Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
No froth Just got a krups xp2070. The first few times, it made froth. Now it won't. I took off the frothing thing and cleaned it thoroughly, including sticking a toothpick through the holes. I'm using cold, fresh milk. It gets hot and makes steam, but I just end up with hot milk and no froth.
  • xbadger9 Jan 17, 2009
    The first couple of times I used the steamer I got very frothy milk and was loving the machine. Now the milk heats up but no froth is made. Please help
  • Anonymous Apr 08, 2009
    Same exact thing
  • 56 Answers
Make sure the small metal tube is clean as well as the holes in mounts into. The tube can be removed easily from the rubber ends and cleaned. I've had my unit for a year now and we use it ever day without this issue ever happening. I did have the constant beeping water leaking from the seat/valve problem which I fixed by opening up the unit and tightening the screws.
Posted on Apr 15, 2009
When I try to make espresso with my new XP2070, water comes out through the steam arm and not through the nozzles. I've tried it without coffee and all the water still comes out through the steam/hot water...
David, the XP2070 won't operate properly until you've set the clock on the unit.
In case you don't have an owner's manual, I've attached a copy of the manual from the Krups site that you can download and print for free.
Please take some time to reaquaint yourself with the setup and procedure for using the expresso portion of the unit, as you might just have some sequence issues that is preventing the expresso from getting brewed.
Otherwise, it could be that the unit has a faulty seal in the pressure vessel that isn't allowing the expresso side to function properly, hence the reason the water might be coming out of the frothing tube instead of through the expresso brewing section.
http://www.krupsusa.com/NR/rdonlyres/C308FB44-1EC6-4119-A060-C73BD65F4789/7355/XP2070espresso.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Not frothing milk
that means that the steamer is not generating enough pressure steam.
This happens either because there is not enough heat, or if you release the steam when pressure is not enough.
Very common problem with the american maid makers.
bear also in mind that Krups are not the best at frothing milk, and this is also a basic model.
If you want the best capuccino Coffee machine, buy the italian ones, Gaggia, Delonghi, Ariete etc. that are all great at this, or get a bigger Krups as a replacement like the Krups XP405040 that is also good at capuccino
May 09, 2009 | Krups XP7225 Espresso Machine
No froth
ing it back to store and tell them ur problem....u can ask for repair or a new machine
Apr 19, 2009 | Krups XP4030 Espresso Machine
My Krups XP4050 frother heats and makes bubbles but no froth
It doesn't froth because the air hole in the frother has become plugged with dried milk (cream). There are two types of frother - old one was a black rubber nipple with a stainless 2-3inch air tube rising above the milk. The plastic insert has a pin hole (really about the size of a straight pin!) that clogs. Use a sewing needle or straight pin to clear it.
Apr 01, 2009 | Krups XP 4050 Espresso Machine
Milk froths at 1st then doesn't after 1 week
Ensure first that you are using the steam pipe in the correct way to froth the milk.
If it still does not work, that means that the steamer is not generating enough pressure steam.
If you think you are doing everything in the right way, then contact the company and insist for having the machine fixed or replaced.
Nov 07, 2008 | Krups XP 1500 Espresso Machine & Coffee...
Aeroccino does not heat
Try descaling, if the element is covered with scale it wont produce enough heat and pressure.
The machine is Krups, and therefore should be covered with one year warranty. Call the number listed on the user manual, or find contact from websites below:
Coffee & Espresso Machines - Small Domestic Appliances - Krups
Home - Krups UK
Oct 06, 2008 | Nespresso Aeroccino Automatic Milk Frother
Frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Sep 12, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Steam generator
hard water build up in steamer tubes a good clean with clr should help remedy this make sure maker is completly cleaned after using clr cleaner
May 15, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP 2070
I have the same problem and this is the second machine. I warrantied the first one because it stopped working. I brewed one espresso with this machine and now no water or steam will come out. Help?
Dec 23, 2007 | Krups XP2070 10 cup Coffee Maker/15 bar...
Froth control problems
Your vinegar did the job: it as removed the deposits, now these deposits are clogging the four holes porcelain valve.....if the froth lever is not broken.
Remove all the screw you can see on the top and under the top of it, remove the cover, unscrew the frothing device down to the porcelain valve consisting of two 4 holes discs, clean them, and voila!
Dec 22, 2007 | Krups XP 1500 Espresso Machine & Coffee...
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
272 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
