Question about Electrical Supplies
Low 5.5 volt output on my power boss 5500 generator set.. What is wrong?
Power Boss 5500 ith Briggs and Stratton engine. Lost 110 output.. When Measuring at receptacle when running the peak output is currently 5.5 volts. What can I do to fix it..
5 Suggested Answers
SOURCE: I have a Briggs & Stratton Generator 5550Watt model 030253 That is showing an output of only 4.6 V
Have the same generator. Shows only 3 Volts. I took the generator apart and found that the stator winding was burned. Can buy a replacement stator for about $250.00.
Posted on Sep 22, 2010
  • 185 Answers
SOURCE: I have a Briggs and Stratton 5500 watt Generator
Hello, I would not advise you to adjust the speed without a frequency meter. for 220 volt operation, you will have to use the twist - lock receptacles and not use the neutral in the receptacle. This means one of the generator's hot leads is going to be the neutral in your system. The frame of the generator may be connected to the neutral of the generator, so be careful so that you do not receive an electrical shock. The voltage is adjusted within the receptacle box. There might be a small hole on the right side of the receptacle box that you can insert a small blade screwdriver into to make the voltage adjustment. You do not need to change this much to change the voltage. Now, the frequency is adjusted by a self-locking nut located under the air cleaner right side, when facing the engine. There is a spring on this nut / bolt assembly. I think it is a 5/16 nutdriver or socket that you need for this. Turn counter clockwise 1/8 of a turn. This will slow down the generator to about 50 - 55 hz. This is okay if you are running at around 52 hz. As the generator loads, the rpm will drop down. A frequency meter would be great to use here, as a too low rpm could burn out electrical motors and other equipment that you are using. Feel free to contact me joeleier@gmail.com www.freelancemissions.com
Posted on Jan 22, 2011
Testimonial: "Thank you for the quick response. Great advice and outstanding instructions."
kel1guy2002
  • 3740 Answers
SOURCE: Hello, my Briggs &
Hi and welcome to FixYa. I am Kelly
Usually when you have a lower voltage output that is yet above 150 VAC the problem is as simple as the engine is no longer running at full speed. This could be caused by binding carb or governor linkages but more often than not the Governor adjustment screw has backed off over time causing the engine to gradually slow so the output voltage drops. The user does not notice it so much until the output drops more than 15% and you notice dim lights... slower running equipment etc.
Look for a circular plate / governor speed plate near the base of the governor lever but off to one side that has a spring that attaches to the governor lower end of the governor. There should be a screw with a locking nut. Loosen the nut and turn the adjusting screw clockwise to increase engine speed. (You may have to barely loosen the pivot nut on the governor speed control adjustment plate to make the speed adjustment.... tighten when done with speed adjusment) Watch your output voltage and adjust the voltage to 225 VAC with NO LOAD. The voltage will drop as loads are added. Make sure to tighten the lock nut on the adjusting screw or in a matter of an hour you will have low voltage again from engine speed dropping. What ever you do.... DO NOT adjust the governor arm base attach point where it attaches to the engine.
Just so you know a weakened governor spring can cause the speed drop also. If the speed keeps dropping with extended use, you may have to change the spring that goes from the lower end of the governor arm to the governor speed adjustment plate.
Thanks for choosing FixYa,
Kelly
Posted on Apr 20, 2011
Testimonial: "sound bright advice, excellent"
stewbison
  • 577 Answers
SOURCE: I have a briggs and
Hello, First figure out what the load per leg is on your generator. Are you using the 240 Volts because this is two 120 AC volts legs and they are 120 degrees out of phase with each other.
You will need to figure what the power factor is for each phase on this generator. To figure the power/wattage by using ohm's law. Voltage times Current will give you Watts. Example: If the generator is generator 240 volts the maximum current available is about 23 amps. The maximum current for 120 volts will 46 amps. Therefore, the maximum current per 120 volt circuit is 23 amps for one circuit and 23 amps for the second 120 circuit..
I would try replacing the circuit breaker with the same amperage breaker. Also, watch what the generator load is per circuit. You can install current meter for each circuit. This will give a good indication of which circuit is pulling more load than the other circuit. GB...stewbison
Posted on Sep 06, 2011
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
My generator starts on the first pull but whenever you move the throttle lever from "choke" to "run" it dies. I thought possibly the fuel had gone bad so I throrughly drained the tank...
Does your generator have a warm up position (where the engine will run but not generate power). Take a look and if it does get it running on that setting first. Then switch on the generator switch.
Aug 26, 2011 | Briggs Stratton H7159 & StrattonĀ® 5500,...
Briggs & Stratton 12KW Model 040229 LPG Generator. 96 Volts @ the 120 Volts outlet, When I turn the house 2 Ton AC voltage increase to 106 Volts.
Can you manually adjust the voltage on the generator without load?? If you have 120/240 60hz output on it and you are not overloading the unit (amperage), then it may be as simple as adjusting whats called your gain setting for your voltage regulator. Obviously you are seeing what happens when it is set too low. Trying raising that setting until it becomes unstable then back it off. Unstable meaning voltage starts jumping all over.
Jun 27, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
Briggs and stratton 8000 watts generator, the output of the 120 is only 102. How do I adjust the output?
Voltage is adjusted by increasing rpm of engine. Use meter with Hz setting and try to adjust to 60 cycles and check voltage to be at about 115-120. If engine is turning 3600rpm/60 cycles and voltage is very low, then problem is most likely with brushes/ commutator rings, or voltage regulator. Some voltage regulators have an adjustment screw to bring voltage up/down (adjust to proper rpm/cycles first). Good luck
Sep 09, 2010 | Briggs & Stratton Electrical Supplies
How do I remove the case from the generator on a B & S motor / power boss 030249? the gov. is fried.
take the end case off the end of geny 3 x 10mm bolts?
on the end of the geny shaft is a 10mm bolt wip it out,
the geny is held to the motor by 3 or 4 bolts wip them out too,
then with a sharp rap on the geny case near the motor end the geny should pop off the taper its held on to the engine crank shaft,,,there tight as well!
Jun 26, 2010 | Briggs & Stratton Power Products 5,550...
No power output from Briggs & Stratton ProMax 7500E generator
You may have exciting field broken. Look for a fuse or wire break.
Jun 04, 2010 | Briggs Stratton Portable Generator 305cc...
Briggs and stratton generator keeps throwing the circuit breaker
Power tools CAN draw heavy loads if the voltage or frequency is off. Both of those CAN be a fault of the generator.
Check the frequency by plugging in a clock with a moving second hand and time it for 10 minutes against a quartz clock. ALSO do a voltage check with another voltmeter.
The 5500 Watt generator should hold 40 amps. Power tools with induction motors like some table saws take a large starting load near this value AND would be sensitive to low voltage AND especially low frequency, both of which will cause much higher current draw.
One MIGHT have to resort to put an oscilloscope on the output to make sure the waveform of the AC output is normal..
Apr 03, 2010 | Briggs & Stratton Power Products 5,550...
Briggs elite 5500 model 01654 putting out too much power at outle
butterfly shaft on engine siezed causing irregular high idle. high idle causes over powering surge from stator/rectifier assy. idle sppeds must be within gen specs for accurate output levels.
Jan 16, 2009 | Briggs Stratton H7159 & StrattonĀ® 5500,...
Electrical Supplies Logo
185 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
