Press remote to power tv green light comes on than shuts off
Have two problems other one is colors shadow double on on colors do we have a major fix here tv is a mitsubishi projection screen model WS65711 is this tv worth fixing
  • 5,138 Answers
Replace Both of your convergence ICs they are big black ICs with STK on them use number on ICs if they are 110s use 180s if 020s use 040s other wise use same number on ics. Parts call 1-800-223-3205 or go to www.electronix.com .YES TV is worth fixing if all 3 tubes are Good.
Posted on Jan 03, 2009
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
I have a problem in my BPL TV(FHR-21) it showing a green color
How to Fix a TV When the Screen Is Green
A TV is calibrated by the factory to provide a "standard" picture that attempts to appeal to the vast number of buyers who take the set home. To adjust a TV picture that is too green, you must first enter the hidden "service menu" that technicians use. Adjusting the colors to remove the green cast will save you the cost that would otherwise be incurred from a TV technician coming to your home. No special tools are needed, nor any expertise in how the TV works.
Press the power button on the remote of a TV whose picture is too green in order to turn it on.
Press and hold down the "Menu" key until the manufacturer's logo appears on the screen. This could take up to a minute or more. Release the "Menu" key when the logo appears.
Immediately press the "9," "8," "7" and "6" keys in this order. Press the "Enter" button on the remote to enter the "Service Menu" screen.
Press the "Menu" button to go to the second of the two "Service Menu" screens. Press down on the "Down" arrow until you highlight "Color Calibration." Press the "Enter" button to enter the "Color Calibration" screen.
Select one of the color bars on the screen. Adjust the color by changing the values of the color bar by pressing left and right on the "left" and "right" arrows on the remote. Repeat this procedure with the other color bars as well. Stop adjusting the colors when the green cast is no longer present.
Press and hold the "Power" button on the remote to exit the "Service Menu" and save the adjustments you have made. Turn the TV off.
Sep 14, 2011 | Audio Players & Recorders
Seeing double with the picture - a lot of shadows with the picture?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 17, 2010 | Hitachi 53FDX01B 53" Rear Projection...
The picture on my TV has started to "shadow" or double on the sides of the screen and seems to be slowly working its way across the entire screen. The color is also getting goofy. My set is 7 years old.
•Screen looks 3D
Aug 12, 2010 | Hitachi 51SWX20B 51" Rear Projection...
Mitsubishi RPTV has a blue shadow/image alignment problem
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 23, 2010 | Mitsubishi WS-65809 65" Rear Projection...
My tv seems out of focus and has green shadows as well....do you have any idea what could be wrong?
  • Screen looks 3D
May 15, 2010 | Sony KP-53V80 53" Rear Projection...
The right side of the TV has shadows/distorted images and colors
  • Screen looks 3D
Jan 22, 2010 | Samsung PCL545R 54" Rear Projection...
Picture shadows...color (red) seems to be out of line
HELLO MY FRIEND. YOU PROBLEM IS THE CONVERGENCE STKS, WHEN THIS IC'S ARE BAD YOU HAVE NO CONTROL OF THE CONVERGENCE ADJUSTMENTS BY REMOTE CONTROL,IF YOU OPEN THE SET LOOK FOR TWO BLACK PARTS WITH SAME SHAPE AND NUMBER.YOU CAN BUY THIS PARTS ON LINE AND REPLACED THEM PRETTY EASY IF YOU HAVE REPAIR SKILLS AND ALWAYS REMEMBER TO UNPLUG THE SET BEFORE YOU DO ANYTHING.
YOU WILL NEED A SOLDERING IRON, A DESOLDERING TOOL AND SOME SOLDER, YOU CAN GET ALL OF THIS THINGS AT RADIO SHACK.IF NOT CALL THE REPAIRMAN HE SHOULD NOT CHARGE YOU MORE THAT $250.00 FOR THIS JOB WITH PARTS INCLUDED.
GOOD LUCK
CAYPIANAN@YAHOO.COM
May 10, 2009 | Televison & Video
Green shadowing
  • Screen looks 3D
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 06, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
