poss, then fill the coolant recovery tank full and run the engine until it just starts to overheat, high end of normal zone on gauge, then shut the engine down and run cold water over the radiator core, this will self bleed the system and the coolant will be pulled from the recovery tank, repeat as necessary, never let the recovery tank run dry or more air will be pulled into the cooling systeml , if it still overheats then you need to have the head gaskets checked with a gas analyzer for hydrocarbons present in the radiator or recovery tank
Jun 30, 2010 | 2006 Pontiac G6
My scerity sys went off and I my car over heats I think it needs a new thermastat
maybe your security system monitors engine temp ... it doesnt have to be the thermastat thats bad .. it could be the radiator fan switch or relay bad .. you can tell which by the following.
1. if it overheats only when idling or in heavy traffic but does not overheat while on the road (moving) then your problem is more likely the radiator fan switch, relay or fan motor ..
2. if your car overheats all the time even while driving then it could be the thermostat ..
check belts, coolent level and radiator clogging ..
Feb 19, 2010 | 2001 Pontiac Aztek
Replacing radiator on 2005 Pontiac G6?
comes out of bottom. You need to remove the bottom cover. Then there is two radiator support brackets that need to be removed. Don't forget to remove the AC condenser bolts then lower it on down. Probably gonna take u a few hours to replace.
Mar 09, 2009 | 2005 Pontiac G6
Air Conditioning and Heat for Pontiac G6 Logo
Top Pontiac Vehicle Parts & Accessories Experts
jerry emmons
Jeffrey Turcotte
Jeffrey Turcotte
Hashim Khan
Hashim Khan
Are you a Pontiac Vehicle Part and Accessory Expert? Answer questions, earn points and help others
