Question about Jenn-Air JED8430 Electric Cooktop
Stainless trim on cooktop is coming unglued. What glue should I use to fix this?
Installation in a hole bigger than the unit, is there a flange kit or something that will help get it to fit?
yes there is a kit you can use. most diy shops that sell cooker fixings etc will have them. they usually stainless steel and you have to cut them to size you need. and make a square with it. backing with bits of wood to the size of the hole need to put the top on and the stainless steel to cover the wood that has been put in. you can make your own. by filling the hole with wood strips get from a timber yard or store have them cut the size you need. then fix them to the open part you need to fill. leave a lip ( this is to put the stainless steel to. check it all fits. then get the strips of metal to fill the hole making sure they the right size glue them down to the strips of wood you have put in then put the top on. jobs a good one. don't nail the wood in place put 4 good long screws in each piece of wood gives it strength then.
Oct 30, 2013 | GE 30 in. JP340 Electric Cooktop
F35 ERROR CODE
had exactly the same thing happen; did you figure it out?
Would like to know if you had a big fee as won't bother if it is expensive to fix! Thanks Emma
Jun 16, 2013 | Miele KM 5753 Stainless Steel Electric...
I have an elecrolux E36EC70FSS2. The strip of stainless trim between the controls and the burner has come unglued and bows up when the lower elements are on. What adhesive do I need to resecure it. I...
there are Solder cool, they sell in any auto parts, is speciall Glue for seal any things. Solder in Cool. contain 2 parts a+b Buy it and fix it.
God bless you
Sep 24, 2012 | Electrolux 37 in. Designer Series...
Need a template for Whirlpool GJC3055RS Stainless Cooktop.
Go to the supplier/outlet you purchased it from....they will have one from their demo room.
Jul 21, 2010 | Whirlpool GJC3055RS Stainless Steel...
How do I fix a bad igniter on my F&P GC912 cooktop?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 18, 2010 | Fisher and Paykel GC912 Iridium Stainless...
Need a trim kit of some sort for the new jenn air I need to install the hoe in the granite is 1/2 inch too wide
i think no trim for that model,much beter to use an plate of stainless to fix want u want,then use sealant to fix it also.
Sep 07, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
The stainless steel rings on my cooktop are already getting burn stains. How do I clean them without discoloring the rings?
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jun 17, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Stainless Steel Cooktop - Remove Sealant Spray
try paint thinners , but before you do any thing you need to call the workman to see what brand of glue he has used.or to come out and clean it off for you or to see if thinners will work , it normally does but when i do resturant kichens out any spillages of glue is removed straight away.you will need to use polish cleaner after the thinners to stop any further marks appearing
Feb 17, 2009 | Thermador PC366BS Stainless Steel Gas...
Pitted glass cooktop in Jenn Air Model JGC9430ADS
Did you find anything out? We have had our Jenn-aire gas stove for 1 1/2 years and just noticed today that the surface has bubbled in a spot??? I did clean the oven last week.
Sep 10, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
176 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
