Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Unable to load operating system on FUjTSU AMILO Pro V2010
Have bios sceen willnot load operating system from recovery disc
  • Fujitsu Siemens Master
  • 3,606 Answers
Hello the recovery disk is only for repair windows purpose.
It does not contain a complete windows system.
You can ask microsoft in your country to send you
a new windows disk as long you have the 25 digit code.
I know it will cost a litle money but it is so.
You can even download your own windows at microsoft
But its a large file approx 2,4gb for 32 bit and 3,2 gb 64 bit
And the file is in the ISO format so you have to burn it yourself.
There are many other ways to download your own windows
Use google and type: windows 7 download
and see what comes up.
Good luck
Posted on Oct 30, 2012
beeveez
  • 167 Answers
SOURCE: LOST DRIVERS
How do you normally connect to the Internet on this computer wireless or by connecting an Ethernet cable on it?
- If using wireless, look for available wireless network in the area, and once you find your network, connect to it and it will brought back again to the Internet.
- If using Ethernet connection, make sure your computer is connected tightly to your router or modem for you to get online.
Posted on Mar 11, 2009
longgee
  • 322 Answers
SOURCE: BIOS CMOS battery dead
You just have to go to the nearest computer store and purchase the battery you needed.
Posted on May 01, 2009
heavyice
  • 374 Answers
SOURCE: keyboard replacement instructions
The keyboard removal process is very similar to many other laptop brands.
1. Remove screws securing the keyboard.
2. Remove keyboard bezel.
3. Unplug keyboard cable from the connector on the motherboard.
A word of caution. Be very careful with the connector on the motherboard when you unlock it If you accidentally break the connector, you’ll have to replace the whole motherboard.
You can even try this site http://mycapsules.com/disassembly/fujitsu-s2110/keyboard
or this site
http://www.amilo-forum.de/topic,1056,-Arbeitsspeicherwechsel-RAM-bei-Amilo-Pro-v2010.html
It is not your model but it will give you an idea.Just keep pressing "next"
Hope it helped.
Posted on Aug 05, 2009
durtopian
  • 408 Answers
SOURCE: how to get sound drivers online for AMILO Pro
(http://support.ts.fujitsu.com/com/support/downloads.html) if you have XP.
Posted on Nov 20, 2009
  • 76 Answers
SOURCE: I need a video tutorial on how to replace the
All you need to do is leaver off the power button strip with a thin screwdriver. The power button strip has a slight gap at each side this is where you insert the thin screwdriver or thin leaver.
The power button strip has two plastic locking down lugs at each side they hold it in place.
Do it from the power on button side first with the screen flat backwards or you will pop off some keys.
Getting off the power button strip is the hardest part without poping off keys or scratching the case.
Unscrew the single silver screw to release the key board this screw is located slightly to the right of center although there are four locking down tabs on the keyboard it is only held down in the second one from the right. (It’s the longest screw in the laptop)
Push the keyboard slightly forward then tilt the keyboard towards you and lay flat (you should have enough strap to do that)
If you want to remove the keyboard completely you have to lift up the left and right lug each side of the strap)
Just at the right top edge of the strap connector you will see a silver headed screw, remove it.
The CD/DVD writer is now free however at the end nearest to you it is pushed into its electrical socket which is part of the motherboard.
If you press on the silver metal bit that you removed the screw from (looks a bit like a top chopped off triangle) the writer will slid out of its electrical socket, the device will come out from the right side of the laptop.
Remember if you are replacing the writer you will have to get one with the correct electrical socket.
Replacement is the reverse of removal. Slid in the DVD writer make sure it slots into the electrical socket. Put the locking screw back in. Locate the keyboard in its forward slots and slide in the strap, lock it into its connector, by pushing down the lugs either side. Lock down the keyboard with its screw and push back into place. Push the power button plastic strip into place.
Do the operation with the battery out and the power adaptor disconnected.
Hope this is clear enough and helps.
Posted on Feb 17, 2010
Testimonial: "Thanks so, so, so much!"
Want to download drivers for Fujitsu Siemens Model. Amilo Pro V2010
Go to the link below and select your model and operating system
http://ts.fujitsu.com/support/downloads.html
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu siemens amilo pro. it is running windows and i did a checkdisk. now i gives the error - cannot load operating system.
go to the bois by pressing f2 or delete then go to boot seq then sellect 1st boot from cd'dvd rom f10 to save
Nov 08, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Where i can buy, power socket for my amilo pro v2010?
Just one example,
http://www.laptopjacks.com/view_part/For-Fujitsu-Amilo-Pro-V2010-DC-Power-Jack-FJ41420.html
The power socket in the laptop that the AC adapter (Charger) plugs into is a DC Power Jack.
Type Amilio Pro V2010 DC Power Jack in your browser search bar, press the Enter key.
To add:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Nov 07, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
My amilo v2010 will not change boot options Help
Please try to press F2 for the BIOS and then CLEAR NVRAM meaning set the BIOS to default configuration there is an option there to change the BIOS Default then restart . Make sure that there's nothing connected to the system except the adapter and the battery only.
ERNZ
Feb 03, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
I have lost my recovery cd for Siemens AMILO Pr, how can i instal windows XP SP2 again on my system as it says there is no hard disk connected. Plz help me
If You're Getting That Message... Then It's Not Recognising The Physical Hardware... The Drive Itself...
Pull Hard Drive Out And Reinsert It... Then Go Into Your BIOS Setup... Ensure That Your Hard Drive Shows Up In There....If Not, Your Hard Drive Most Likely Is Faulty and Will Need Replacing..
You Will Still Need Either A Recovery CD Or Just An OS Cd..(XP/Vista etc..)
Dec 03, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
May 01, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Will not work wireless - has to be plugged into hub
To switch on the WLAN automatically at system start, please enter the following BIOS setting:
Open the BIOS Setup Utility by pressing [F2] after switching on the AMILO. Goto menu Advanced and change the option "Default Wireless Setting" to "Wireless LAN". Save changes and exit BIOS.
Now the WLAN adapter is enabled by default.
hope this helpsplease feel free to ask morequestions
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Default cmos password of amilo pro v 2010
is this a second hand computer or are u the original owner of this if so you may need to contact the manufacture and get the password
Jul 06, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Problem starting notebook
This is a problem with the operating system and sometimes an indicator that the hard drive has failed or is starting to fail. Start by doing a system repair with your recovery disc, if it will not repair, then do a complete reload of the operating system. If you have any problems (ie... missing file 32 dll) during or after the reload, then the hard drive has failed and will need replaced.
Jul 03, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
211 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
