Question about BMW Vehicle Parts & Accessories
Bolt size 95 bmw 525 thermostat cover
I am looking for the bolt sizes for a 95 bmw 525 i thermostat cover
  • BMW Master
  • 14,384 Answers
10 MM
Posted on Nov 07, 2012
Starter bolt size 95 geometro
boy that is bummer.
the suzuki parts lists never show size, only p/n
you lost them both.? why say that, so I answer shorter.?
if not they you have 1 on now the thread sizes is known
M8 or M10 my guess.
so leaves what length , use a ruler?
measure distance?
25.4mm to one inch.
so if bolt is 4 inches, long, 4 x25 is mm size, shop math.
if both are lost. wow. golly good show, no./?
the find a both (long) that fits, now you know thread size and then measure lenght.
this is all cover under stop practices, in all mech, books. (and class)
Mar 08, 2017 | 1995 Geo Metro
What are bolt sizes on thermostat housing?
Shop for bolt sizes on thermostat... on Google
ARP 450?7401: ARP Thermost...
$5.70
Summit Racin... Thermostat Housing Bolts...
$9.95
Original Parts... ARP 434?7401: ARP Thermost...
$7.57
Summit Racin... ARP 134?7401: ARP Thermost...
$5.50
Summit Racin... ARP 430?7401: ARP Thermost...
$6.37
Summit Racin...
(4) Search Results
    The Official ARP Web Site ' Thermostat Housing Bolts
    arp-bolts.com/kits/product.php?PL=60
    Automotive Racing Products20 kits found for Thermostat Housing Bolts ... These premium grade bolts are engineered to properly engage the manifold threads and ... Thread Size 1, 3/8?.
    Thermostat housing bolt size questions ' IH8MUD Forum
Dec 05, 2015 | Cars & Trucks
What are the bolts size for the thermostat housing for a 2004 Chrysler 300m
I don't know the size of the bolts but I felt it was a good idea to ensure you are asking about the bolt size and not the spanner or wrench size.
Typical bolt sizes for the retaining bolts of thermostat housings are 6x1 mm, 8x1.25 mm and 5/16" either UNC or UNF.
The wrench or spanner sizes are typically 10 mm, 12 or 13 mm or half inch respectively.
I haven't met many other sizes for that job...
Mar 03, 2015 | Chrysler Cars & Trucks
Need to know the bolt size or the thread pitch for the thermostat house bolts on a Chevy 4.8 2003 truck
go to chevy.com for parts diagram, this will have the bolt sizes listed.
Jun 04, 2014 | Cars & Trucks
Alternator bolt size
the head size for socket size or actual bolt spec.?
you lost the bolt (not stated) or just want to unscrew it?
I'll'' guess at lost.
its metric.
and is 6mm or 8mm ? in size. (i bet 8)
buy some 6 and 8s in the store and see if one fits.
if one fits , you now know the diameter in mm and the pitch.
now buy the correct length (use a ruler)
Jan 27, 2014 | Honda CR-V Cars & Trucks
What's what size bolt do I need for a 89 Diahau charade bellhousing?
We have no reference material to look that up
Remove one bolt ,measure its diameter in inches
& divide by .0395 to convert to metric bolt size
Oct 03, 2012 | 1989 Daihatsu Charade
Location for fuel pump on 92 525i bmw
Typically, you will find the fuel pump for a BMW 525 located under an access panel in the trunk. Remove the contents of the trunk, remove the floor/spare tire cover and a metal access panel will be visible on the floor being held in by several small bolts. The panel is about 4"x6" in size. Remove the bolts, carefully pry up the panel (it has some sticky sealing material) and the fuel pump mounted on top of the gas tank will be visible with fuel lines entering/exiting it. This is where it was for my 1990 525i.
Jul 24, 2011 | BMW 525 Cars & Trucks
What are the torque specs for belt tensioner
There no real specs for the tensioner. The bolt should be tight and the unit as a whole should be squared to the engine. If it is in anyway tilted, th eunit is coming apart and will need to be replaced. One bolt holds this unit in place. It should have adequate tension to keep the belt taunt against all the pullies. If you are dealing with a constant squeel issue, locate the writing and you should be able to read it like holding a book in your hand. If it is upside down to you, reinstall. this will take care of the squeeling 9 times out of 10. The tensioners for replacement run about $50 - $75.
Oct 23, 2010 | 2005 GMC Sierra
I just bought an old 95 plate zx6r last week and upon stripping the fairing off iv discoverd that some muppet has lost two bolt from the primary cover and instead of replacing them they have filled the...
Your local dealer will have a size chart available for all the bolts and screws this bike will carry. If the bolts are striped you can drill out the cover holes and heili coil the holes. These should be in the 6mm range screws. Don't sweat the lttle stuff cause the longer you work on older bikes the more you will find somebody has been there before you and in most cases they have blotched something up. And in most cases it is an easy fix and the moron that messed it up just didn't look at it right.
Mar 30, 2010 | 1995 kawasaki ZX-6R Ninja
Im looking for torque specs for factory jugs and head for banshee can someone please help,lost my book and to late to get one, thank you
Look up the spects on your bolt size, ie, 8 mm or 10 mm.  You can find generic spects on the net. Per bolt size not socket size, but the bolt. You can measure the bolt with a end wrench though. Put the end wrinch on the bolt at the threads till one will fit, thats the bolt size. Some spects call for dry or wet numbers. Wet just means lightly oiled.
Aug 04, 2009 | Yamaha RD 350 Motorcycles
Vehicle Parts & Accessories Logo
54 people viewed this question
Top BMW Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
greg benton
Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
