Question about HP Recertified - G72-227WM 17.3" Windows 7 Home Premium Refurbished
I have a hp g72 227wm my screen got broken so i hooked up a desttop screen and it was working fine until i restarted the laptopb by the lights on the key board i can tell its logging on to windows the
Can t see any thing
  • HP Master
  • 27,725 Answers
What sort of a desktop IDE or SATA
Test all leads that attach to your hard drive including electrical extensions IDE SATA
the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections and are not faulty
even something as small as an electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
Posted on Nov 01, 2012
Signal flasher problem.
are the trailer lights the same as the vehicle ( not LEDs as car bulbs) check the trailer connections for shorts or broken wires
May 08, 2016 | Cars & Trucks
Video Cable may be damaged, causing the display to quit. Video Cable shorting out.
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Page 70. (Adobe Reader page number box at top)
Remove all components down to the Top Cover. (Palm Rest Cover)
Page 71. Disconnect the Video Cable.
(Display Panel Cable, and Number 1 in the figure photo)
Let's see if you still have a problem with the external display.
HP Support > HP G72-227WM Notebook PC > Main Support page > Manuals,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=4290949&
In the list click on -
Compaq Presario CQ72 Notebook PC and HP G72 Notebook PC - Maintenance and Service Guide
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name it may take up to 30 seconds, before the first page comes up.
(Using medium speed DSL connection. Took 6 seconds just now)
ONCE the Top Cover is removed the STATIC shock sensitive components are exposed.
Your body carries Static electricity. Static WILL fry out, (Short Circuit), the delicate hardware components inside a computer.
(Laptop or desktop)
A Processor is the MOST susceptible hardware component to Static shock.
For this reason it would be a GOOD suggestion for you to wear an ESD wrist strap, and have it's alligator clip attached to a good ground source, BEFORE removing the Top Cover.
Average price is around $3 to $6. Here is but one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
(I feel an Anti-Static mat is unwarranted)
You can also set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or a large metal knickknack. (Unpainted)
Post your results in a Comment.
Regards,
joecoolvette
Oct 28, 2012 | HP Computers & Internet
Hp g72-227wm has a broken lcd screen i have a hp compaq le1711 vga flat screen hooked to my lap top it was doing fine i log off out of windows and shut down the pc when i turn it back on the flat screen...
Check monitor is set to correct input (VGA, DVI, HDMI) if it goes to sleep instantly.
Otherwise screen resolution is set too high. Boot into safe mode by pressing F8 during boot. Login and lower screen resolution.
Oct 03, 2012 | Computers & Internet
HP Pavilion dv6448se Notebook PC Won't Boot.
it restarts on booting screen or else at start up screen itself?
Jun 08, 2012 | HP Computers & Internet
My screen is dark, appears like no back light, but everything else still works fine. can faintly see screen
Hello
If you can faintly see the screen I would guess the back lights are like you said....not working.
Can you hook up a external monitor or TV so you can still use it and get your files in order. or until you choose to get it fixed. I would get a couple of estimates first
I also found this video if you want to replace the back light inverter yourself.
http://www.youtube.com/watch?v=UT2GFVem_9U&feature=PlayList&p=70B03BCB27E35519&playnext=1&playnext_from=PL&index=16
Feb 23, 2010 | HP Pavilion dv1000 Notebook
HP internal webcam shows dark screen
Okay, the driver for the camera (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32\
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the webcam applications that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the webcam driver, and the problem will be fixed!
Mar 12, 2009 | HP Pavilion dv4000 Notebook
It starts up fine until a blue screen pops up
hi
i think one of the drivers are the culprit. heres what you should do:
open your system unit and remove all the pci cards except the vga card. and turn on the computer.if it starts fine, then turn it off and hook each card one by one.
hope this helps
Kind regards
RAhL_hunk
Mar 06, 2009 | Microsoft Windows 2000 for PC
Screen wont light up, cannot see the screen.
press f8 after boot up ,then select option enable vga,then when it start go to control panel,
un-install the display drivers,restart and reinstall them.
Feb 06, 2009 | HP Pavilion dv7-1130us laptop
Computer screen is blank
Try uninstalling SP3 you will have to hook up to another monitor first. Go to control panel and click on Add and Remove Icon Go down until you see SP3 click on the remove tab. Once it is removed turn off your laptop remove the other monitor and restart you should be fine. You can also call 1-800-642-7676 for help as well
Jan 24, 2009 | Toshiba Satellite A35-S159 Notebook
HP Recertified - G72-227WM 17.3" Windows 7 Home Premium Refurbished Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
