My Amish fireplace has become very noisy when it is on. Any suggestions?
How do I clean the dust from an Amish fireplace
This shut down is a safety feature on the unit so it doesn't over heat.
You need to remove a cover that's in the back on the bottom and
take compressed air to blow out the dust. Concentrate on the
blower especially. Best done out doors.
This is also a good opportunity to see if the blower still turns
freely. If not it'll need lubed or replaced.
Sep 01, 2014 | Unknown Heat Surge Amish Crafted...
Unit turns itself off
It's dusty inside. I came he to find out how to clean it
Mar 12, 2014 | Unknown Heat Surge Amish Crafted...
Heat surge fireplace
Customer Service
1-800-924-7964
Mon - Fri: 8:00am - 9:00pm EST
Sat - Sun: 9:00am - 6:00pm EST
custserv@heatsurge.com
Oct 12, 2012 | Unknown Heat Surge Amish Crafted...
How do i clean the inside of an amish fireplace
I was told to tip the amish fireplace and hold it about 6 inches away from the floor for about 20 seconds then set it back up you can here it reset inside and I was also told they are self cleaning hmmmm I also had mine for more than the warranty and they sent me a new insert at no charge. Cannot beat that I have to call them again casue it runs for a bit then shuts down again all in all they have been great to me and it heats great too
Mar 29, 2012 | Napoleon Heating & Cooling
Charmglow electric fireplace flame does not flicker. Bulbs ok. HEF33WDG
You will have to connect a 12v dc power supply to the flame motor. The controller on the board has fried. I built a regulated 12 v dc power supply and tapped it into the bulb circuit so it will power the motor when the bulbs come on. You may have to find an electrician or techie to rig this up safely.Good luck!
Oct 12, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
