Question about Aiwa Audio Players & Recorders
Looking for the manual of an AIWA PX-E770 Turntable
djproaudio
  • 515 Answers
SOURCE: Aiwa PX-E860 turntable
Don't understand. If it doesn't turn on, how do you know the electronics are ok? More than likely your transformer shorted, and will need to be replaced.
Posted on Sep 24, 2007
SOURCE: aiwa stereo turntable system px-e860k
how long have you had it? could be that you just need a new belt if it keeps slipping off...
Posted on Oct 20, 2008
lesliemurphy
  • 69 Answers
SOURCE: A needle for AIWA PX-E860?
try this company?
mailto:info@needledoctor.com
Posted on Oct 07, 2009
  • 396 Answers
SOURCE: how do I attach the turntable belt to the Aiwa px e850
Lift the platter off the turntable. You can identify the motor spindle by using your fingers to turn the round shaft which rotates freely. Remove the rubber mat off the platter. Place the belt around the outside of the drum on the bottom of the platter. From the top of the platter, place your finger in one of the platter holes and tension the belt so it will not fall off or twist. Griping the platter trough the holes while keeping tension on the belt place the platter on the turntable aligning your finger with the belt to the motor spindle. Place the section of the belt on your finger over the motor spindle. Replace the rubber mat on the platter.
Posted on Jul 21, 2010
  • 256 Answers
SOURCE: the drive belt on my Aiwa px-e860 turntable has
Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
Posted on Aug 18, 2010
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
THE PLASTIC COVER OR LID IS BROKEN FROM MY AIWA PX-E860 TURNTABLE WHERE CAN I BUY IT. SILVIA DE ALBA
I don't think you can find this part easily and new and honestly it doesn't worth it.
I would suggest to go for this or something similar
Aiwa Stereo Full Automatic PX E860 Turntable System
Feb 12, 2014 | Aiwa PX-E860 Turntable
I need a motor for my aiwa px-e 860 turntable
Hi, stylus city can supply a motor for this turntable. Styluscity@gmail.com
Jun 23, 2010 | Aiwa PX-E860 Turntable
PX-E860 Turntable: I need to replace the cartridge of my aiwa turntab...
my aiwa PX -E800 TURNATBLE has stopped working ,, is there anywhere i can get a replacement turntable .
Regards
Trevor
May 17, 2010 | Aiwa PX-E860 Turntable
How do I attach the turntable belt to the Aiwa px e850
Nov 05, 2009 | Aiwa PX-E860 Turntable
TURNTABLE SPEED TOO SLOW. IS THERE ANY WAY TO ADJUST IT.
The liely cause of the slow speed problem is the belt. Your turntable is belt driven, like components in your car's engine compartment. As the belt ages, it can begin to slip. Replacement of the belt will probably restore the speed once again. The PX-E860 turntable has been discontinued. There are parts, such as the belt, that are still available. How much longer these parts will be available for remains unknown. If you like the the turntable, you should consider purchasing several belts as the next time you need one, they may not be available or may cost much more.
One source for replacement belts (there may be many others, ie: eBay):
http://www.elexatelier.com/aiwa.htm
You might also need a manual to direct you as to how to go about changing the belt. The manual is a free (after registering) download below:
http://www.retrevo.com/support/Aiwa-PX-E860-Turntables-manual/id/1077bh126/t/2/
Oct 05, 2009 | Aiwa PX-E860 Turntable
Sep 23, 2007 | Aiwa PX-E860 Turntable
93 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
